Transportation Chain and Binders
/ Transportation Chain and Binders #1
Huntshillhaus Farm
South Central Missouri
John Deere 2150, Husqvarna Z554
When it comes to purchasing chains and binders for hauling my JD 2150 tractor (approximately 7000lbs with FEL and Ballast), are the 5/16 - G70 chains and binders from https://www.uscargocontrol.com/collections/transport-chain-and-binder-packages sufficient, or have any of you had bad luck with imported chains? With a 4,700 WLL, I imagine four chains is more than sufficient to bind it properly, even if the chain is inferior to US made chain?
/ Transportation Chain and Binders #2
/ Transportation Chain and Binders #3
If you use 4(FOUR) separate chains, Plus another for each attachment, you'll comply with DOT and prudent practice.
see link:
https://resources.lytx.com/blog/load-securement-guide#:~:text= Cargo Securement: Factors to Consider 1,does not breach DOT load securement... More
Per DOT regulations a 7,000 pound tractor requires 2 chains on the main body plus the attachments. Using 4 4,700 pound rated chains in addition to another 2 for the attachments is in far excess of the minimum requirements.
/ Transportation Chain and Binders #4
US Cargo Control has good products and I like what they have. In your particular instance I would imagine your plan of 4 chains would be more than sufficient no matter where they are made.
For tractors and other equipment I use chains, but for other stuff I use straps and always go for more strength than I think I need. I look for extra thick straps even if the load rating is the same. I've had some of the straps cut by edges that were sharper than they seemed to be. (I always carry extra, just in case).
I am aware of the under/over 10k load rule, and the requirements it entails, my main concern is whether or not the import chain and/or binders (boomers) are a problem. It's enough money even for the cheaper stuff that I don't want to do it twice. Is it sensible to buy cheaper chain, but better binders? Do the Chinese ones function well?
On a separate note, what is the most practical length of chain for two or four way binding. Could I buy two 20' or 25' chains, and four extra hooks, and end up with four 10-12' chains for the corners? Or are those too short to be practical? Or should I get two long chains for the front and the back, and only two binders? I have plenty of 10k rated straps for the FEL and attachments.
/ Transportation Chain and Binders #7
I have plenty of chain for securing loads or towing, dragging. Inherited a lot from my Dad. I did buy 2 20'ers and extra hooks at Tractor Supply (they are foreign made). I cut them in half, added new hooks and dedicated those 4 for securing tractor or vehicles. Plus more chain for implements. It's been 20 plus years now without any problems. I inspect the chains for any signs of weakness. I used straps before the chain but found I had to replace them every couple years due to wear.
/ Transportation Chain and Binders #8
When hauling my Kubota B7800 I used 3 5/16" chains and 5 /1" ratchet binders.
1 chain on the front with each hook attached to either side of the grille guard and then other end to the binder that is hooked to a stake pocket on either side of the trailer. Then the loose chain can lay on the trailer. Same way on the back of the tractor. Then a chain across the implement with a separate binder. And I prefer using ratchet binders.
And the 10 footers are plenty long? I suspect they are, but have not yet loaded the tractor to see. I have a rub rail and stake pockets, and eight D-Ring tiedowns, so I would think four 10 footers would be plenty.
/ Transportation Chain and Binders #10
Yes, 10'ers are plenty long. My trailer is 22' tilt bed (actually 23 1/2' with tail). It has a rub rail along each side plus stake pockets so I have several places to loop the chain through. I also have drop in D-rings I can put in the pockets. I also bolted D-rings on the front tractor frame sides and a twisted clevis on the rear draw bar.
/ Transportation Chain and Binders #11
A 10 footer is a little short to go all the way across. If you’re using 4 chains 10 foot is more than sufficient.
/ Transportation Chain and Binders #13
/ Transportation Chain and Binders #14
I’ve had the exact same chains and binders for over 20 years. Works just fine and no breakage. I have never seen any U.S. made binder chains for sale anywhere.
/ Transportation Chain and Binders #15
What is the difference between 2 10 foot chains on the rear or one 20 foot chain secured through the drawbar and fastened in two corners of the trailer? If you do the same in the front, you have tie-downs on 4 corners of the trailer.
/ Transportation Chain and Binders #16
Because the 2 chains are 2 chains so 2x the working load and the load can’t shift sideways. With 1 chain going through the drawbar you only have the working load of one chain and minimal resistance to side shifting.
/ Transportation Chain and Binders #17
Good point. But I thought the requirement was 4 tie down locations, not 4 chains?
On a 10k plus piece of equipment, I believe it's four separate chains and binders. My tractor is under that weight, but I may someday need to haul something that is, and I want to cover my bases.
/ Transportation Chain and Binders #20
I cut two 20ft chains down to 8ft/12ft with a grab hook on one end and a slip hook on the other, seems you always need some a little longer or shorter, works well for me. I also keep two 20ft chains in the truck.
I prefer 4 chains even on my 7k tractor, for binders I like a ratcheting style with the folding handle. I prefer US or other quality chains but haven't seen any problems with the cheaper imports. Last couple 5/16 g70 chains I bought were actually from harbor freight because I needed them right then, have had them for 7 or 8 years with regular use and seem to be holding up fine.
Sent from my SM-G715U1 using TractorByNet mobile app
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
(2) UNUSED 12-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12-16.5...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
KMC 6R HEAVY DUTY ROTARY TILLER (A64276)
KMC 6R HEAVY DUTY...
BALDOR INDUSTRIAL 15 HP MOTOR (A64281)
BALDOR INDUSTRIAL...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
