Chain and Binders
/ Chain and Binders #1
B7510HSD
Veteran Member
Kamiah,ID
Kubota B2601
Ok guys what do you recommend for my Kubota I estimate the weight at 3000# with FEL and BH...5/16" chain and how many? how many binders?? This will be hauled on an 18' car trailer...Thanks in advance!
/ Chain and Binders #2
To be legal. 6 ..........2 crossed on the front , 2 crossed on the rear, 1 on the fel bucket and 1 on the hoe.
Yup seems like overkill but thats the requirment
If GOD reached down and picked your trailer up and turned it upside down, your tractor should be still on the trailer !!
/ Chain and Binders #3
kinda open ended question. I haul equipment for work as a job and under 10k pounds your only required one chain and one binder through the hooks at both ends of the machine. Grade 70 chains (4700 lbs). Also, we need a chain over each implement. I fyou are hauling a backhoe for example, you need a chain over the front bucket as well as the rear bucket so you would need four chains and binders legally. Depends on the state and the load. With only a 3000 pound load, I imagine you wouldnt even need grade 70. Do you want to be legal in your state or just haul the load safely? There is a difference. I know I dont need a chain over every implement traveling a few miles. Also i know i dont need grade 70 chains for some loads. But do i want to avoid some hard nosed traffic cop? Yes. check your state laws or maybe someone on here is from your state and knows.
/ Chain and Binders
Thanks chin I knew about the implements needing to be sucure..so if I was to run from one side of the trailer to the hook and then to the other side with a binder ?? or just a straight chain one one each end?
/ Chain and Binders #5
100% correct. Only thing I will add is 2" staps are fine for the FEL and BH.
Chris
/ Chain and Binders #6
I don't like to use just one chain. What if it comes loose or breaks?
A friend of mine was hauling a small Bobcat just 1 mile. He took the time to put 4 chains on it. Good thing he did. Traveling 45 mph a car going the opposite way came in his lane and they hit head on. His F350 saved his life. The other driver list theirs. Cops said they could not believe the equipment stayed still and not through the back of the truck. That would have surely killed him and the other two in the truck with him.
Chris
/ Chain and Binders
Thanks guys I was planning on 4 on the tractor and maybe straps on both buckets!! Now to find all this at a reasonable price everyone around here tells me Harbor Freight not so sure of the quality!!?
/ Chain and Binders #8
Lowes is the best deal going on 5/16 G70. 20' for $30. Have them cut them in half and buy 4 extra hooks.
Chris
/ Chain and Binders #10
while technically 6, i make use with just 2 20' chain front and rear. I hook my hook binder on the bottom of my stake pocket. 1 end of chain is hooked on tractor crossed to binder. (about 4' of chain) extra chain goes to other side of trailer, were the hook end crosses back and hooks on the rear of the tractor with a second binder on that side (extra chain in the middle on the trailer floor)
thus 2 chains on the rear made out of only 1 length of chain.
same for the front, then straps for the FEL/BH. = just 2 20' chains have to be purchaced (4 binders)
/ Chain and Binders #11
this. when i was driving flatbed over the road, i hauled a lot of small equipment (skid steers, balers, combine cutting heads, backhoes, etc). i used one chain and two binders per end of vehicle and i always used straps to restrain buckets, loaders, et al. i never had a bit of trouble with local, state, or federal DOT folks.
/ Chain and Binders #13
Which binders do you guys prefer-ratchet or lever and why??
Now you started a war. Lol.
I like lever and only use two. I pull my tractor up on the trailer and shut it off. Hook up my rear chains tight as I can then use the two lever binders on the front two chains to snug it down with a three foot cheater pipe.
I then put straps oner the FEL and implement using corner protecting pieces of plastic I got at a truck stop.
I got my binders at HF.
Chris
/ Chain and Binders
I thought you had to have one binder on each corner??
/ Chain and Binders #15
No just a tie down. I prefer to only put them on the front. Its one less thing to fail in a crash and allow the load to come through the rear of my truck.
Chris
/ Chain and Binders
Lots of good info thanks guys!! Any opinions on the HF binders??
/ Chain and Binders #18
I found that all your box stores and even my local truck stops carry what looks to be the same binders from China/India. So unless you are going to search out some pro grade binders they are all about the same.
Chris
/ Chain and Binders
Thanks again Chris hopefully will bring home a trailer Saturday!!
/ Chain and Binders #20
I guess my 10k lb straps aren't good enough? :stirthepot:
