m7040
Elite Member
- Joined
- Sep 15, 2006
- Messages
- 4,207
- Location
- Frederick maryland
- Tractor
- Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
The brakes on the 10,000 lbs equipment trailer are not working. I do not use it often and the F350 dually has enough brake power when lightly loaded but would want to make it legal without a lot of expense. First problem was the connections on the wiring were twist on types or crimp types and no power to the brakes and some lights. Flipped the trailer over with the excavator and fixed all connections under the trailer with connectors with glue inside and when heated with the heatgun they seal pretty well. Now checking each wheel to see what I find. First one had broken wires inside the drum for the magnet. Spliced in some wires and tested the magnet. It works now so 3 more drums to go.
