Rim guard or not? Why a ballast box instead of boxblade?
/ Rim guard or not? Why a ballast box instead of boxblade? #141
I think you make a good point. Tires are normally filled ~80% so if the tractor starts to roll that fluid in the bottom 80% of the tire starts to slosh into the top 20% of the space that's normally just air. Especially the fluid in the tire on the "top" side of the tractor. Makes an already bad situation a bit worse.
At this point it will be irrelevant and non-provable.
/ Rim guard or not? Why a ballast box instead of boxblade? #142
NOT PHOTOSHOPPED... JD has a low front bumper designed to keep from bumping into trees and rocks and cracking plastic hood.... Discovered bumper wedges under lip of FEL when it died on most remote back corner of property (naturally most inconvenient place) and I had to move/drag it down to shop .... Yes its all just wedges and leverages and balance.
Keep in mind that this set of graphics was carefully setup for photo shoot only I don't usually push little tractor beyond its limits, I have learned if tractor says no, then I don't do it....
Thanks for the reply- makes sense
/ Rim guard or not? Why a ballast box instead of boxblade? #143
I also have a dedicated lawn mower. If I can mow the lawn with two machines instead of one, I'll gladly do it just to get the job done quicker.
I bought a zero turn last year, can get the grass done faster than with the tractor/rear finish mower. The tractor/RFM are great in tall grass, such as a first ever cut.
/ Rim guard or not? Why a ballast box instead of boxblade? #144
This is almost always overlooked. My rears are 75% filled. This means I only 25% the volume of air to ride on. This means you have to run slightly higher pressures to get the same tread pattern on the ground. So ride is changed. Good point that hadn't been discussed.
More pressure is not always better, you are doing more damage via soil compaction. This is why the majority of AG tractors come with Radial R1 which are not loaded. They add wheel weights, leave the tires unloaded so the air pressure can be adjusted as soil conditions require.
/ Rim guard or not? Why a ballast box instead of boxblade? #145
Been out here 40+ years and had a tractor all that time. I thought about a ballast box a few times. For me - a ballast box is of no use. I have VERY FEW really tight places and have no business with my tractor in those that are tight.
I have 1550# of RimGuard in the rear tires and a 1050# rear blade on the 3-point.
The M6040 Kubota is just not a tractor for tight places.
However - I do see the definite advantage of a b-box if you have a smaller tractor and need to do work in tight spots. I see some very "enlightened" designs for b-boxes - increases their usefulness.
I think of a ballast box as most other 3-point implements. If you need it - fine. Otherwise - wise money says use a 3-point implement and get more bang for your buck. JMHO
I agree! I too have very few tight spots that my tractor goes into. My rears are filled with cow friendly antifreeze - the Mahindra dealer doesn't do rimguard. When I need more ballast, be it due to a tight space or maxing out my FEL/forks/bale tines etc with a very heavy load, I back into a round bale. During the winter I usually have a bale or two that aren't "cow" good so I'll wrap mostly in plastic and leave out in the elements to gain weight. Don't think I'd go back to weights or other means of ballast - just another step to drop an implement and add another when 50+% of the time I just leave the bale tines on the back end.
/ Rim guard or not? Why a ballast box instead of boxblade? #146
Air pressure in the tire has minimal to no measurable difference in regards to compaction. Weight does that.
Radial tires are used because of the gain in traction.
The tread pattern that my tractor sitting in the machine shed right now has is determined by the weight on the tire. It's distribution is somewhat varied by air pressure. Which can be adjusted the same as one without fluid.
/ Rim guard or not? Why a ballast box instead of boxblade? #147
Seems like a lot of people on here dislike Rimguard. Totally disregarding any discussion of whether ballast is needed or not, what are the downsides of Rimguard? The only thing I see is the potential for staining a surface if you puncture a tire. it' supposed to be relatively freeze proof and non-toxic. I remember calcium chloride filled tires when I was a kid, but that's pretty corrosive unless I am mistaken?
/ Rim guard or not? Why a ballast box instead of boxblade? #148
L
A major advantage to radials is less soil compaction.
/ Rim guard or not? Why a ballast box instead of boxblade? #149
Change the drawbar hitch to a piece of 3X12 (or similar) steel bar, as long as there is room for.
Under the tractor, the weight would be out of the way. ...
I would be curious to know how much additional weight you would add doing this. Doesn't seem (to me) it would be very much more than the actual draw hitch itself. My filled tires add ~750# each (~1,500# total). As mentioned earlier, I'll back into a round bale (1,200-1,500+# depending on the time of year) if I need to offset the front end any more than that.
/ Rim guard or not? Why a ballast box instead of boxblade? #150
You can reduce the potential for staining and mess made by using the green slime stuff that is specifically made for filled tires. I have my fronts filled with green slime and the filled rears have the equivalent type of slime that is made for filled tires - can't remember the brand. The other option might be to just not have anything that will stain - dirt floors in barns/shops nothing but gravel roads, etc.
Some of the biggest deterrents I've heard about fill/nofill have been tire & rim issues. Although I've not had any rim or tire issues, I've heard that some of the older fills were corrosive enough to destroy rims and eat away at the tire - seen pictures too. I don't think that the tractors of my youth (8N's) were filled but for the last 25 or so years my tires have been filled and I haven't had any issues.
/ Rim guard or not? Why a ballast box instead of boxblade? #151
490 lb per cubic foot for steel. that equates to a little under 41 lb for a piece of steel 12" x 12" x 1" thick.
/ Rim guard or not? Why a ballast box instead of boxblade? #152
I use LiquiTube, regular for fronts and ballast formula with RV antifreeze on rears.
/ Rim guard or not? Why a ballast box instead of boxblade? #153
A piece of steel 3" x 12" x 30" would weigh in at 305 pounds. Steel weighs 0.2826 pounds per cubic inch.
I'm assuming that "drawbar" in this case means the piece held by/between the two lift arms.
Edit: Looks like simultaneous posting above.
/ Rim guard or not? Why a ballast box instead of boxblade? #154
But, I'm guessing, my draw bar weighs 30 - 40#
/ Rim guard or not? Why a ballast box instead of boxblade? #155
Article on tire fill materials.
/ Rim guard or not? Why a ballast box instead of boxblade? #156
I see a lot of people buying 3 point ballast boxes or making ballast containers out of drums to attach to their 3 point hitch.
I have never really grasped why not just keep a box blade on the back so you could have not just a weight, but something that can be used should you wish to drag something? I have seen some weld a section of railroad rail onto the top of a box blade to make it heavier.
You can use any weight on the 3 point hitch to provide counterweight, be it an implement like a box blade or a dedicated counterweight. The key is having enough weight. Unless you have an unusually heavy box blade for its width, you will either end up with too wide of a box blade for your tractor to effectively use in order to get the blade to weigh enough, or it will be too light to be a counterweight to pick up heavy loads with your loader. Generally it takes a fairly heavy and long implement to serve as adequate counterweight. Some people have been pretty creative with rear ballast, and one popular one in my area is to spear a round bale with a 3 point bale spear.
Regarding Rim Guard, I don't have any personal experience with it, but I do have water/methanol in my rear tires. That was very economical and won't be that big of a hassle to deal with in the future when tires need fixed or replaced. The tractors I grew up operating had calcium chloride and we didn't have any trouble with any of them, but rarely kept one beyond about 15 years, so any corrosion issues wouldn't really have happened yet.
Maybe, but rear tire ballast doesn't move the pivot point of any load on the front axle, appreciatively. Weight on the 3PH does, thus reducing wear and tear on the front axle, steering gear, etc.
Weight does indeed need to be placed behind the rear axle to unload the front axle. The farther behind the rear axle, the more torque the counterweight exerts to resist the torque the load on the loader exerts on the tractor. However, loading rear tires certainly can improve performance of the tractor when using the loader even though it doesn't unload the front axle. It does improve traction of the rear axle and the ability of the brakes on the rear axle to slow down the tractor. This is the "other" important reason to have appropriate amounts of ballast and why ballast recommendations also mention weight distribution between front and rear axles.
I would also add another big reason that radials are often not fluid-filled is that the mechanism for much of the advantage radials have over conventional bias-ply tires (lower ground compaction and better traction due to larger contact patch, smoother ride, cooler operation in high-speed environments leading to higher road speeds) stems from the greater ability of the sidewall to easily deform or "cheek" due to the radial ply orientation. Putting fluid in radial tires decreases the ability of the sidewalls to deform and eliminates much of their advantage over the less-expensive, sturdier, and self-cleaning bias ply tires.
EDIT: Changing air pressure certainly does change ground compaction. The more pressure in the tire, the more resistant to deformation the tire is. The contact patch is simply deformation of the tire from donut-like to flattened where it meets the ground, so the higher the air pressure, the narrower and shorter the contact patch. Ground compaction is due to the pressure exerted by the tire on the ground, and the smaller the contact patch, the higher the pressure. Adding fluid to tires will make the tire stiffer and shrink the contact patch, but one can still change this somewhat by adjusting air pressure, just less than if the tire didn't have fluid.
/ Rim guard or not? Why a ballast box instead of boxblade? #157
I found that usually when I was using the loader, the box blade also was useful. On my Kubota BX, I was using a snow blade in winter and with the box blade on back I could pull snow away from the garage door, back over it, then push away towards the street. Therefore in winter or summer the box blade was useful both as implement and counterweight.
Then two years ago I bought a Heavy Hitch and I love it. It's expensive - you're paying as much for iron deadweight as you would for an implement - but I can leave the A-frame on all the time, (while mowing for example) and easily add weights if I decide to pop on the FEL.
Further, I have two heavy trailers to spot and often need weight in the front. The suitcase weights will hang on the front brushguard plate of a BX, or better, my brushguard has a receiver where I can plug in the Heavy Hitch front weight bracket and quickly put 250 pounds of weight on the front. Before I would make do with mounting the FEL.
If you are in a similar situation and can afford it, Heavy Hitch is a good setup.
/ Rim guard or not? Why a ballast box instead of boxblade? #158
Check out bio-ballast. Non-toxic, non staining. It’s what the dealer filled my tires with.
/ Rim guard or not? Why a ballast box instead of boxblade? #159
Interesting that this thread came up on my email notification as just yesterday I did the design sketches for a ballast weight I could build for less than 1/4 the price of any comparable thing I could find. (and yes, it has a hitch receiver built into the design, but I also have a receiver added to my box blade so I can latch onto a trailer without dropping the implement when needed) So, here I am trying to decide which route to go and this thread comes up on my email.
I have a heavy box blade (nearly 1000#) that is 96" wide and I was contemplating making some suitcase weights to add another 1,000# or so to it as I have felt the rear end start to feel really light when picking up large stumps or boulders with my grapple. This means I'm putting too much stress on my front end and need to anchor my rear down. Then I was considering building this ballast weight because having an 8' box blade behind a tractor that is only 78" wide gives me a significant overhang on both sides. The extra width is essential when using the box blade, but not so much when just doing other things. Probably only 15-20% of the time am I using the box blade. My ballast design would add 1,550# hanging out past the 3 point hitch where filling the rear tires with 5#/gal of CaCl2 would add nearly 1,600# at the rear axle. (16.9X30 tires, so 73 gals/tire), making the ballast design more effective weight-wise than fluid and removable when pulling a heavy implement that doesn't need the added weight. With a quick hitch, picking the weight up and dropping it off are no problems. (my 3 point is rated at 5100#, so none of the options I'm considering are too heavy)
Up until this point I've also been hesitant about adding fluid to my tires as I was raised with fluid filled tires -- a necessity for traction when plowing in deep black loam soil -- and have had more than one instance where too much speed when roading the tractor from one field to another got a bit scary for a few moments when the fluid started rotating with the tires and the tractor started seriously lifting or bouncing creating a steering challenge. I don't drive my tractors that fast now that I'm older, but if you road your tractor, please consider this as the speed point between being safe with fluid in your rear tires and the scary/deadly point can be rather narrow. (tires are only supposed to be filled with fluid to the top edge of the center of the rim leaving everything above the rim air) I suppose on most compact tractors this might not ever be an issue?
So, like most questions on here, your personal circumstances and uses dictate what is best for you. What works for one person in their circumstances might be entirely wrong for the next person.
/ Rim guard or not? Why a ballast box instead of boxblade? #160
My bad, I thought you initially said the draw bar, not the hitch. So now I'm guessing you are either welding this 3x12x30 piece to the bottom of the draw hitch or you've fab'd a drawbar that will go into the hitch to hold it in place, correct?
I don't have much more room than what my drawbar will fit in that hitch opening, sorry for being confused..
New/Unused ATS-T460 Mini Skid Steer (A61166)
New/Unused...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
LandHonor LHR-UBF10 10in Utility Blower Fan (A60352)
LandHonor...
2007 Toyota Avalon Sedan (A61569)
2007 Toyota Avalon...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
New/Unused Wolverine 77in Quick Attach Bucket (A61166)
New/Unused...
