Problem sharpening a new chain
/ Problem sharpening a new chain #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I use this type of file guide for hand sharpening my chains although mine is Stihl brand. I don’t really want to buy a new system as this normally works fine.
The problem is on a new chain something on the guide hangs up and doesn’t allow me to sharpen the chain with the guide install. Not a big deal I just remove the guide. After I have run a few tanks of fuel on a new chain and sharpened it a few times I can reinstall the guide. What is happening with the guide catching on a new chain? I can’t really see what is hanging up. This is one of those questions I’m more curious of what’s going on than really needing to know.
/ Problem sharpening a new chain #2
Don't know. Have same sharpener but have never used the guide. Can't see what i am doing with it in the way. My chain has guide lines on the teeth so i just eyeball it with those marks.
/ Problem sharpening a new chain #3
Catching the tip of the chisel on the tooth?
/ Problem sharpening a new chain #5
I have a couple theories: Some new chains come with a profile under the cutting edge that does not match the curve of the file, at least not where the guide positions the file. So you're recurving the profile when you file which can be kind of grabby until you've filed a few times and made the teeth match the file. With hand filing you position the file in a slightly different way.
The other theory is that on a new chain the distance between the tip of the cutter and the back of the raker is pretty short. The guide may be keeping the file up a little more than when you hand file, and the file may be hitting the back of the rakers.
When I was young it was easy to see what was happening when I sharpened chains. Now I need reading glasses.
/ Problem sharpening a new chain #6
It’s the correct size file. I think Eric’s theories make sense.
/ Problem sharpening a new chain #8
Can't say I have ever noticed this and I sharpen a lot. Use the same style guide. It's likely based on how the original chain was ground, and the particular shape of the gullet and point. What brand chains are they?
/ Problem sharpening a new chain #9
I think it has to do with the chain companies trying to make their new chains easier for newbies to sharpen. I got a new Oregon chain for my Stihl. It was a purple ***** to sharpen the first few times. I have the sharpener that Dodge Man shows and an Oregon - clamp on the bar type. Both were a real PITA the first couple times. Then something got "ground out" and both work just fine now.
/ Problem sharpening a new chain #11
Getting ready to play with some more complicated chain myself. My files for sharpening square ground came in so will get to work on trying to sharpen that style chain.
/ Problem sharpening a new chain #12
Never used an guides.
I simply file a stroke or 2 every odd tank fill just to maintain a nice fresh edge and the chips fly.
Every so often I clamp my blade in a vice and touch up the rakers and clean up any damaged teeth.
Important is also to draw file the bar to a nice flat or square surface.
Here a single cut file is the best tool.
/ Problem sharpening a new chain #13
I use Stihl chains with a Stihl 2-in-One sharpener/guide. I notice the same difficulty on the first sharpening of a new chain even though I am sure it is the correct file, guide and for the chain. It just happens on the first stroke or two on a few teeth. After that everything works as normal. I only use a new chain once or twice per year so it doesn't happen often.
However, I bought a new saw in October with a longer bar (but same chain profile, just more links) and a couple of new chains. I noticed the problem on the first sharpening of the new chain. I think it is as others have noted about the original profile being a bit different on some teeth. Just powering through it the first time fixes it.
/ Problem sharpening a new chain #14
If you are cutting mostly all softwoods those sorts of file-holder hand guides are good enough. If you have much hardwood like I have cut for the last thee decades, you need an accurate system. I was never much good with the hand guide like that. I use one just for touchup in the field, but that's all. Now, except for the files themselves, the Oregon brand tools I have tried have been of low quality. I tried the "Timberline" sharpening jig but I did not like it. I have been using the "Granberg Bar-Mount Chain Saw Sharpener, Model# G-106B" for quite some time in my home-shop. They also make a similar tool that uses a 12 volt powered grinder (G1012XT). It holds the file precisely at both angles.
The way I get a chain really sharp, particularly if you have hit a rock or such, is start with a dial caliper and measure the length of all the teeth to find the short one. Using the Grandburg I set it up and sharpen that one tooth. I then measure it and sharpen all the rest of the teeth to that length. When they are all the same length they are also all the same height. It does sound like a lot of work, but it is effective. I learned the measuring trick from a professional lumberjack.
I harpened our fire company's saw and the enxt firefighter who used it said it was the sharpest re-sharpened saw he ever used.
/ Problem sharpening a new chain #15
Eric’s explanation is correct.
/ Problem sharpening a new chain #16
Oregon makes a dremel style chain grinder that comes with different size stones. Once you try it you'll be hooked. It sharpens the chain in one third the time and does a great job. It runs off 12V so you can sharpen at your work bench with an old battery charger or anywhere in the field with your tractor/car battery.
/ Problem sharpening a new chain #17
That orange Stihl file guide that was posted on the Amazon link is really nice. In addition to sharpening the teeth, it keeps the rakers at the right level so the chain continues to cut nicely. That file is crazy expensive, but I remember it being $35 not $50 so look around.
I also stopped buying the anti-kickback chains and got the more aggressive versions and was much happier. (I think they are green vs yellow. ???)
A safety chain is not safe if you are struggling to get it to cut.
/ Problem sharpening a new chain #18
Properly sharpened anti kickback chains do not cut any slower than regular chain, except when making bore cuts. The anti-kickback feature sticks up and reduces the raker depth when the chain is bent around the nose of the bar. That's how it reduces kickback. On the flat part of the bar it's below the rakers and has no effect. On some the anti kickback feature may need to be filed when the rakers are filed.
I've tried a couple of the Granberg type filing contraptions. I find them slow and frustrating to use. I'd rather hand file or use the Oregon guide that's just a flat plate. I mostly cut hardwoods on my property and hand filing works well for me. I do have a lot of practice hand filing as that's how I sharpened chains when I was running saws for the forest service. But there's a reason there's a lot of different tools for sharpening chains, different ones work for different people.
/ Problem sharpening a new chain #19
I may not be a pro but I hand file and I can assure U that the chips fly.
OK, perhaps I have a sharp eye and dexterity but my saws cut, and well.
Since I VERY rarely cut on or near the ground I avoid damaging saw teeth.
From there a touch or 2 with the PROPER file goes a long way to keep teeth sharp.
I do like to do that 'touch up' often, besides at my age (83) I like the that 'rest' period.
It is really not rocket science, just align (eyeball) your file with the angles of the teeth and give a stroke or 2 every tanking or 2 and those chips will fly.
Also, as said B4, use a single cut file and dress your blade every so often. Keep the blade edge square so as to have your chain track true otherwise the chain will wobble and make things worse.
I have one of those, I like it, but I still prefer to hand file.
2021 Case IH 540 Steieger (A66285)
2021 Case IH 540...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
