etpm
- Joined
- Jun 30, 2021
- Messages
- 2,401
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Reading in another thread about rollovers, and recalling how I almost rolled my 9N over backwards shortly after I bought it made me think some about pulling with my Yanmar YM2310.
When I almost rolled that old Ford over backwards it was because of the way I was pulling and because it was my first tractor. I have learned a lot since then. So, now I'm driving a lighter tractor with more horsepower. It will soon have 320 pounds of wheel weights added. I suspect that the added traction may be a problem when pulling logs if I'm not careful.
I'm thinking that one thing that could increase traction AND keep the front end on the ground would be to turn my drawbar around. This way the connection point to the drawbar would be ahead of the rear axle centerline. Attaching the chain this way would pull the front end down a little and, I think, also transfer more of the pulling force downward, giving the tractor even more traction.
I understand that the angle of the chain would have to be such that the chain would always be slanting downward away from the bottom of the tractor. This won't be a problem. The logs I'm pulling are in places where I can't get the tractor close to, so I usually have 15 or twenty feet of chain stretching between the log and the tractor. I can't lift the end of the log up so sometimes I chainsaw a sort of point on the end of the log so that it won't dig into the ground.
Opinions?
Tbanks,
Eric
Opinions?
Tbanks,
Eric
