What are my options to keep a small section of exposed water line from freezing?
   / What are my options to keep a small section of exposed water line from freezing? #1
JOE G
Gold Member
Eastern NY
Husqvarna / John Deere
Hi, My Shop is fed from my home which is about a 100 FT Run of Black Plastic pipe I believe it's around 1 Inch ID, My issue is when I ran it I was not able to get it under ground easily from where it comes out of my home to where it goes under ground is 5 to 6 Feet, This part of the pipe is under my porch, Is there anything I can do to keep this from freezing? What I have been doing is shutting the water off and blowing the line out for the winter but I would like to have water out there year round., The ground is to rocky and to try and get it under ground would be very difficult. Thanks
P.S How forgiving is this pipe? I have had it freeze a couple times on me when i don't get it off in time.
   / What are my options to keep a small section of exposed water line from freezing? #2
1) Wrap it in a pipe heater (fire risk!)
2) Insulate the heck out of it
3) Insulate the porch area
4) Do what you have been doing
I would do 2, and 3. Insulating the porch areas allows heat to flow out of the ground and house to help keep the area above freezing. Since you don't use much water, the pipe will be more susceptible to freezing than a pipe that is in daily use.
That pipe will tolerate an occasional freeze, but nothing good comes of it. The fittings are less tolerant.
All the best,
Peter
   / What are my options to keep a small section of exposed water line from freezing? #3
Heat Tape and insulate. Heat Tapes need to be on a GFCI circuit.
When blowing out water lines, you never get all the water out so you have been lucky so far.
   / What are my options to keep a small section of exposed water line from freezing? #4
Agree with Doofy. Go to plumbing supply and get a good (cut to length) Heat Tape. Run and tape and insulate according to instructions. Most good heat tapes won't heat until ambient temp is near 32.
   / What are my options to keep a small section of exposed water line from freezing? #5
Just noticed you are pretty far north - NY. Is the line in other places deep enough? When my father-in-law was alive, he owned a car wash. He had a small relay device that opened below 32 that would permit a slow drip on each bay. I don't know if I like that idea, but that is what he did. I think he got them from car wash equipment supplier.
   / What are my options to keep a small section of exposed water line from freezing? #6
A 12" wide piece of 2" styrofoam will go a long way to keep it from freezing.
   / What are my options to keep a small section of exposed water line from freezing? #7
They also make excellent heat tapes that can be run inside the water line providing that both ends are accessible and have no close 90s. These can be ordered with thermostats and or timers and leak-proof fittings.
   / What are my options to keep a small section of exposed water line from freezing? #8
Under a porch? You didn't say how much room you had under there to work, nor how "close to the ground" the water pipe is.
But, 2 inches of blue board foam insulation laid on the ground keeps the ground from freezing here in Vermont. I bet it works in New York as well. The "ground" runs about 55 degrees if you don't let the heat out.
More insulation is always better of course. but laying two sheets 4 X 8 over that water pipe, and then sealing it all over with poly sheeting held tight with soil , or better dry straw. would protect that line. To test it out, just lay a coupe of sheets of insulation out on the ground in some protected place , cover as described and check on it on Feb 28th!
Black plastic pipe is pretty resilient to freezing.
I've got a 80 foot run from the house to the yard hydrant that sits outside my shop. The house end goes into ground in an unheated concrete block "oil shed" and is insulated as described above. Never an issue.
BUT
In late winter, when the frost goes full depth in the soil, the yard hydrant is up against the foundation of the shop. That sub level is unheated and not even closed in (think bank barn)
The line does freeze there, and no water will run. That lasts just about a month or two stating mid Feb.
It's been that way since the late 90s, so I'm thinking I'll keep going with it.
   / What are my options to keep a small section of exposed water line from freezing? #9
This is an excellent resource!
The Line is deep enough every where but the run under porch, I have it attached to the Deck Joist so it is off the ground, It is about 3 ft high in that area which is why i didn't put it in the ground it. I let my compressor run for a while blowing the line out, I am pretty sure I get most of it out, and what ever I don't I believe would settle under the ground.
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
White 5100 / 6900 Planter (A59814)
White 5100 / 6900...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
13042tx (A55973)
13042tx (A55973)
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
