Noob Here...Seeking a Tractor Education, Please
/ Noob Here...Seeking a Tractor Education, Please #1
kailor
None
I'm new here and have been reading the forum now for several weeks trying to prepare myself to make a knowledgeable tractor purchase in the future. I've never owned or driven a tractor before, but I now have land (10 acres). Something I've not been able to discern across all brands is this...what features are essential in making sure that I'm comparing apples to apples across different brands? Without initially comparing dealers and parts availability, but machine to machine, I think they might be:
1. Weight
2. HP at PTO
3. ?
Being in north Alabama, I've access to most any brand. All inputs/thoughts are appreciated. Thanks for having me!
/ Noob Here...Seeking a Tractor Education, Please #2
I went to Tractor College
It's free on youtube.
Start with the Goodworks Tractors site, he's got Tons of great material including how to not kill yourself or destroy your tractor.
From there you can expand
Everything Attachments does a lot of instructional stuff
There is Tractor Mike He was a dealer and a rep so he knows a lot.
Dave Knows How
My Wild Kiotoi Adventure
Tractor Time with Tim
My Cluttered Garage
Tony's Tractor Adventure Homestead
That'll keep ya busy
/ Noob Here...Seeking a Tractor Education, Please #3
As a noob....get out and drive some tractors...new and used. You want to buy one that you are comfortable operating. Only you can get a feel for what is right for YOU.
/ Noob Here...Seeking a Tractor Education, Please #4
Get to know your neighbors. They probably will have good advice on how to move forward.
I suggest renting for specific task to get some seat time and learn works well for your property.
The biggest thing is learn to respect the equipment. You have to pay attention to a lot of things when operating. It is not like driving a car where the rules are laid out before you. Things can go south quickly so start slow and work your way up to different tasks.
/ Noob Here...Seeking a Tractor Education, Please #6
Yep. Its more important to define your expected future work on that 10acres, so you can define your specific tractor needs. Are you just mowing? Or have a gravel road to maintain? Do you expect using a snowblower in winter? If your lot is wooded, any need for a PTO chipper? Will you be needing a tiller for garden preparation? How much loader work to you expect, and project weight of those loads.
/ Noob Here...Seeking a Tractor Education, Please #7
I agree with defining what you want to do with your tractor and implements you will be using first. Then determine the frame size that will do your tasks optimally. I am guessing a 35hp mid frame tractor about the size of a John Deere 3039R or 3032E (or same size Kioti, Kubota or LS) would do the trick. Go to a few dealers and do some test drives to get the feel of things - If you can find any dealers who have tractors in stock!
/ Noob Here...Seeking a Tractor Education, Please #8
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor capability is more closely correlated to tractor weight than any other specification.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
Bare tractor weight is a fundamental tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used. Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range.
I spreadsheet tractor and implement specs, often a revealing exercise which cuts through specification clutter. I have a column for cost per pound.
Neophyte tractor operators are often intimidated by instability of tractors with small front wheels and large rear wheels, therefore frequently purchase tractors too light, too small for long term satisfaction. ((Tractors seem to shrink after about twenty hours of operating experience.)) Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is worse than depreciation on a tractor.
BUY ENOUGH TRACTOR​
/ Noob Here...Seeking a Tractor Education, Please #9
I have 10 acres in North Alabama.
If your ten acres is fairly flat and level I recommend a tractor of 2,500 to 2,800 pounds bare tractor weight.
Tractors are inherently unstable operating on sloped ground. Tractor rear wheel/tire spread, sometimes adjustable, is a critical factor increasing compact tractor stability working sloped or uneven ground. A 4" to 8" wider rear axle substantially decreases tractor rollover potential.
If your ten acres is sloped or uneven I recommend a tractor of 3,600 pounds to 4,000 pounds bare tractor weight. This is the mid-weight category of compact tractors, a high volume segment. Every tractor manufacturer produces an economy model and a deluxe model in this weight range. Horsepower options range from 35-horsepower to 60-horsepower in this weight range.
When considering a tractor purchase, bare tractor weight first, tractor horsepower second, rear axle width/rear tire spread third, rear wheel ballast fourth. Ample tractor horsepower is needed for PTO-powered implements such as Bush Hogs and snow blowers, but remains subsidiary to tractor weight in defining tractor capability.
/ Noob Here...Seeking a Tractor Education, Please #10
First identify why you want a tractor.
Gardening? Tiller? Driveway maintenance? Backhoe work? Lawn mowing? Firewood? etc etc.
Once you have identified the tasks.....decide what size attachments you want for those tasks. Then you can select an appropriate sized machine to handle those tasks and implement sizes.
Be prepared for some compromises along the way. Driveway maintenance and backhoe/loader work....the heavier and bigger the better. But heavier and bigger is not really a good thing for lawnmowing and gardening.
Its okay to compare HP.....but you must FIRST compare the tractors frame size...which is closely related to a tractors weight.
You can find ~35hp tractors ranging from under 2000 pounds to over 4000 pounds. So if you ONLY use HP as a basis for comparing.....you may be looking at a 1800# machine that can only lift 800# on the front loader and trying to compare it to a 4000 pound machine that can lift a 2500# and is physically ALOT bigger. Both will have the same/similar HP. Obviously that isnt a good comparison.
Once you have a good idea of what "physical" size machine you want...go to the dealers in your area and sit on some. How the tractor "fits YOU" and its ergonomic layout is far more important than comparing paper specs. Because at the end of the day....tractors are tractors and if you are comparing similar sized machines....there is very little real world difference in their capabilities.
/ Noob Here...Seeking a Tractor Education, Please #11
Also consider your health and protects maybe in the future.
/ Noob Here...Seeking a Tractor Education, Please #12
Kubota 'Grand L' L3560 VIDEOS:
/ Noob Here...Seeking a Tractor Education, Please #13
Tractors are great fun...(I've owned JD 3, 4 and now 5 series) but you should determine what you're going to use it for. If you just want to mow, with 10 acers (or less), a large Zero Turn will out mow any tractor faster, cheaper and with less fuss...especially on hills. In addition, you'll struggle with the just the right tires for your tractor. If you hate getting stuck in the mud or want to do field work, aggressive tractor tires are a must...but they will tear up your lawn. If you're going to use a tractor for work other then mowing...that'd be a better investment. If you can afford it...get both.
  • Good Post
Reactions: mo1
/ Noob Here...Seeking a Tractor Education, Please #14
Also deem the need for ROPS (open station) or cab, factor in weather vs your own health. Woods/no woods......cab tractors need to be more aware of tight spots and woods. But they do shield you from elements hot colt or driving over a yellow jackets nest while working the soil.
/ Noob Here...Seeking a Tractor Education, Please #15
Weight,
horsepower,
hydraulic capacity (lift capacity of FEL and 3 point hitch),
3 point hitch “size” -Class 0, 1, or 2, etc.. Attachments have to be able to …well…. attach. There is some overlap and adjustments. Larger tractors can usually fit smaller attachments, vice-versa may be case-by-case.
Number of (rear) hydraulic ports (i.e. SCV’s - selective control valves) where you plug in hydraulic hoses for rear attachments. These are different than where hoses of FEL plug in. Number you want depends on what equipment you want. Each single valve has two ports (think of it as 1-in, 1-out) for plugging in 2 hoses that would go to a 1 hydraulic cylinder on the attachment.
Operation of PTO: Is PTO electrically controlled by a switch (that slams PTO on) or an independent lever that you can manually “clutch.”? Or part of the clutch pedal operation?
Block heater for cold weather.
Above where the big ticket items (for me).
Then there’s hundreds of the nitty gritty, and “comfort” issues. Like :
Cab or no cab.
Extendable lift arms on the 3 point hitch for connecting attachments more easily.
Many many more…
/ Noob Here...Seeking a Tractor Education, Please #16
Before you decide on the features you want, better do a site review of your property and want work you want done with the tractor. Only then can you decide best features. And only after that, can you decide on what brand you need. WELCOME TO TBN. GLAD YOU ARE HERE.
/ Noob Here...Seeking a Tractor Education, Please #17
Kailor, how about giving us a response to all the comments listed so far? We can't help you if you don't give us more information.
Thanks for all of the responses thus far. I have a 61" Ferris for mowing. Land is flat-to-very-small-inclines.
Usages, in no particular order, would include:
Spreading gravel
Digging post holes
Digging trenches for water lines and electrical runs
Clearing an acre of small trees...< 10" diameter...and moving the felled trees
Tilling soil for garden...approximately 1 acre or a little less
/ Noob Here...Seeking a Tractor Education, Please #19
Backhoe for trenching and stump removal?
/ Noob Here...Seeking a Tractor Education, Please #20
Spreading gravel
Digging post holes
Except for excavating 10" diameter trees, a 2,500 to 2,800 pound bare weight tractor with <25-horsepower will be ample. For the trees, rent a mini-excavator for a weekend which will take out trees, roots and all. The mini-excavator can do your trenching during the same weekend.
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61569)
2018 Freightliner...
832723 (A61166)
832723 (A61166)
Pallet of Fork and Frame Mini Skid Steer Attachment (A61567)
Pallet of Fork and...
large capacity skid steer bucket (A56857)
large capacity...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
