2006 310SG Backhoe Controls - 4 stick
   / 2006 310SG Backhoe Controls - 4 stick #1
Kwi-Chang
Bought a 2006 JD 310 SG with 4 stick controls on the backhoe. Used to using 2 stick standard control and not having much luck learning the 4 stick control.
Could there be a hydraulic issue causing the 4 stick to act inconsistently?
Also has anyone changed a 4 stick control to a 2 stick?
Thanks
   / 2006 310SG Backhoe Controls - 4 stick #2
Kwi-Chang
Welcome to TBN
Others may be along to answer your questions, but a photo or two with labels may also help get some response.
Sorry, I cannot help.
Kwi-Chang
Welcome to TBN
The owners manual doesn’t even mention a 4 stick control so…?
   / 2006 310SG Backhoe Controls - 4 stick #5
You should be able to put a set of wobble sticks on it. You’ll also have to change some hoses around to make the pattern right when you’re done.
   / 2006 310SG Backhoe Controls - 4 stick #6
Browsed around in JD parts and this link may help.. shows the 4 stick as well as other combinations of sticks, more and less.
May give you a lead on changing to a two stick control.
Indicates a two-stick conversion kit
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
402 (A52706)
402 (A52706)
2007 Ford E350 (A55973)
2007 Ford E350...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
