2006 310SG Backhoe Controls - 4 stick
   / 2006 310SG Backhoe Controls - 4 stick #1
Kwi-Chang
Bought a 2006 JD 310 SG with 4 stick controls on the backhoe. Used to using 2 stick standard control and not having much luck learning the 4 stick control.
Could there be a hydraulic issue causing the 4 stick to act inconsistently?
Also has anyone changed a 4 stick control to a 2 stick?
Thanks
   / 2006 310SG Backhoe Controls - 4 stick #2
Kwi-Chang
Welcome to TBN
Others may be along to answer your questions, but a photo or two with labels may also help get some response.
Sorry, I cannot help.
Kwi-Chang
Welcome to TBN
The owners manual doesn’t even mention a 4 stick control so…?
   / 2006 310SG Backhoe Controls - 4 stick #5
You should be able to put a set of wobble sticks on it. You’ll also have to change some hoses around to make the pattern right when you’re done.
   / 2006 310SG Backhoe Controls - 4 stick #6
Browsed around in JD parts and this link may help.. shows the 4 stick as well as other combinations of sticks, more and less.
May give you a lead on changing to a two stick control.
Indicates a two-stick conversion kit
2006 CATERPILLAR 304C (A58216)
2006 CATERPILLAR...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
2006 FREIGHTLINER CST120 (A58214)
2006 FREIGHTLINER...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
LOT: (1) Craftsman Shop Vac, (1) Dewalt Shop Vac (A59076)
LOT: (1) Craftsman...
