Buying Advice Looking for a tractor
/ Looking for a tractor #21
Don’t think so as he put 40 acres in both his profile as well as in the post. That would be 2 fat finger mistakes.
But - no doubt really meaning to mow 40 acres a week is crazy talk.
MoKelly
I certainly thought the same as you, he wants to mow the same 40 acres each week. But then knowing how some people often don't provide enough details, the OP could be referring to a mowing goal of 40 acres per week, and mowing a total 160 acres (quarter section) every month.
/ Looking for a tractor #22
MoKelly
Depends... if it is his 40 acres and he wants to mow it every week, that is crazy.
If it is his employer's 40 acres and he gets paid by the hour, it is genius.
I could see where Jeff's mowing calculator would come in real handy! :unsure:
/ Looking for a tractor #23
Jeff, l don’t agree with your price for a 70 HP tractor at 70,000 unless you are talking about new. I bought a JD 5425, 81 HP tractor, cab, loader for $39900 about 3 months age with 1954 hours.
/ Looking for a tractor #24
My $70,000 includes the 144" mower.
You are in Arkansas, like Florida a low cost state for compact tractors.
So far, the OP's location is unknown.
Good strike. Others may not share your good fortune.
/ Looking for a tractor #25
Hope the OP is OK. But evidently has not seen any of the great replies to his post.
/ Looking for a tractor #26
Yeah, a couple others thought this seemed a bit fishy. It is also possible that he went ahead and bought what he was already thinking of buying when he posted to ask for recommendations. Wouldn't be the first that happened. 😁
Maybe he's just been busy and will come back.
/ Looking for a tractor #27
mow 40 acres??? I dont know that I would bother with that, reseed into hay field, or let a farmer rent your field and do the work. If you reseed into hay field you could sell the crop...
/ Looking for a tractor #28
Everyone's assuming agricultural land. Could it be playing fields, parkland, airport or something where the grass needs to be kept short?
/ Looking for a tractor #29
Looking for a good used tractor to mow 40 acres once a week. I'm new to tractors so help help help. I hear I need a diesel, four wheel drive front end loader and mower. I don't need something that is going to break down and I also need a tractor 101 education so I can care for it properly, operate it safely, etc.
Depending on your location, look for a local farmer/rancher to lease it and grow crops, make hay, or run cattle. The cost of fencing it could be a lot less than buying a tractor. You may also be able to get a farm deferral on property taxes. I've turned some of my acreage into hay pasture and a local family comes and cuts it, bales it, takes the hay in return for the work. None of my time spent cutting it.
/ Looking for a tractor #30
Oh my, I agree with Deezler. Mowing 40 acres once a week means a REALLY big mower, or you're going to spend your whole weekend mowing.
1) you'll want a tow-behind mower for that size if you don't want to spend the entire weekend doing it.
2) do you really need a loader for it? That's going to up your expense quite a lot. A quality used tractor that can tow a mower AND do loader work is likely to be much more expensive than a tractor that just has to tow (old-style farming tractor). Your tow behind mower is going to run thousands by itself ($10k plus depending upon size and used vs new)
3) I'd consider getting a flail mower or batwing for that kind of job.
A woods BW12 will run you $12k+.
4) spec out your mower first, that'll tell you how much of a tractor you need.
If you're mowing once every couple months, you might opt for a smaller, less expensive mower and just taking longer to mow, so you can get a smaller less expensive tractor, since you aren't worried about consuming the whole weekend.
/ Looking for a tractor #31
Good info but one thing beckons....in the case of it being "playing fields, parkland, airport or something where the grass needs to be kept short" they would have maintenance crews where all this mowing would not fall on just one person....
/ Looking for a tractor #32
If you have 40 acres to mow.... why on earth would you do it every single week? Most people only mow that many acres 3-5 times per year.
Great question. I am wondering if this is a large area mowed like a lawn or lawn quality? Being a very inexperienced non-tractor-so-far guy the OP may just not know how often to mow it and 'weekly' may have been a wild guess.
/ Looking for a tractor #33
Rather than a tractor you might want to consider a commercial zero-turn with a 90+ inch deck. The initial purchase would be cheaper as would the operating costs. You can find some that have cabs and AC but those are costly. You also have less maintenance needed on a zero turn unless the back 40 was used as a bombing zone.
/ Looking for a tractor #35
Most municipalities would outsource that sort of job to a contracting company that would ALREADY have the equipment and people who know what they're doing.
I've seen suburbanites move out into the country with very large properties, and expect a nice neat lawn. That usually doesn't last long. I been one kinda of the lazy type ;-) My property is 10 acres, about 6 wooded. That didn't last long - we planted trees (over 1500!), and left other areas to overgrow, and reduced the mowable area to about 1/2 acre. Takes me 2-3 hours with a 43" deck garden tractor. Most of it is the road allowance outside the (no longer existing) fence line. It's not just easier, it encourages wild-life - we seem to have become the local deer birthing centre.
/ Looking for a tractor #36
Yeah, but how in H does that kind of thing get dumped on a guy who knows nothing of tractors and is new to the entirety of the technology? I'm waiting for his clarification.
/ Looking for a tractor #37
For a data point:
I mow an 11 acre runway (4800' x ~100') that has runway lights on about 3000 feet of the length. I use a 45 HP 2WD Kubota tractor & 7' finish mower, mowing in high 3rd gear. It takes about 2 & 3/4 hrs to mow, including using a zero turn mower to mow around the runway lights. Obviously, it's straight, level, and no obstacles except the lights.
I don't understand the need for a loader & 4WD, if all you're going to do is mow. Plenty of uses for both, but they don't involve mowing. In fact, the loader would be a big disadvantage while mowing, in my opinion.
/ Looking for a tractor #38
I do not see a single post since the first from the OP. Until he clarifies his circumstance all 34 posts above are wasted and mostly irrelevant. Mine included.
He just started the thread day before yesterday... do we all have so little to do that we jump in with over 30 posts before the OP ever clarifies?
/ Looking for a tractor #39
If you're just mowing 40 acres a week, do you really need a front end loader? And what is the terrain like? Do you need four wheel drive?
/ Looking for a tractor #40
I have a 2004 80 hp Tn80F that can do that. I also can rarely use it due to needed repairs (can not get it in my garage for self repair/maintenance). If you are buying used the most critical factor is cab height (too big and you can not get it in your shed/garage) and weight (too heavy and its difficult to tow it yourself to the dealer). Buy the lowest overall height, lightest machine that will handle a decent size batwing. I intend to trade my TN80f for a low (under 76"), light machine setup to add extra weights.
2022 SANY SY5OU EXCAVATOR (A63276)
2022 SANY SY5OU...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2014 Toyota Tacoma Ranch Camper Shell (A64126)
2014 Toyota Tacoma...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
2015 Timpte 40' Hopper Bottom Trailer (A64127)
2015 Timpte 40'...
2000 International 4900 Tandem Truck (A66285)
2000 International...
