Buying Advice Looking for a tractor
/ Looking for a tractor #1
Chevalia
Looking for one to mow 40 acres once a week
Looking for a good used tractor to mow 40 acres once a week. I'm new to tractors so help help help. I hear I need a diesel, four wheel drive front end loader and mower. I don't need something that is going to break down and I also need a tractor 101 education so I can care for it properly, operate it safely, etc.
/ Looking for a tractor #3
How long do want it to take to mow? Are you using the tractor for anything else at all?
/ Looking for a tractor #4
As soon as you say "USED" the whole buying program changes,,
With used,, you gotta find what is available within transport distance of you,,
If you are in California,, I could offer you my tractor for $10,, but, it would be overpriced, because of what it would cost to move.
So,, more details, Where are you located? and what is available local to you,,,??
/ Looking for a tractor #5
Welcome to TBN.
Need lot more info.
Type transmisson,horse power,type mower,future plans etc. etc.
Lots good info on TBN over the years..try search.
/ Looking for a tractor #6
To mow 40 acres every week you will need a big enough tractor to handle a 15 ft batwing mower, But as others have said there are many more variables that will come into play. More info needed.
/ Looking for a tractor #7
Looking for a good used tractor to mow 40 acres once a week. I also need a tractor 101 education so I can care for it properly, operate it safely, etc.
Here is a basic mowing calculator. If your ground is flat and level you probably can mow at 5-mph. If you have hills, have to mow around trees or the ground is rough, viz pasture, your average speed will be more akin to 3-mph.
A 144" wide mower will cut about 6-1/2 acres per hour @ 5-mph. So 40 acres will take at least 6-1/2 to seven hours with breaks and fueling. I would not mow a full day without a cabbed tractor, which adds $8,000 to open station tractor price and 800 pounds to open station tractor weight. Too much heat, too many bee stings, too much pollen and too much mold, mowing with an open station tractor.
Operating a 144" mower with a cabbed tractor featuring A/C requires minimum 70 net tractor horsepower.
This is the heaviest subset of compact tractors. With this rig you could mow quarterly, rather than weekly, if desired.
'Previously owned' you are looking at $60,000 for a 70-horsepower, 4-WD, cabbed tractor and rotary cutter. Tractor prices vary 20% by USA region.
For almost everything else a tractor does tractor weight is the primary consideration. For mowing, where you have to power the tractor and a particularly power hungry implement, tractor power is the primary consideration.
A 70-horsepower tractor will have a bare weight of 5,500 pounds. Most consider this weight just adequate for general farm work on forty acres.
Bare tractor weight is a fundamental tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used. Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range.
BUY ENOUGH TRACTOR!​
/ Looking for a tractor #9
Where?
40 acres in the northern plains grows a lot slower than 40 acres in Florida.
Is it flat?
What type of grass?
Is it a 40 acre golf course?
Lot's more info needed.
  • Good Post
Reactions: JWR
/ Looking for a tractor #10
If you have 40 acres to mow.... why on earth would you do it every single week? Most people only mow that many acres 3-5 times per year.
/ Looking for a tractor #12
Inform us of where you are. Tractor prices vary 20% by USA region.
Inform us of the nature of your land, how open your land is, how smooth/rough/hilled.....
/ Looking for a tractor #13
Hmmm.....40 acres every week is roughly half an average work week doing nothing but mowing grass. And that's just time in the seat. Doesn't include anything else.
With that level of tractor use, there is a strong bet that you will be spending another half a day per week just keeping the equipment in shape & going...maybe more depending on how used the machinery is.
A lot of used equipment is sold just because the maintenance is taking up too much time.
Are you sure that mowing grass is what you want to do with half your working hours?
I wonder what other alternatives there are?
/ Looking for a tractor #15
Dont you guys think such a post is a little odd?
Mow 40 acres?
Need tractor 101?
New guy?
/ Looking for a tractor #16
Honestly, mowing 40 acres a week is within capability of tractors from 26hp to 110hp. No budget was indicated or any details regarding mowing terrain, location or type grass.
/ Looking for a tractor #18
Mow 40 acres?
Need tractor 101?
New guy?
It is an odd post. His profile is blank.
But the OP has already recieved good advice regarding additional information from his next post.
/ Looking for a tractor #19
I hope it is not another klutz who taps in 40 but means 4.
/ Looking for a tractor #20
Don’t think so as he put 40 acres in both his profile as well as in the post. That would be 2 fat finger mistakes.
But - no doubt really meaning to mow 40 acres a week is crazy talk.
MoKelly
