YM226D Project
/ YM226D Project
She's mine! Just finished up sorting and organizing everything. Got the old tractor and parts buttoned up and put to the side and laid out all of the new tractor parts and pieces. Everything looks awesome so far and the new tractor is extremely clean and rust free. I have all the old parts as well as the new, which I appreciate so that I can understand where the previous owner left off and why they did what they did. I'll get some pictures/videos up this week. I'm excited to continue this project!
/ YM226D Project
Here's a bunch of pictures to show how I picked it up and some of the initial discoveries:
Head:
Two of the old pistons that were damaged due to starting fluid:
Old bearings:
/ YM226D Project
One thing I have some questions on is the injector pump. My original YM226d had a 721550-51700 T86 injector pump. This new tractor came with two injector pumps, one is a 721550-51700 that is completely disassembled and stored in plastic bags, the other is a 3T72SA injector pump and is currently installed in the tractor. From what I have found online, the 721550-51700 looks to be correct, but are these pumps interchangeable? Without knowing any better, my gut reaction is to take the pump out of my old tractor and use it on this one. This seems like the most efficient path forward because I don't have to assemble the new pump and I am fairly confident it's the correct pump for the tractor.
With that said, I pulled the 721550-51700 out of the old tractor and noticed some small scratches. Is this a problem?
/ YM226D Project #84
Not sure about the scratches being a problem or not.
I do know that the 'same' engine in various Yanmar models use different fuel pumps to achieve higher or lower engine Hp. If you knew the fuel pumps flow rate, of the unknown pump, you could determine if a 1Hp to 3Hp gain could be had.
The 3T72SA fuel pump came off of a YM1510 or a YM1502. The engine piston diameter is just 3mm [1/8in-ish] difference. It could flow very much the same.
Glad you have both machines under one roof.
/ YM226D Project
Thanks Bmaverick!
I did some more digging now knowing the 3t72sa came from the YM1502 or YM1510. It appears that several OEM numbers were used originally but if you were to replace the injection pump today, several of them cross reference to the same IP-375 pump.
Between the Hoye site and Southern Global I am finding IP-375 replaces OEM #’s 721550-51700, 721461-51700, 721454-51700, and 721520-51700. This corresponds to tractor models YM187, 220, 226, 250, 1301, 1401, 1502, 1510, 1601, 1610, 1702, 1800, 1802, 1810, 2000, 2001, 2002, 2010, 2020, 2202, 2220, 2240, 2301, 2310, 2402, 2420, and JD750.
Since the 1502/1510 and the 226 cross reference to the same IP-375, it makes sense why this 3t72sa pump was used and I believe is correct.
/ YM226D Project #86
Thanks Bmaverick!
I see a few of the 3-digit models that were never US imports. That YM250 was a UK import.
/ YM226D Project
Took the valves apart today and cleaned them up. A friend told me to use a dry erase marker and color on the sealing face of the valve. Then, put the valve in, twist it 90 degrees, remove it and verify that the dry erase marker was cleaned off 360 degrees around. All the valves passed this test and look to be in good shape.
Opened up the new pistons and rings and started getting things together. I took the cylinder liners out, and put each ring into the liner it will be installed in and verified the gap was correct. A couple needed to be opened up a few thousandths. I installed the pistons onto the connecting rods and am waiting for my ring spreader to arrive before putting the rings on the pistons.
Once I get the rings on I think I'm ready to put the new bearings in place and install everything back into the block. I'll put the oil pan back on with a new gasket and install the head with a new head gasket and see where I'm at.
/ YM226D Project #88
When you say, "few thousandths", due note, your machine is 100% METRIC. So, use Metric first and then covert back.
/ YM226D Project
Thanks Bmaverick, I double checked and the specs from the manual I was referencing are provided in inches. The new tractor also came with an original service manual (not a reprint) and it is night and day better than my reprinted one. All of the pictures are crisp and no sections are missing or incomplete.
/ YM226D Project
Big night tonight. I installed the pistons with new bearings and rings, got the oil pan back on, new oil filter, new head gasket and installed the head. Everything went super smooth up to this point - I used a bunch of assembly lube and triple checked torque specs before closing things up.
After torqueing the eight head bolts and 3 head assist bolts down I put the pushrods and valve wear tappets back in place and dropped the rocker arm shaft assembly on. The final step to secure everything was to tighten the rocker shaft assembly down using the brass looking nuts on the three stepped studs. I screwed the studs into place by hand and went to secure the nuts following the 40 ft lbs spec from the manual and ran into problems. The nuts started to snug down and then started spinning. The nuts appear to be stripping out on the studs and when I went to remove the nuts the entire stud came out instead. The nuts are now stuck on the studs and I can tell the nut or stud is stripped. Any thoughts on what went wrong?
I'm glad it's just the studs/nuts because that is easy enough to replace (I also have a spare set from the other tractor) but I'm not convinced if I were to try it again I would get different results. Is the 40 ft lb spec wrong? Is there a special technique that is required and I don't know about it?
/ YM226D Project #92
The closest Service Manual I have is the YM169 of the 3T72 engine, It's close to your 3T75.
So, those rod bolts are near Winston's value (27) coming in at 20.2 ft-lbs.
You would need the Service Manual of
/ YM226D Project
Well that's dumb. I was following along on page 13. Thank you Winston, at least it's an easy fix moving forward.
BMaverick, I think in your manual the part I'm referencing is the rocker arm support at 45-52 ft lbs, no?
/ YM226D Project
Went with the 27 ft lb spec and got the rocker shaft assembly secured. Went ahead and adjusted the valves, they were extremely loose and I almost made another big mistake. Similarly to the 40 ft lbs vs 27 ft lbs, the valve adjustment in the manual had a typo and said .080” instead of .008”. I thought it seemed off and sure enough on another page in the manual the correct spec of .008” was listed (also confirmed by the sticker on the valve cover).
Installed a new belt and hooked up all the radiator lines. Added coolant and noticed a small leak along the new head gasket and a small leak at the bottom of the radiator. The leak at the head gasket has me confused. I did some searching online and people suggested retorqueing the head bolts after running the tractor for a bit. The leak is extremely small, and I’m wondering if it just needs to set properly after being run/heated for a few minutes. It’s definitely coming from between the block and head and not running down the side from somewhere else. Not sure where the leak at the bottom of the radiator is coming from yet. That one is a drop every 5-10 minutes or so.
/ YM226D Project #95
... Similarly to the 40 ft lbs vs 27 ft lbs, the valve adjustment in the manual had a typo and said .080” instead of .008”. I thought it seemed off and sure enough on another page in the manual the correct spec of .008” was listed (also confirmed by the sticker on the valve cover).
rScotty over the years pointed out this problem with many of the manuals. Yanmar issued Tech Service Bulletins to correct these problems. The big trouble is, the people selling the manuals today don't give you the those TSBs to cover the discrepancies. So, doing all that work can and could get messed up badly.
It's a shamed that those TSBs for the YM Series are not made public anymore. How are people ever going to know ???
/ YM226D Project
It’s surprising how many mistakes there are to begin with. It’s forced me to slow down and try to really understand what I am mechanically about to do instead of blindly following directions. Can’t say that’s a bad thing.
Tightened up a lower radiator hose and stopped the slow drip leak from the bottom of the radiator for now. If it starts up again I’ll get new hoses or swap out radiators. Still signs of coolant ever so slightly seeping out between the head gasket.
When I started tackling the second tractor I separated everything into old tractor parts and new tractor parts so nothing got mixed. As I re-assembled the new tractor I referenced the old stuff and slowly worked through the piles of bolts, nuts, and parts that came in a box to determine where everything belongs. I am now down to about 3 bolts, 2 washers and a nut that I am unsure of where they belong. I have a new valve cover gasket, exhaust gasket, and air intake gasket due in tomorrow - at which point I should be able to complete the assembly. I will then spend a decent amount of time attempting to figure out a use for the extra parts. Today I flipped through the entire manual looking at the diagrams and trying to pin point where they go without much luck. I will post pictures of anything I can’t figure out in case someone has an idea.
/ YM226D Project
Parts are delayed, not sure what the deal is but they haven’t arrived yet. I have a few “spare” parts. Does anyone have any thoughts on where these items would go? It’s also very possible they have nothing to do with my tractor and just fell into a box while sitting in the previous owners garage.
/ YM226D Project
I suspect you're going to get some wise-ass answers to that post! :)
Better than nothing 😆. Worst case they stay in a box to the side and we see what happens
/ YM226D Project #100
Ok, full confession, reassembly with leftover parts is a recurring nightmare of mine.
I'd love to tell you that is an old style nylon Kimura seal backer for the main engine seal just to see the expression on your face, but the reality is I have no clue.
All the best,
Peter
2011 GMC SIERRA 2500HD (A67714)
2011 GMC SIERRA...
2024 CATERPILLAR 279D3 SKID STEER (A65056)
2024 CATERPILLAR...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65053)
2013 VOLVO A40F...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2021 CATERPILLAR 316FL EXCAVATOR (A65056)
2021 CATERPILLAR...
