YM226D Project
/ YM226D Project #1
tc197
Bronze Member
YM226D
Hi, I've been reading and observing for a few weeks now collecting information as I go. Thanks for the help so far. I have a YM226D with a front loader that I recently inherited that I am working on getting running. It's been sitting outside under a deck for the last 5-10 years untouched until it was given to me by some family. I have a couple issues I am working through and was hoping to get some advice before I start tearing things apart.
So far I've drained and replaced the diesel, changed the fuel filter and bled the lines according to the Hoye site, changed the engine oil and filter, replaced the thermostart glow plug, and spliced in a lower radiator block heater. I have a fresh battery and have been somewhat successful in getting the tractor to start. The colder it is, the harder it is to start and the other day when it was about 20 out even the radiator hose heater wasn't getting it done. I am following the recommended starting procedure with the throttle all the way forward, using the thermostart for 30 seconds two times, pulling the decompression lever and cranking and releasing. once I can get the tractor started I have three main issues.
1. The tractor is leaking engine oil. I have a consistent drip when running that is coming from the weep hole in the bottom of the bell housing. It is not hydraulic oil. Based on my research I believe this would indicate a rear main seal issue but was looking for any other possibilities before I go down that road. It's probably a drip every second or two and not something that I would run as is.
2. Despite all of the posts about Yammer-Hammering I think I have extra noise and it does not sound smooth to me, especially at lower RPM's. I hear inconsistent knocking and not just a smooth diesel rumble like my fathers BX series Kubota.
3. Possibly linked somehow to number 2, I have weird surges and control issues with the RPM's. It will respond to the throttle but not in a consistent manner. If I try to set the tractor at any RPM, within a few seconds it is either dropping in RPM's and stalling or surging and heading to redline. All of my throttle control is over an inch or two of travel and requires constant babying to stay away from redline but not stalling. I have adjusted the throttle friction nut so it is not the throttle sliding up and down. If I hold the throttle in one position I still get the increase or decrease of RPM's. I get some white smoke when cranking and starting but once it is running the smoke goes away. I will get some black smoke if I throttle the RPM's up but only for a second. Any thoughts on what might cause this?
Thanks in advance for any input and I look forward to getting these issues sorted out!
/ YM226D Project #2
Welcome to the forum! There are many many folks on here that are great resources here. I am sure you will get lots of help.
My opinion but typically we do not talk about a redline RPM’s on our tractors. You probably need to explain what you mean in more detail. As a side note, Tractordata.com list your working RPM at 2600 (this would generate 540 PTO RPM in PTO speed 1, if multiple speeds)
Your smoke description sounds pretty normal based upon what you say. Also when using the tractor when a heavy load (PTO or ground engaging) expect some black smoke. Probably more than a brief puff.
The rough running sounds like an issue that needs to be corrected. It is difficult to advise you without hearing the sounds. It could be as simple as a poorly performing injector due to sitting and a gumming effect. A good diesel additive/injector cleaner may correct this over time. If you do not wish to wait (understandable) use an additive conditioner for fuel anyway (diesel in 2020’s is very different than diesel in 1980’s). If you want to be proactive on the knocking, one at a time verify that fuel is getting to each injector by loosing each metal line at the injector. If fuel is getting to each injector, plan to pull the injectors and clean them. There are videos of how to clean them on Youtube. And yes a surging is probably related to a poor fuel delivery issue.
As for the oil leak, you will have to split the tractor to replace the rear seal. If the oil getting into the Bell Housing is sufficient to coat the clutch, you run the risk of other damage to other components.
I would be concerned about the amount of oil inside the Bell Housing as well as how much drips out over a period of time. I suggest you get a paint mixing container that has marked measurements on it. Run the tractor for a set period of time (measure) then collect the dripping oil over an extended period (ie 1day). This gives a good feel for exactly how much oil you are loosing. It is possible that the seal may have dried out and loose less as it runs longer. But at 40 yrs old don’t count on it.
A couple of other areas you want to address.
1) change the hydraulic/transmission fluid and. Clean the screen. All of these tractors have a tendency to allow water to seep into the reservoir. Only way to avoid is to store them out of weather.
2) same water issue but in the steering box. Water runs down the steering column and collects in the steering box. Since oil is lighter than water, the oil floods out.
/ YM226D Project
My opinion but typically we do not talk about a redline RPM痴 on our tractors. You probably need to explain what you mean in more detail. As a side note, Tractordata.com list your working RPM at 2600 (this would generate 540 PTO RPM in PTO speed 1, if multiple speeds)
The rough running sounds like an issue that needs to be corrected. It is difficult to advise you without hearing the sounds. It could be as simple as a poorly performing injector due to sitting and a gumming effect. A good diesel additive/injector cleaner may correct this over time. If you do not wish to wait (understandable) use an additive conditioner for fuel anyway (diesel in 2020痴 is very different than diesel in 1980痴). If you want to be proactive on the knocking, one at a time verify that fuel is getting to each injector by loosing each metal line at the injector. If fuel is getting to each injector, plan to pull the injectors and clean them. There are videos of how to clean them on Youtube. And yes a surging is probably related to a poor fuel delivery issue.
I would be concerned about the amount of oil inside the Bell Housing as well as how much drips out over a period of time. I suggest you get a paint mixing container that has marked measurements on it. Run the tractor for a set period of time (measure) then collect the dripping oil over an extended period (ie 1day). This gives a good feel for exactly how much oil you are loosing. It is possible that the seal may have dried out and loose less as it runs longer. But at 40 yrs old don稚 count on it.
Thanks for quick and well detailed response!
I believe my understanding of redline was incorrect for this tractor. On my gage I have a red line at just past the 2500 rpm mark. I see now that this most likely indicates the working rpm's of 2600 as you pointed out. The gage max is 3000 rpm. I was getting nervous watching the rpm's surge to 2600+ thinking I was "redlining" the tractor. Is it possible for these diesels to overrun and do damage or is that not something I need to worry about?
I did add a diesel injector cleaner as well as an anti-gel due to the cold weather just the other day. This is my first time working with diesel so I was surprised to learn that gelling is an issue. My biggest concern with the knock was doing extra damage for running it longer. I will verify fuel delivery at the injectors and start there. As an additional thought - a lot of the soft fuel lines are past their prime and I'm tempted to replace them. Is there a recommended process to avoid sucking a bunch of air into the system? After seeing how detailed you need to be when changing the fuel filter I can only imagine the troubles that could arise if I load the lines with air.
Great idea with the oil vs time measurements, I will do this as well. My plan right now is to try to fix any issues I know of before splitting the tractor if it ends up needing to go that way. This way, when I put it back together, I know anything not working properly is directly related to my rear main seal fix.
I will change the hydraulic fluid. I held off on this initially because it looked clean, at the proper level, and the front loader has motion. I already have the new filter but had just prioritized some of the other issues ahead of this.
Good to know about the steering box. I will have to do some research on this.
/ YM226D Project #4
My yanmar is a grey where yours was USA build, but my understanding is most if not all the USA models have a grey counterpart model or one very similar at least.
Gelling of diesel is an issue has there are different numbers of diesel (#1 & #2). Basically that is warm weather and cold weather fuel. Because of the age of my model (only built in ‘82 & ‘83) I use a conditioning additive with every tankful of fuel. The additives I use for conditioning contain an anti-gelling additive so win win on that.
As for replacing your soft fuel lines, try to do them all at the same time, tank to filter is a pain if no shutoff at the tank (mine does not have at least. Ot when it found its way to me). It is never a hood ideal to run a diesel dry of fuel by the way. Replacing all the lines at once means you only have to bleed the fuel system once as it can be a drawn out process. This could be feeding your knock condition, a failure of the injection pump to have a sufficient fuel supply could be randomly starving injectors from enough fuel to fire correctly as they pop off of pressure mechanically not based on an electronic signal as a modern fuel injected car (no computer present).
The potential issue for your hydraulic fluid looking fine but containing water is that if looked at resting, oil and water will separate with oil on top. Looking from any opening will look good. Checking the dipstick for fluid level will look fine. Overfull would be a large indication of potential water. If checked while running or just after shutting it down, a milky or frothy appearance is a sure sign of water in the oil.
A rear engine seal in a tractor is similar to a rear seal on a car. The transmission must be removed from the engine. The big difference for a tractor is that you end up 2 pieces of tractor, each piece with one axle. Both half’s will need extra support. Be sure you have help on hand. Best if someone has done it before is around, even if like me and would mot attempt it any longer (back problems that make tugging on that heavy uncooperative half’s a bad ideal).
/ YM226D Project
Tried to do some of the checks you mentioned today but couldn't manage to get the tractor started. I have a service manual on order and am waiting to start the bigger jobs until that arrives. I was able to verify that I have fuel reaching each injector and am waiting for the service manual for details on pulling the injectors to clean them. I wasn't sure how much of an overlap there is amongst various diesel engines and was getting confused trying to google the removal process. It seems that I will be removing the hard lines, removing the retaining collar, and using a puller. I will change out the soft fuel lines at the same time and go from there.
/ YM226D Project #6
See attached
  • YANMAR YM226 PARTS MANUAL.pdf
/ YM226D Project
See attached
Thanks bmaverick, I do have a copy of the parts manual as well as the operation manual. I'm assuming the service manual will have a good description of how to remove the injectors and how to split the tractor to get at the rear main seal.
/ YM226D Project #8
I would be checking the governor spring.
/ YM226D Project
Well my service manual came in and it looks to be full of great information. One thing I'm having trouble finding is details on removing the injectors. Do I need a special tool to pull the injectors like what is sold on the Hoye site? The only information I can find in the service manual says "Remove retainer from top of each injection nozzle. Remove injection nozzle from cylinder head."
/ YM226D Project #10
Sometimes they come out easy, sometimes they don't. Yours could be either. I have read of loosening hold down bolts and spin engine to blow them loose. Do not remove hold down, just loosen if you try this. :eek:
/ YM226D Project #11
re getting the injectors out, you can do it the pro way, get the Hoye tool.
Or you can do it cheap. This worked but it was more hassle than I expected. The injectors were an extremely hard pull all the way out.
I liked Aaron's (Hoye) comment, they destroyed some uncooperative injectors until they perfected the ideal tool. :)
My longwinded post:
Injector removal tool - (cheapskate version) - with photos
/ YM226D Project
Thanks for the info guys, went ahead and sprung for the puller from Hoye. Slow moving project but hopefully it's worth it in the long run.
/ YM226D Project #13
SNIP
SNIP
The "Yammer Hammer" hasn't been my experience with older Yanmars - particularly the USA models from the 1970s and 80s - which would include the YM226D.
I think that the nickname may have originated with some of the air-cooled single cylinder marine diesels. Especially those single cylinder "long-tails" that ran so many river boat sampans in SE Asia.
As far as tractors go, our two cylinder YM165D was pretty smooth except at very low idle - and even then it didn't hammer. The three cylinder models like your YM226 were all exceptionally smooth and quiet. Smooth running is the mark of well designed three cylinder engine anyway. They were always known for that. People used to remark on how quiet & smooth the 3's ran when I was at the Yanmar dealer.
As far as I know, there doesn't have to be any reason for diesels to hammer. Our big JD is smooth running after 6000 hrs. It runs so quiet you can hear the turbo spin up when you gun it. I also like our 4 cylinder Kubota - it it more lightly constructed than the JD & with a side exhaust, so maybe that is why it makes a little more motor & fan noise than the JD - but is still what anyone would call a nice running 60hp motor at 1000 hrs.
But neither one has the smoothness of our old 33hp Yanmar. Yours can be that smooth too.
rScotty
/ YM226D Project #14
rScotty
My two-cylinder YM240 must be the exception. Sometimes I wonder if the injection timing is a little early, like preignition in a car. The best way I can describe it is, imagine several people pounding on a heavy manhole cover with sledges. Deep bone-shaking thuds. Muzzling the muffler with a gloved hand makes no difference at all. Cetane improver helps only a little. 18 years now and no change, so it's not a rod knock.
For me the Hammer is real. Its the reason I prefer to use the (smooth) YM186D most of the time and leave the YM240 dedicated to backhoe use. After it has warmed up, that light use is merely loud but it isn't loaded down to where it smokes or clanks.
It's tiring, even with hearing protection on - either muff or earplug style. And causes temporary hearing loss if unprotected.
The only time I've heard another of these run was a YM2000 at a VN import house. That one did seem smoother.
I have a recording of this racket on a personal website. PM me if you want a link. (I don't want the traffic this might generate if I name it here).
/ YM226D Project #15
rScotty
The Yanmar made JD650 vs. the JD850, HUGE difference. One notices right away the hammering. I call it the popcorn engines. As for diesels, it's common for the 2-clys to do this. My neighbor has a Ford 1500 that pops too.
/ YM226D Project
It’s been a bit since I’ve updated, got stuck with a combination of bad weather and lack of time for a few weeks.
The injector puller came in and I was able to remove and clean all 3 injectors. The injector furthest forward on the tractor had some rust and debris built up, the other two were pretty clean.
I replaced the soft fuel lines and bled the air out. I also discovered my fuel cap was jammed up and did not have a good vent. I attempted a fix that I believe will work, but I will also test with the cap loose going forward for now.
After replacing the lines and cleaning the injectors the tractor is still very hard to start. I did get it going this weekend but it required the block heater despite being mid 50’s out. It also takes several iterations of using the thermostart and cranking. Once running It did sound better than before but I had a few noticeable issues:
1. White smoke.
2. The rpms still surge. I could manage an idle around 800rpm but any movement of the throttle and it would ramp up to 2-3krpm. It was much smoother sounding and not knocking.
3. At idle any load on the tractor would stall it. This model has power steering and even slight pressure on the steering wheel would bog it down and stall it if I continued applying pressure. This may be normal, i’m not sure.
I was able to grab a video of it running, smoking, and ramping up. If I can find a way to post it I will.
/ YM226D Project #17
1. White smoke.
1. inspect the engine governor rod and timing apparatus. My old JD850 had a bend one due to an inexperienced diesel mechanic.
The engine would run at idle, bump the throttle, and wham-o 3K rpms. There was no in-between.
2. Verify the inject lines are going to the RIGHT injectors. This was problem #2 from the same mechanic.
3. Inspect and compare all the throttle linkages, springs and mechanisms to diagrams and other WORKING YM226 machines.
You may have to poke around the web for an image search.
Now the white smoke.
1. Normally with a diesel, white smoke out the exhaust strongly suggests the injectors are very worn out. This too could be the reason WHY the idle can JUMP to 3K. The injectors just get a hint of extra fuel to go WIDE OPEN. Then adding a load it sputters to die out.
With all the work you have done, don't run the engine long with it white smoking.
/ YM226D Project
Thanks bmaverick, I'll go check out the governor rod. LeeJohn hinted at this as well. I'll also confirm the injector lines aren't mixed up, I'd be surprised because they are hard lines and wouldn't easily be crossed but you never know.
I've been doing some research on the white smoke and considered just replacing the injectors. Rather than throw money at the problem I figured I could do a little more diagnosing first so I have a compression gage on the way and I'm planning on pulling the injectors again to verify the spray patterns on some cardboard. If I come up with poor compression I'll know the problem starts deeper and the injectors may be ok. If I get good compression and/or poor spray patterns I'll be back to looking at the injectors and may just replace them. The governor assembly gives me something to check out in the mean time.
/ YM226D Project #19
My understanding is the Yanmar hammer is in reference to the 2 cylinder motors.
if you have not, I would add injector cleaner and just let the tractor idle at 2000rpm for an hour. I did this with many tractors when I was importing and had good results.
/ YM226D Project #20
Also today’s fuels are very different from the fuels of the late 70’s and early 80’s of the design of our YM machines. Frequent additive to your fuel of a good quality diesel additive is probably wise.
I try not to call at brand names as there are many high quality brands.
