Box Blade Purchase - Conflicting information
/ Box Blade Purchase - Conflicting information #1
jacksonhill
Central Vermont
Kubota L4060le
Hey All,
I'm waiting on my L4060le to be assembled by the dealership. Among the implements I've ordered is a box blade. The dealer built it with the Land Pride BB1272. After looking into it, Land Pride shows it's rated for tractors up to 30hp. so I emailed Land Pride and they said they would not recommend that for my tractor but would recommend the BB1572 instead as it is a thicker gauge steel. Dealer says they have guys running the 1272 on MX series tractors (over 50hp) with no problems. So...who do I believe. Seems like the dealer may be trying to sell what they have rather than the right tool for the job. But maybe not. Anyone have any input?
Thanks in advance
/ Box Blade Purchase - Conflicting information #2
We run a BB1572, recommended by our dealer & we confirmed via the Land Pride specs on a 40hp New Holland TC40D & I don't think I would want to go smaller... There is a 100lbs different between the BB1272 & the BB1572... IMO with a box blade as long as your machine can handle it... weight is your friend
/ Box Blade Purchase - Conflicting information #3
People having no problems using lightweight implements usually haven't hit that big rock or root yet.
Bruce
/ Box Blade Purchase - Conflicting information #4
The manufacturer probably knows the product better than the dealer. Of course if you get the lighter one and break it the dealer stands to make another sale. Get the heavier one.
/ Box Blade Purchase - Conflicting information #5
BB1272 = 404 pounds
BB1572 = 504 pounds
BB2572 = 549 pounds
The Three Point Hitch provides no hydraulic down pressure on implements.
Therefore, heavier BBs will cut better than light BBs and require fewer Top Link adjustments for acceptable peeling of dirt layers. The key metric is weight per unit of width.
Consider also the BB's role as Three Point Hitch counterbalance to FEL lifts.
If your rear tires will be "loaded" with liquid, 504 pounds should be just adequate.
If your rear tires will be inflated with air consider a BB of 600-700 pounds.
Box Blades have a considerable learning curve. Be patient.
60" Bush Hog brand Rollover Box Blade in pictures weighs 620 pounds.
(124 pounds per foot of width)
/ Box Blade Purchase - Conflicting information #6
I have a L3240 and use a 1100+lb 78in BB, weight is your friend here, even on my smaller tractor with a 400lb 60in box blade I found myself adding weight to make it work.
I'd get the heaviest blade that will work on your tractor that you can afford.
I like Land pride implements but have always found them to be a bit light for their price/size a lot of times.
/ Box Blade Purchase - Conflicting information #7
I bought a medium weight box-blade at an auction. I was grading a dirt road and caught a cast iron water valve housing. My 70 hp tractor ripped the 1/2"x3" flatbar located on each side like it was taffy! I welded them up but it soon failed again. I sandwiched a piece of 1"x 3" up against the original and haven't had any issues since. During the repair time, I often wished I had spent a little more money and bought a heavier one. The lighter one worked fine for me for several years until I stressed it with all the available horsepower my tractor had.
David from jax
/ Box Blade Purchase - Conflicting information #8
Hey All,
Thanks in advance
Absolutely get the 1572. You have it, they are trying to sell inventory on hand.
/ Box Blade Purchase - Conflicting information #9
The downside is what you will probably hear about BB1572 availability. You might want to explore other options. Box blades aren't terribly complex or unique.
/ Box Blade Purchase - Conflicting information #10
Hey All,
Thanks in advance
ABSOLUTELY.....Get the heavier one!
Dealer just wants to sell what he already has!
/ Box Blade Purchase - Conflicting information #11
Weight is your friend with all land engagement implements. Get the heavier box blade. Lighter implements will not perform as well and can "crumple" when faced with an immovable object.
/ Box Blade Purchase - Conflicting information #12
You’re probably going to run into an availability problem with the heavier one.
I ran into that when buying a landscape rake for my 40hp Kioti CK4010. Ended up with a Kioti branded /Woods manufactured medium duty rake only rated for , I think, 30 hp.
I needed it for the summer, though, and couldn’t wait the 12 to 16 weeks everyone was quoting for a more capable rake.
Worked fine this summer, and I doubt I will care in twenty years.
Not many 90 year olds use their tractors regularly...
Besides, the dealer said he will buy it back if I bust it up. Wonder how long that offer is good for?.
/ Box Blade Purchase - Conflicting information #13
Hey All,
Thanks in advance
If I had a choice, I would rather the 1572. That is only because of the weight. I understand your concern. I had the same concern. the 1272 is rated up to 30hp. HOWEVER, they say it is matched to the BX, B, LX, and L series. My tractor - L4701. Also, on the Kubota website, it says the BB15 is 40 hp, but matches it with B, LX, and L series. Interesting.
I also have the BB1272. I use it a lot on the road. It is very tough and over the last 4 years, it has had a lot of use with no problems. But I do not use the tines a lot. There is too much rock here for that. Still, even though they are both good, I like the extra weight of the BB15. That is be best place for rear ballast to add even with liquid filled tires.
Best Wishes, Larry
/ Box Blade Purchase - Conflicting information #14
That seems to me like an out the door offer.
Once you are out the door the offer is no longer valid!
/ Box Blade Purchase - Conflicting information #15
Generally I figure a box blade ought to be able to hit a rock or stump off center and stop the tractor without any fear of bending the box blade. That means it is built strong enough. You can always add weight, but can't subtract it.
I'd say it sort of depends on what your soil is like, and what you plan to do with the box blade.
More weight usually means it is the same box but built with thicker metal - which you must have if you are in rocky or tough soil.
If the jobs you are doing are gardening in soft soft loam without many rocks..... or you have fine sand like Jeff does.... then the lightweight box blade will probably do OK.
I'd tell the dealer my fears and get a promise to take the lighter one back if it is damaged in the first couple of years of use. Box blades typically last about a zillion years. Old used ones work about the same as new ones.
rScotty
/ Box Blade Purchase - Conflicting information #16
If its not in writing its a figment of your imagination
Seeing is believing!
willy
/ Box Blade Purchase - Conflicting information #17
I have an ancient 72" or 74" Gannon box blade behind my L4060hstc. Loaded R4s & loader. The Gannon is heavy, probably pushing 1,000lbs. I can stall the tractor (traction wise) without to much effort filling the box full or taking a deep cut into hard ground.
For a box blade the heavier the better. Weight us a good proxy for strength, they aren't complex. Weight also is downpressure & cutting force. If you have hard ground you need heavy to dig in & heavy to hold up to the abuse.
No matter what you get a hydraulic toplink is your best friend when learning or using a box blade.
Heavy also makes for a more effective ballast when using the loader.
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
213324 (A64279)
213324 (A64279)
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
Trek (A65640)
Trek (A65640)
2019 LAYMOR SM300 RIDE-ON SWEEPER (A65053)
2019 LAYMOR SM300...
1200 GALLON FLAT BOTTOM POLY TANK (A64278)
1200 GALLON FLAT...
