Cobwebs on my PWS
   / Cobwebs on my PWS #1
Grumpycat
Madison, AL
<TBD>
Have forgotten how many years I have had a PWS (Personal Weather Station) on this fence (this is the 2nd hardware, first was up long enough for the plastic to turn to dust) but this year is the first I have had a spider problem. Don't see cobwebs anywhere else on the fence or the trees but have had this thing apart 4 times this year to clean it out. This morning I only had to dust it off having observed the almost impossible situation of no wind for several days.
The 2nd picture is of the black teeter-totter inside with buckets to measure rainfall. Each tilt counts as 0.01" of rain. Most recent cleaning used WD-40 hoping spiders will not like the smell. Also folded a dryer sheet inside as fabric softener seems to be a good bug repellant.
My PWS posts as KALMADIS73, Personal Weather Station Dashboard | Weather Underground
   / Cobwebs on my PWS #2
We had a spider plague this year, seems to be a 10 year event, early in the morning acres of paddocks are just covered in a blanket of cobwebs, our PWS didn't seem to be affected but it is on top of a 10' steel pole mounted on gutter fascias.
Our problem is corrosion on the battery terminals that get damp in their waterproof (???) enclosure.
   / Cobwebs on my PWS
The AcuRite 5-in-1 shown doesn't do anything to waterproof the battery compartment. Has a loose door on the bottom. Batteries are about 1/2" above the door. Humid air freely enters. Haven't had a problem with battery contacts.
   / Cobwebs on my PWS #4
Peppermint oil mixed with water and applied with a spray bottle solved the spider problem in my home gym.
A single undiluted drop in your weather station should do the trick.
   / Cobwebs on my PWS #5
Ours was a cheaper unit which probably explains a lot, we paid about $130, might look at the Acurite but the missus will baulk at the $350 price tag.
Fence mounting no can do as the horses will break it.
   / Cobwebs on my PWS #7
I have a Vantage Pro 2 weather station. Mounted on a steel pipe about eight feet above the corner of my porch. No spider problems. However - the rain collection cup will fill with dead, falling pine needles. I climb the ladder and pick them out two or three times a year. It's somewhat of a PITA & I dislike ladders.
   / Cobwebs on my PWS #8
Killer gym!
Yeah, I’d spray the pole too.
I spray the soffit around my hummingbird feeders to keep the ants out.
   / Cobwebs on my PWS #9
Killer gym!
Never been to a gym in my life!
Ain't about to start now (almost 81).
2021 Kubota SVL97-2HC Compact Track Loader (A50657)
2021 Kubota...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
2005 Ford F650 Fire Truck (A49461)
2005 Ford F650...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
