New to me 226D
/ New to me 226D
Got the orange flashing lights wired up and working like factory today!
Tonight is the Yanmars first night out of the shop with the bobcats. Mainly because I gotta get my brushcat into the shop so I can rebuild the gearbox. Still have a few things to do but I’m at least on the downhill side of things with the 226D.
/ New to me 226D
Brought home another Yanmar tonight.
The guys dad used to be the local Yanmar dealer back in the day and believes his dad sold this 135D new. This tractor needs the front end rebuilt mainly, it was pulled apart to diagnose the oil leaks and was thrown back together and parked. It runs great, clutch probably is gonna need replaced as it kinda grinds into gear, missing all of the 3 point hitch. I’ll start a new thread for it, looking forward to bringing another Yanmar back to its former glory.
/ New to me 226D #64
This is a really nice looking Tree Frog to restore.
/ New to me 226D
Brought the 226D out to my property yesterday to do some mowing and test things out.
What I found is in high range the power shift is super delayed, it takes up to 10 seconds to build pressure and start moving and up to 5 seconds between gears. On an incline it actually will slow to a stop on high range. No clutch slippage or anything, it’s just like it doesn’t have the pressure to stay in gear. Haven’t read through the manual on it yet but I figured I’d start by draining the hydraulic fluid and pulling the screen to see if it was plugged.
Upon removal the screen didn’t appear plugged but had a fair amount of metal shavings on it. I’ve since cleaned the screen and refilled with fresh hydraulic fluid. My 3 point lift sounds better now but still has the delay in high range. I’ve not gotten it to stall on an incline yet though. Any thoughts? I’m thinking either the valve body for the power shift needs resealed or my hydraulic pump is weak. The 3 point lift cylinder probably needs resealed too, if I lift it it’ll slowly drift down and then relift every 5-10 seconds. Also found that the front axle leaks which I fully expected after refilling it with 90 weight since it didn’t register on the dipstick.
/ New to me 226D #66
with your 3 point in up position, close your lock valve and see if it still drifts down. If so, lift piston o-ring likely bad. If not, control valve or relief valve likely leaking by.
Assuming you are aware your main hydraulic pump does not affect your power shift. The power shift has it's own pump.
Also, your front end leak may be to bad, but, in some cases people have been successful in adding Lucas transmission stop leak.
/ New to me 226D #67
...On an incline it actually will slow to a stop on high range. No clutch slippage or anything, it’s just like it doesn’t have the pressure to stay in gear.
That's not good at all. That is physical clutch slippage inside the transmission.
Powershift is a 100% mechanical connection, crankshaft to axles, after the little internal clutch packs are engaged by hydraulic pressure.
Here's a picture of motorcycle clutch components, for a simplified view of what's in there. Hydraulic pressure on the end of the clutch pack jams the drive and driven plates into positive engagement.
Slippage in there is just as bad as on a conventional clutch.
/ New to me 226D
So I did this test today and with the valve locked and 3 point up it did not drift. As far as the front end goes I’ve put together a parts list on Hoye, it’s about $200 to completely reseal the front end.
/ New to me 226D
Well that’s unfortunate.. I’ll have to do some reading in the manual to better understand how it’s put together. I got to rebuilt automatic transmissions in college so the whole hydraulic clutch pack is familiar to me.
/ New to me 226D
Finally found most of a set (missing 1 front) of wheels/tires from a 790 John Deere today.
The rears fit like a glove, front measures to be the same as well. My sway links are a tight fit however I ultimately plan to get a quick hitch and probably spacers in the rear which should solve that problem. I do plan to get these wheels blasted and painted to match, just wanted to mock them up and see how it’d look.
Ratio wise I should be good with the matching set of R4’s can my R1’s so everything in theory should work. Should be a great alternative to mowing grass on fairly soft ground.
/ New to me 226D
Ordered another front wheel today through Deere and got the rears back off the tractor so I can get the tires dismounted and wheels sand blasted. Really looking forward to getting this tractor dialed in.
/ New to me 226D
More progress, got the tires dismounted today and picked up the 4th wheel. Next step is getting the wheels sand blasted so I can get a fresh coat of Yanmar off white on them.
John Deere part # for the front wheels:
/ New to me 226D
Just some cosmetic changes to clean up the 226D.
Sizing up the new front wheel
Note: Front wheels only fit in the wide position
/ New to me 226D #74
/ New to me 226D
Is that a replacement Yanmar Diesel decal ?
It is yes. They’re not quite as long as the originals but they do look a little nicer without all the fading.
/ New to me 226D
Made a trip out to a friends house and found some Yanmar side panels. unfortunately they weren’t exactly right but with slight modifications they fit right on.
And I got another project tractor…. Allis Chalmers 5020 (Hinomoto E23 if I’m not mistaken)
/ New to me 226D #80
And I got another project tractor…. Allis Chalmers 5020 (Hinomoto E23 if I’m not mistaken).
From what I recall reading here more than a decade ago - Those are excellent, every bit as good as the Yanmars. But with one exception: A few people were crying that they broke the ring gear or front differential or something similar, with no hope of repairing it. No parts available. Hinomoto folded long ago. That unavailable part was already stripped from every salvage yard Hinomoto.
I guess the thing to be learned is don't overstress the differentials and you will be fine.
2013 Chevrolet  Express 2500 (A62613)
2013 Chevrolet...
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
