Texas Spring/Summer Thread
/ Texas Spring/Summer Thread #7,061
Last Friday, my propane company finally installed and filled my 1,000 gallon propane tank. Yesterday, the electrical guys came out and connected the transfer switch up and tested the generator. I am ready for hot or cold power failures now. Watching the tranfer test was worth the price for it all to me. 5 second delay, then the generator kicks in. I was told the 790 gallons in the tank will run the Kohler for about 2 weeks. But I have to change oil every 100 hours.
hugs, Brandi
/ Texas Spring/Summer Thread #7,062
Don't y'all have natural gas access? No worries about a tank or running out.
/ Texas Spring/Summer Thread #7,063
hugs, Brandi
Brandi, running an engine on super clean propane helps keeps the oil clean for extended periods. But if dusty environment, change oil frequently.
You should get rain soon.
/ Texas Spring/Summer Thread #7,064
hugs, Brandi
Congratulations! I hope you stay comfortable now.
There is also the first month/20 hour oil change, and some break-in loading, I think. I learned the hard way that when doing the generator exercise testing, it is worth loading the generator up to full load to burn off residual oils and load seals.
I don't know if it helps on the oil change interval, but I do the mental math to compare to a car on a freeway. 100 hours times 55mph is 5,500 miles between oil changes. Personally, I file it in the "worth doing on time" category, even if the weather conditions are ugly.
YMMV...
All the best,
Peter
/ Texas Spring/Summer Thread #7,067
YMMV...
All the best,
Peter
The guys installing it ran it for 5 hours before bringing it out. The Kohler is rated to change oil every 100 hours, or 50 hours if ran that long. I really don't know what you are trying to convey by mentioning mental math and comparing it to a car on a freeway. Running at steady RPMs is nothing like an automobile engine with constant rpm changes.
I was an A&P mechanic (still am, as the license is good until revoked) for 43 years, with the last 28 years with Southwest Airlines. I know more about using hours than miles. Who drives 55 anyway??????????????????????
Brandi
/ Texas Spring/Summer Thread #7,068
Hey Kyle! Yep, just like running it on jet fuel. Makes it way harder to check oil levels.
No rain yet.
hugs, Brandi
/ Texas Spring/Summer Thread #7,070
25_cent_score,
We will see how much preventative maintenance the tarp will need. How is your JD 110 doing?
hugs, Brandi
Thanks! And glad to hear things are going well with you. Im using the 110 frequently. Moved it from the farm to a place in town. Taking my time clearing out an area behind the house there. Also move it over to another couple places from time to time for moving cut trees and brush.
Took down a large pecan tree and have some decent sized chunks. I need to load one up for a guy in Central Texas who makes cutting boards, bowls, etc. The chunk is so heavy I’ll need the forks to lift it onto the trailer.
/ Texas Spring/Summer Thread #7,072
I have access to natural gas, but it isn't in a pipe.
hugs, Brandi
I had a friend in Oklahoma once who had to flare off his drinking water. His 300' water well was half gas and half water. He could have cooked and heated with it, but installing and maintaining the dryer cost more than it was worth at the time.
/ Texas Spring/Summer Thread #7,073
Brandi
My bad. I thought that you were objecting to the 100 service. With your background, of course not.
Amateurs like me are perhaps more used to thinking about miles to service intervals. I was just trying to put the service interval in a different perspective. I have seen more than a few folks on TBN complain about servicing every 100 hours on generators.
All the best,
Peter
/ Texas Spring/Summer Thread #7,074
I didn't mean "that" type of natural gas. It's the kind I get after eating rich food.
hugs, Brandi
:p
/ Texas Spring/Summer Thread #7,077
Looks like the upper gulf coast and SE Texas is going to get some in the next few days from the tropical storm that just formed. I hope we get several inches up in the Buffalo area.
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
2016 JCB 3CX 4x4 Loader Backhoe (A68183)
2016 JCB 3CX 4x4...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2013 FREIGHTLINER CORONADO 122 SD (A67714)
2013 FREIGHTLINER...
