Advice on 25 hp tractor purchase
/ Advice on 25 hp tractor purchase #21
My suggestion is look at the specs for the mower you want. It will tell you minimum PTO HP. The minimum is jut that, a minimum. That means you will experience times when HP is lacking. I would be looking at a being above the minimum.
Also, if you are at the minimum or just above that's where a gear vs HST is really going to make the very noticeable difference.
/ Advice on 25 hp tractor purchase #22
For the member who put out that I would be limited to a 5’ light duty brush hog, if that’s true that concerns me. I want a medium-heavy duty hog for small brush around my place and the occasional for-hire job.
"For-hire" you will not be offered easy jobs.
MORE: T-B-N ARCHIVE:
25 horsepower tractor and bush hog rotary cutter site:tractorbynet.com
/ Advice on 25 hp tractor purchase #23
Let me clarify, I will be using to clear underbrush, thicket and small trees. What is too big for the tractor, I’ll take with a saw and then work on working the stump out with the tractor. I will be getting a ratchet rake to assist with these task.
I realize going with a hydro I lose some hp in certain situations. For the member who put out there that I would be limited to a 5’ light duty brush hog, if that’s true that is concerning to me. I want a medium-heavy duty hog for small brush around my place and the occasional for-hire job. If I need more tractor, will a 30 hp allow this? Will it handle a 6’ Hog?
I had a Massey Ferguson 1250 with 34HP/27 at PTO. It managed to keep my field mowed with a 60" brush mower. If it got too high, it was slow going. When it came time for a new tractor, I got a 45 HP tractor with larger, heavier frame. Wish I had done that earlier.
/ Advice on 25 hp tractor purchase #24
i have a Bobcat 2025 which i think is very similar to the kioti you mention. We loved the Bobcat vs all others because of the cab layout, fit and finish, metal fenders and hood, and dealer network in my area. I planned to get the 35hp version but on test drives found it to be much louder. I am perfectly happy with the 25 hp hyrdo and a 5 foot cutter. I am mowing field grass with small brush (finger width) as fast as I want on level ground. On hills I do lose RPM; some may find this underpowered. It is fine for me. I mow in mid range, only use high to get from one field to another. My neighbor has a much steeper field, feels his 39hp kubota is underpowered. All comes down to specific land conditions, and user expectations. I am at 42 hours on this first summer. Also added a trash fork which is perfect for grabbing brush and trees I dropped with chain saw. Enjoy the shopping!
I find my bobcat (kioti in white) really nice. Large easy on/off operator platform. It is a hydro and I use it for brush hog with no problems, except.......... i wish i could stand up on it to see what's coming up in front in the grass.
So, i ordered the cruise control kit for it. If one of your choices has that option, pick it.
Which model Bobcat did you purchase?
I know you have your reason for the 25 hp and I have a Kubota with 27 and I am so glad it has every one of those horses. Borrowed my friends Kubota BX with 23 hp if memory is correct with their rear tiller. Oh boy did it need more hp. Tiller was supposed to have been matched to that tractor by the dealer. Know they were bought together.
No idea on Branson as not aware have ever seen one but who makes them? Any issue on parts? As to buying the dealership, I recommend know who the next dealership is in case something happens to the one near you. I passed on a Yanmar for that very reason. Really like the dealership about thirty miles away but they had only been a dealer for about a year and no other was within 100 miles.
The Branson dealer said no issue with parts. If there was something which had a longer lead time, they would take it off a model which they have in their inventory. TYM owns Branson however they do not manufacture them.
Is there really any point on getting an implement much wider than the width of the tractor? As long as it covers the width of the tractor, it's good enough. Will the extra foot really make that much difference on the time it will take to mow a certain area versus the extra load/stress it will put on a tractor?
That's a good point.
/ Advice on 25 hp tractor purchase #28
As you now know: On the FIRST try,...... you should..... BUY ENOUGH TRACTOR!
/ Advice on 25 hp tractor purchase #30
It seems most recommend more hp than 25. Regarding width of brush hog. Note the 5 hp per foot width recommendation, passed on by one member. But you don't have to use the full width of the brush hog. If you're just mowing weeds in a pasture, use the whole width of what you own. If you're hogging brush 4' high with saplings an inch thick, then only use 1/2 of the width of your brush hog. With implements, heavier is better. It's almost as is you can buy by the pound.
/ Advice on 25 hp tractor purchase #31
The heavier the blades on your brush cutter the more rotating mass you will have which helps with cutting smaller trees/larger brush with a sub-compact tractor.
/ Advice on 25 hp tractor purchase #32
Yes. Mower blade inertia is important. Light mowers have light blades. When the load stops the blades or a low stump deflects the rotating blades it is tough on the gear box. Or a blade can be deflected enough to contact and even cut the deck. I have had personal experience with the latter.
BUY ENOUGH TRACTOR
BUY ENOUGH MOWER​
/ Advice on 25 hp tractor purchase #33
Sure. So the dealer then has his limited inventory down for absent parts, so the limited tractor inventory cannot be demonstrated. When potential customers ask the sales person why equipment cannot be trialed, the sales person can answer 'because parts are not available from Branson'. Then the mechanic quits so the status of the dead tractor inventory becomes a mystery.
Do you want a Branson from this dealer?
Caveat emptor.
/ Advice on 25 hp tractor purchase #34
As I have said I have a 27 hp Kubota. I use a 52 inch (on the light wide side) rough cut mower which is often call a bush hog which is a brand. I have no issue using that width in light weight bushes but heavy grass or heavy brush forget it. Must go narrow as was suggested. One thing to consider on real heavy pto load, if the tractor uses a pedal or other device to engage the pto then you can ease it into the load and not shock load the pto clutch. If it uses a simple pull or push switch with hyd engagement it will hit the pto with the full load in a shock engagement I call it.
Oh I also have a 6 foot rear finishing mower I use to use for my lawn. I have a zoysia grass which in some areas is on the thick side much like carpet grass. It will stop my tractor in mid range. I have to back off of the full 6 feet to about 4 feet. One reason I use to use it to mow our lawn.
Don't let me spend your money for you and know you want the tractor two weeks back (well I do when I want one) but price the difference in the next hp sizes. Might surprise you how little the difference is but you may have already done so.
I have bought 5 tractors in the last 25 years. On my 5th purchase I was calm enough to really take my time and get it fully right. Each of my first four served my well and still have two of them. But I bought everyone with a single need in mind and wish has thought past that single urgent type need. It has been said and I agree, decide what you want and need it for. Want and need are not always the same. Then know what implement or attachment is needed for that job. Okay what size tractor or what options does it need for that implement and the load it will be handling. There is your tractor or in my recommendation the next size is what you need.
/ Advice on 25 hp tractor purchase #35
.... rough cut mower which is often call a bush hog which is a brand.....
brush hogs - generic name by adding one letter. Or field mower.
/ Advice on 25 hp tractor purchase #36
Very true statement, but its much more than simply mowing concerns going on here. Typically a medium duty rotary weighs 420 lbs or more than a light duty cutter, and can reach 1280lbs. Throw in the required heavy duty gear box, and you have a medium duty implement thats simply not suitable for a 25hp tractor with 21HP at the PTO. And on hot summer days, that small tractor is going to overheat for sure. Kubota and JD both market light duty 48" rotary cutters for their under 26HP line of tractors for the specific reason these tractors have limited PTO horsepower. You can run a 60" light duty rotary cutter on these under 26hp tractors....but i would not encourage a medium or heavy duty cutter. Just get a bigger tractor.
/ Advice on 25 hp tractor purchase #37
TJ, I don't know how to say this right so I'll just say it outright. You need to sit down and give this whole tractor idea some more thought. Every time someone on the forum questions what you plan to do with this tractor, you come back with what sounds like an story straight from a salesman.
We've all heard these sales pitches. After all, we bought tractors too and those stories were old a generation ago. Which is about how long we have been tractoring.
Just for starters, for what you describe you want to do, you need to be looking at a larger machine. Probably twice the weight & HP. Or lower your expectations.
I'm an old timer just trying to be realistic here.
rScotty
/ Advice on 25 hp tractor purchase #38
Rade - absolutely agree with you. Seems everyone is trying to talk him into getting more horse power than 25. In buying, if he gets the owner's manual, and reads before purchase, it will probably recommend the width of the hog, but likely won't specifically point out the weight of the hog - he'll have to deduce that from the lift capabilities of the 3 pt hitch. Lot to go wrong on a first tractor purchase.
Incidentally, I used to live in Hillsboro
/ Advice on 25 hp tractor purchase #39
I am in agreement 25 hp is good for weekend farmer and or hobbyist. Getting work done in larger setting requires horsepower unless you just love tractor seat time. I have two tractors 25 and 35 Hp they are for different jobs. I chose 25 hp over zero turn mower. Many people like zero turn mowers. I am not one of them after owning woods zero turn. It was rough riding unit that was fast. My back hurts just talking about it.
Have you looked at LS? My is 25HP and I have done a ton of work with it on my farm. 109 hours and 0 problems. Moved big cut down trees dug pits and even made a small canal for water.
I haven’t looked at any LS
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59906)
2006 STERLING...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
2016 Komatsu HM400-5 44 Ton Articulated Dump Truck (A60352)
2016 Komatsu...
