Advice on 25 hp tractor purchase
/ Advice on 25 hp tractor purchase #1
tjm1982
Long 2360
Hello all. I'm in the market for a 25 hp compact. I have done extensive comparisons and have settled on Kioti or Branson. I chose these 2 for the amount of tractor I would get for my $. Each tractor is the heaviest in its class and has the best lifting capacities. I have heard the "buy the dealer, not the tractor" phrase already and am comfortable with both dealerships, which are within an hour of me and both service in house. I want to go Hydro for this purchase. This tractor will be used for FEL work (small tree clearing), minor driveway grading and brush hogging. I was quoted the below prices:
Kioti:
CK2610 Hydro
$18,300 tractor + FEL
Fluid and delivery included
Branson:
2515h
$19,900 tractor + FEL
nothing else included
I have been on the Branson and it's ok, nothing special. I have yet to sit on a Kioti. Neither dealer has these tractors in stock, so I would likely have to wait either way. My question for those which have experience with either of these models......which would you spend your money on?
/ Advice on 25 hp tractor purchase #2
tjm, Before purchasing my first tractor, a friend advised I get power steering to ease the work with the front end loader, a 30 hp, as a lot of PTO driven implements require a bit more horse power than a 25 hp tractor has at the PTO, and to get a hydrostatic transmission since I was not buying for agricultural work.
I've found the advise good.
After that first tractor, with FEL and back hoe, I bought a different property, this with agricultural work to be done. I bought a used manual transmission tractor, since all I was going to do with that tractor was back-and-forth across the fields for aeration, harrowing, seeding, etc. That transmission was right for ag work, just as the hydro was right for the miscellaneous duties of the first tractor, which I still have.
Hope this helps.
/ Advice on 25 hp tractor purchase #3
I would not choose a 25 HP HST to brush hog with. I’m also curious what you mean by clearing small trees with the FEL.
/ Advice on 25 hp tractor purchase #4
Choose a Kioti or Branson model with a 3-range HST, in preference to a 2-range HST.
25-hp limits you to the use of a light duty (grass only) 60" rotary cutter / Bush Hog.
This tractor will be used for FEL work (small tree clearing), minor driveway grading.
I recommend a Ratchet Rake as your first attachment. The largest tree you will be able to push over with the FEL is 2-1/2" diameter in moist-wet soil. It is only possible to push over a 2-1/2" tree because the Ratchet Rake grips solidly.
I'll be using this tractor to clear small trees with. Using the bucket to remove the trees. I will likely be getting a Piranha bar or something like that to help with this task.
/ Advice on 25 hp tractor purchase #6
I don't think there is, currently, any better deal for a 25 hp tractor other than the Branson 2515. And looking on how those are selling faster than the dealers can get them, it must mean something. It will lift more on the loader and on the 3 pt and it's also an heavier tractor.
That being said, the Kioti is also a great tractor. I think I would sit on both, maybe ask the dealers if you could run them for a bit to get a feeling for it and then make your choice. Also see which dealer you like the best and take care of you the best.
/ Advice on 25 hp tractor purchase #7
Kioti:
CK2610 Hydro
Branson:
2515h
I have now had 1.2 years on Ls MT225S with loader. Tractor and loader was 16.3K. I chose to add mmm for 3k which has proven to be wise but. Just turn 151 hours on tractor its used for driveway construction and landscaping. Moved roughly 72 tons of dirt around my sons house. Tractor is light enough to get close to foundation. I have pushed this tractor no abuse. It has been a work horse no disappointments. The 25 horse motor is yanmar. The tractor is weighted well to its FEL. 3 speed transmission, rear and mid mount PTO, tilt wheel cruise control smooth power steering. No tier 4 emissions. It’s good starter tractor for first time owner. I also have 35 hp Ls it’s more sizable tractor I use for haying. Pick your tractor for your work, you may grow out of it. However many people are searching for compact tractors you can always trade up.
/ Advice on 25 hp tractor purchase #8
I find my bobcat (kioti in white) really nice. Large easy on/off operator platform. It is a hydro and I use it for brush hog with no problems, except.......... i wish i could stand up on it to see what's coming up in front in the grass.
So, i ordered the cruise control kit for it. If one of your choices has that option, pick it.
/ Advice on 25 hp tractor purchase #9
I'm wondering why you are looking at 25 hp? Is it due to the amount of work you will be doing, or is this related to avoiding emissions systems on your tractor?
Just curious. I would never advise buying a small (25 hp) tractor just to avoid emissions issues.
/ Advice on 25 hp tractor purchase #10
I know you have your reason for the 25 hp and I have a Kubota with 27 and I am so glad it has every one of those horses. Borrowed my friends Kubota BX with 23 hp if memory is correct with their rear tiller. Oh boy did it need more hp. Tiller was supposed to have been matched to that tractor by the dealer. Know they were bought together.
No idea on Branson as not aware have ever seen one but who makes them? Any issue on parts? As to buying the dealership, I recommend know who the next dealership is in case something happens to the one near you. I passed on a Yanmar for that very reason. Really like the dealership about thirty miles away but they had only been a dealer for about a year and no other was within 100 miles.
/ Advice on 25 hp tractor purchase #11
Both Branson and Kioti make great tractors and I agree with others on the HP. If you choose the Branson and go up in HP you have options if you have problems with emissions system. Also Branson is mechanical direct injected engine so no ECM.
I own a Kioti and a Branson and like them both.
My initial reasons for 25 hp are 1) Cost and 2) Emissions
I’m not opposed to the DPF on either tractor just thought it may be easier maintenance down the road. The next step up in the Kioti is 35 hp where the Branson has a 30 and 35 hp in the 15 series.
/ Advice on 25 hp tractor purchase #13
For 35 hp you might want to test drive a Yanmar
YT235C. I really enjoy using mine!
willy
/ Advice on 25 hp tractor purchase #14
Have you looked at LS? My is 25HP and I have done a ton of work with it on my farm. 109 hours and 0 problems. Moved big cut down trees dug pits and even made a small canal for water.
/ Advice on 25 hp tractor purchase #15
Brush, sprouts, small saplings 1" or so in diameter maybe. Trees? No.
You'll destroy the FEL and frame mountings. We've even seen some very large tractors, 50-60HP and more with broken loader frames here on various threads.
Front End LOADERS are for loading loose material. They are NOT for dozing.
Let me clarify, I will be using to clear underbrush, thicket and small trees. What is too big for the tractor, I’ll take with a saw and then work on working the stump out with the tractor. I will be getting a ratchet rake to assist with these task.
I realize going with a hydro I lose some hp in certain situations. For the member who put out there that I would be limited to a 5’ light duty brush hog, if that’s true that is concerning to me. I want a medium-heavy duty hog for small brush around my place and the occasional for-hire job. If I need more tractor, will a 30 hp allow this? Will it handle a 6’ Hog?
/ Advice on 25 hp tractor purchase #17
Is there really any point on getting an implement much wider than the width of the tractor? As long as it covers the width of the tractor, it's good enough. Will the extra foot really make that much difference on the time it will take to mow a certain area versus the extra load/stress it will put on a tractor?
/ Advice on 25 hp tractor purchase #18
General rule is 5PTO HP per foot of brush hog. Conditions (moisture, thickness of material, size of material) may change that but generally it would increase the requirement.
/ Advice on 25 hp tractor purchase #19
I think either tractor will do just fine for your intended work, but consider that an increase in HP will allow for attaching 60" medium duty rotary cutters, which can cut upto 2" diameter brush. Tree clearing, even the small trees are best done by hand and then later using your tractor and FEL to move and manage the cleared debris into burn piles. A good rotary cutter typically handles all the brush that remains between the large trees you did not remove. Removing of stumps by digging with your FEL is not recommended, instead i would avoid the wear and tear on your tractor, and recommend that you consider renting a stump grinder for a few days, and just grind them all down in a weekend. Both Kioti and Branson are excellent tractors.
/ Advice on 25 hp tractor purchase #20
My suggestion is look at the specs for the mower you want. It will tell you minimum PTO HP. The minimum is jut that, a minimum. That means you will experience times when HP is lacking. I would be looking at a being above the minimum.
The thought I had when shopping for a new tractor was get the highest HP in the frame size I was looking at. But I do a lot of PTO work. It normally does not cost much more for increased HP and the cost will fade quickly as you enjoy having enough power to get the work done in a timely manner.
excavator trenching bucket- one bucket per lot (A61307)
excavator...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2023 FORD F-150 (A60736)
2023 FORD F-150...
2014 JOHN DEERE 50G EXCAVATOR (A62129)
2014 JOHN DEERE...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
