My Industrial Cabin Build
   / My Industrial Cabin Build #2,491
I always run second line back to the well to have a hose bib available, you already have the ditch so why not ! Always comes in handy.
This is the pressure tank house at the well where we live now:
   / My Industrial Cabin Build #2,493
The house is insulated, was built in 2006 and as far as I know the tank has never froze:
The pressure switch is in the well:
I pulled it up for the picture, then pushed it back down where it was.
   / My Industrial Cabin Build #2,496
I have a 20 yo “new” outdoor hydrant sitting in my shed still uninstalled.
The reason to bring a line back out is to have a shutoff valve on it. I’ve heard some people do install them on the incoming line before the tank.
In the south people also put the pressure tank outside.
I’ve found plumbing supply houses to be lower cost than box stores, but you need to know what you need to ask for.
As I recall, my pump is 1 1/4” at the top, and used a reducer to 1”
My sister had to have a new well drilled next week, theirs been going dry.
   / My Industrial Cabin Build #2,497
After reading thru this info and then researching some more online, it’s as clear as mud. The poly lines from lowes are only 160 psi so I need the 250 psi poly line.
I have evolved to the “Buy once, Cry once “ philosophy on things like the pump. The Grundfos and Gould pumps are twice the cost of the Zoeller at Lowes. But I saw some Zoeller on line that were also twice the cost of Lowes, for the same model number pump.
Looking at the Gould and Grundfos pumps online
The questions I am left with are
115 vs 200. Assuming 200 is better
Hp rating
Stages. - multi stage is multiple impeller?
3 inch vs 4 inch.
Gpm.
Back in 2018 when I had it drilled (Feb I believe). I talked to the driller and he said it would be $400 to run the line from well to the house. I don’t know if that was just labor or included the line. I don’t remember anything about the pump being discussed. I’s live to hit the easy button and have someone else donit but I am guessing I would be looking at $1,000 in labor costs and markup.
Also, i need to install two frost proof yard hydrants. Doing this myself is a pain but it also means I know how to fix it later on if something goes south.
I was planning on running the poly line and having it layed out place when the electric trench is dug, so that I can join up to that trench halfway to the house and drop it in the same hole.
Looking at the well report filed with health dept,
Well depth 210 feet
Borehole depth 65 feet
Depth to bedrock 55 feet
Hole size 10 inches 0-65 feet
6 inches 65-210 feet
Casing size 6 1/4 inch from +2 to 65
Material PVC SDR 27.6
Water zones from 130-132. 143-145
Pump test
Static water level 30 feet
Flow rate 30gpm
Drillers log
I’ll probably take this info with me to one of the recommended stores here and talk to them to get what I need to do this. Not happening today so I still have time to drive myself crazy with research.
Today I am running some more pex in the house.
Based on static water at 56' a pump set at 185-190' or 20-25' off the bottom should work well. As over time sediment from drilling and with water inflow - sand etc. will settle to the bottom, and your main water seam is at 130-140 depth so you will be pumping on average around 100-120' depth most likely.
Most pumps are 4" diameter, 230VAC, and then you can get 2 Wire pumps (start capacitor and controls in the pump) or three wire pump (with a control box/start capacitors in the house). For serviceability best to go 3 wire with the above ground control box, though 2 wire pumps last a long time too.
As far as pumps, you could get by with a 1/2HP pump - 5 GPM, set at 190' and this will pump 5 GPM or so across the 40-60 PSI pressure and depth range. If you bump up to a 3/4 HP pump you will yield about 7 GPM average - enough two people to shower at once (unless you have one of those multi head showers).
Talking pump life - starts - you want to minimize starts as that's what kills pump motors, so you can put in a decent size tank drawdown of 15 gallons (2 min run time @ 7 GPM) then you can install a cycle stop valve (CSV) later too which will keep the pump running longer as long as there is demand.
Wire size - depending on the run from the house panel to the switch, then to the well head and pump, #12 3 Wire will run a 3/4 HP up to about 450' total (to the pump). A 3/4 HP is around 10-12 start amps and 7 running amps.
As others have said, run UF to the pump head, and sub pump wire in the well. You can read a lot more in the attached Goulds pump manual - it's not an advertisement for Goulds but a general guideline for pump installation wire sizing and more.
Then an example quote today on a system with a 3/4 Goulds pump example and most everything you would need $2500 range based on a pump set at 200' and the well being 200' from the house. Hope this info helps you in your research.
  • gould pump manual.pdf
  • .75 HP Goulds Well Pump Example.pdf
   / My Industrial Cabin Build #2,498
Pretty sure mine is 3/4 hp at 180 ft down.
Working on pex plumbing this weekend. I have a question that I will probably call inspectors office for. Code says I need a hose bib on front and back of house. I am wondering if I can use yard hydrants instead. Do any of y’all run into this?
   / My Industrial Cabin Build #2,500
Why don't you want to have a hose bib on the front and back of your house? In my opinion, you want more of these, not less. I have 2 on the front of my house, one on the side, and another on the back. Then I have at least a dozen out in my yard that are attached to wood posts. When I build my attached 3 car garage, I'm going to add another, or two.
I also have hot and cold water run to the wall on my back porch. Eventually I plan on installing an outdoor kitchen. I have a drain line there too, but if I didn't, I'd just run it to the bushes.
I have clients that ran hot water lines to a spicket by their garage door so they can wash their cars with hot water. I've never done this, but they say it's the greatest thing ever.
When running PEX, be sure to use the brass 90 degree drop ear fittings for your nipples, that you attach your valves to. Never use sheetrock screws!!! I prefer Hardie screws. They are super strong and will last forever.
I use these for shower heads, hot and cold water valves in the bathrooms and kitchen, and outdoor spickets around the house. I use them everywhere I want to switch from PEX to half inch threaded pipe. Buy extra, they never go bad and you will find a use for them. It's also easier to return extras then to try and find them if they are sold out.
I NEVER use anything that slides onto PEX for a valve!!!! Ten years from now, you will be so happy that you used threaded pipe for your valves. Nothing compares, and nothing else should be used.
I know you mentioned earlier about a system that you are going to use for connecting your PEX that goes outside the PEX. I've never done that and can't comment on it. What I do use is the copper rings that go over the PEX that you use a special tool to compress. In my opinion, this is ten times better then the stainless steal rings that you clip together over the outside of PEX. The stainless steal clamps do not get as tight and I've had jobs fixing them that caused significant damage to the house because they leaked. It's never a big leak, just a very slow drip that goes undetected for years, which is how long it took to saturate everything to the point mold started growing and the sheetrock starts to crumble. The house I worked on last week was built ten years ago, and I just fixed it.
The copper rings are harder to do, but for something long term, it's night and day better.
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
2003 Land Rover Discovery 4WD SUV (A59231)
2003 Land Rover...
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
Tanker Trailer (A59230)
Tanker Trailer...
2023 KRT ST650 STAND-ON SKID STEER (A60429)
2023 KRT ST650...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
