Rebuild or Replace Troybilt Horse
/ Rebuild or Replace Troybilt Horse #1
RodXmas
Troy Bilt Horse
I have a dilemma. I inherited by father-in-laws Troy Bilt horse tiller that was bought sometime in the late 70s. It starts easy and runs smooth but has lots of issues. The transmission slips really bad unless I wire 20210724_143322.jpg20210724_143335.jpgdown the lever. I have to keep constant pressure on the throttle. I live in Maine and have been unable to find anyone to do a complete restore job. Do you know of anyone in the western maine area who would take on such a project.
Is it worth it to spend a lot of time and effort to get this rebuilt or should I just replace with a new Big Red Tiller or other recommendation you may have.
Thanks
/ Rebuild or Replace Troybilt Horse #2
Sounds like you need a couple of adjustments before making a decision.
Here's one that covers the lever adjustment.
Bruce
/ Rebuild or Replace Troybilt Horse #3
If you pay someone to rebuild it rather than doing it yourself, forget about it. It will go over budget and won't be worth what you spend. The Horse you have with that Kohler engine is one of the classics of American design. It is beautiful, functional, bulletproof and will last generations if you care for it..
Rebuild it yourself or sell and buy a throwaway tiller to get you by for a few years. Then rinse and repeat.
Oh, I think the belt is slipping and not the transmission. BTW, use the old style gear oil in the trans or you will eat up the brass parts. GL-1 or modern synthetic is what to do. Search online.
/ Rebuild or Replace Troybilt Horse #4
You cannot get a 'real' new Troy Horse tiller. MTD owns and makes them now and they are very cheapified. I agree with bcp - it sounds like yours just needs to be adjusted.
And/Or maybe new belts. There is no "transmission" in the classic sense. It just has gears that come together when the lever is pushed down and the belts drive the gears.
They are very simple machines and the issues you mentioned are easily remedied. Sorry I am not closer to help.
/ Rebuild or Replace Troybilt Horse #5
Not knowing your model, here is a typical lever adjustment.
Bruce
/ Rebuild or Replace Troybilt Horse #6
Repair for sure. Like already stated...they don't make em like that anymore.
/ Rebuild or Replace Troybilt Horse #7
This is coming from a Troybilt dealer. you will regret not repairing that tiller. I don't care if it cost $1000 you will still be money ahead. There isn't another tiller on the market that will equal the quality of the old Garden Way Troybilt tillers.
/ Rebuild or Replace Troybilt Horse #8
I bought my Troybilt Horse new in 1982 (I think).
I am 80 now, and have no intention of ever using it again.
Was going to sell it, and also my 12HP Gravely Pro.
My oldest son said no!
/ Rebuild or Replace Troybilt Horse #9
What everyone knows and says.... Fix it. I had one of these seven hp tillers bought new in 79 for 900. I ran it and ran it and ran it. Finally about five years ago some one was selling a BRAND NEW HP that had been in Storage for fifteen years. Sold t he old one and got t he new one with the handle improvement. Take care of that old machine. You "might" find out the carb linkages get wallowed out from the vibration but you have a dandy ol machine and you won't find a better one unless you spend beaucoup on a big BCS
/ Rebuild or Replace Troybilt Horse #10
Like everybody else says. My dad had a Troybilt Horse from the 70's. That thing was great, built like a tank too. One of the worse mistakes he did, was to sell it thinking he'd not do any gardening. I wished i'd known he was going to get rid of it, as i'd have bought it from him.
/ Rebuild or Replace Troybilt Horse #11
One thing that has not been discussed is balance and weight. Kohler M Series engines are made of cast iron and use a very heavy flywheel. Your Kohler may weigh twice as much as an aluminum Honda clone engine. So depending on the style of tiller you have, using a lightweight engine may affect the balance and performance of the tiller. Front-tine models are notorious for bouncing around. Rear-tine models use the engine weight to offset the tine area weight when you have to lift the tiller up at the end of a run and quickly do a 180 for the next pass.
When Troy-Built engineered your tiller, they did so in full recognition of the engine weight. This too.... is something you may wish to ponder while deciding on a course of action.
/ Rebuild or Replace Troybilt Horse #12
Mine had a Tecumseh with a large cast iron weight attached. I put on the HF replacement engine and re-installed the weight. Can't tell the difference in handling.
Bruce
Guys thanks for all the feedback. I am going to do some more research on the model get the manuals etc and get this done. I think it is going to be a good way for me to teach my kids some basic how to work skills that I learned as a boy running an old horse tiller in a big tomato patch. I am sure I will have a lot of questions and need more advice. Thanks again to all of you this was so helpful. If there are any other resources you would recommend I would appreciate hearing about them!
/ Rebuild or Replace Troybilt Horse #14
I'm on my third or fourth old Horse. They don't like rocky soil, and that's what I have always used them on. I've worn out a set of gears on each of my last two.
The one I have now has an HF replacement engine and works fine. The problem I have had since I bought it, used, is the gear lever; it has always been stiff and I had to weld on a piece of angle iron reinforcement when it bent.
I've worn out the Bolo tines, but have two sets of cultivating tines down in my shed. I just need to pick some more rocks before putting them on.
/ Rebuild or Replace Troybilt Horse #15
I have a dilemma. I inherited by father-in-laws Troy Bilt horse tiller that was bought sometime in the late 70s. It starts easy and runs smooth but has lots of issues. The transmission slips really bad unless I wire View attachment 707191View attachment 707192down the lever. I have to keep constant pressure on the throttle. I live in Maine and have been unable to find anyone to do a complete restore job. Do you know of anyone in the western maine area who would take on such a project.
Thanks
I think you are saying that it's jumping out of forward gear and you wire the lever down to keep it in forward. If that's the case, Troybilt made an upgrade kit that includes a modified Adjustment Block and Friction Wheel. Search online for
Troy-Bilt Adjustment Block & Reverse Disc for 4 speed.​
This kit fixed the problem on the tiller I inherited from my dad. He fought the problem for years never knowing they made a kit to correct the problem. The kit runs $70-$80 and is simple to install. It is absolutely worth the money since your motor runs well.
/ Rebuild or Replace Troybilt Horse #16
I put new luni Kohler 7's on 2 of mine that had cast iron Kohler 7's on them and now they are so light on the front end that they are useless! --- NO traction at all and the new luni's only weigh half as much as the good old cast iron motors did.
The main problem I have is finding the right length belts for mine! --- they all turn out being 22 inches long and thats way too long. 21.5 would be the right length and I cant find them around here.
And the belts from Troy-built dont fit either since they are also 22 inch belts!
I did make taller side straps so I could get buy but they wont stay in gear cause the longer straps throw the geometry off just enough that they wont stay in so I use tarp strap of the right length to go under the depth lever spring pocket and up to handle to make it go. --- not a good idea but thats all I could come up with.
The belt/clutch was a VERY poor design by Troy-built from the word go!
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
Adams 8 Ton Blender (A63118)
Adams 8 Ton...
2021 John Deere Z960M Zero Turn (A63116)
2021 John Deere...
Four (4) Firestone Combine 520/85R42 Tires (A63116)
Four (4) Firestone...
5ft Tiller (A64047)
5ft Tiller (A64047)
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
