Makeshift Temporary Anti-rotate For 3PH Drawbar
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Perhaps not worth posting, but just a simple way to keep the drawbar from rotating while moving a small trailer.
Would like to see your method or perhaps aftermarket devices for doing the same.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #3
Your "real" drawbar is right behind that bar. Just chain to it with enough slack to allow you to lift, perhaps
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #4
You’ll bend the screw in the clamp. It doesn’t take much and then they’re worthless.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #5
Really easy to ruin "C" clamps..
Slightly more permanent but remove's with horizontal draw bar....ITs just a piece of 2x2x1/4 angle iron...
dsc02317-jpg.704591
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #7
Not sure what is meant by your second sentence.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #10
The chain keeps the 3 point trailer hitch from raising up too high and causing an accident as reported in many threads here in the past.
Should not be a problem with a empty lightweight trailer.
The chain and bracket attach to the tractor drawbar.
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Equipment Trailer (A59230)
1986 Eager Beaver...
DEUTZ MARATHON...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
STEPP SEALCOATING MACHINE (A59906)
STEPP SEALCOATING...
