Makeshift Temporary Anti-rotate For 3PH Drawbar
   / Makeshift Temporary Anti-rotate For 3PH Drawbar #11
Like Xfaxman said... Though I do like some of those simple brackets people made. Those are pretty slick.
   / Makeshift Temporary Anti-rotate For 3PH Drawbar #12
Your "real" drawbar is right behind that bar. Just chain to it with enough slack to allow you to lift, perhaps
Yep, you might have a bar, but it isn't a draw bar when on a 3 point hitch.
Use the real one when towing...zero reason not to
   / Makeshift Temporary Anti-rotate For 3PH Drawbar #13
But then you’d have to manually operate the trailer jack. If done properly using the 3 ph is fine.
like you should..... Using only 2 points and any makeshift braces only encourages damage to your trailer hitch and possibly the tractor when it gets away.
   / Makeshift Temporary Anti-rotate For 3PH Drawbar #14
They make a lock for these drawbars. However they only work if your lift arms are normal thin ones, not extendable.
The drawbar goes through the square cut out, and the C channel section goes around the lift arm and its secured by the bolt.
2017 Ford Expedition SUV (A50324)
2017 Ford...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
NEW HOLLAND BR780 HAY BALER (A51243)
NEW HOLLAND BR780...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
MAHINDRA EMAX 225 TRACTOR (A51243)
MAHINDRA EMAX 225...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
