Makeshift Temporary Anti-rotate For 3PH Drawbar
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Perhaps not worth posting, but just a simple way to keep the drawbar from rotating while moving a small trailer.
Would like to see your method or perhaps aftermarket devices for doing the same.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #3
Your "real" drawbar is right behind that bar. Just chain to it with enough slack to allow you to lift, perhaps
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #4
You’ll bend the screw in the clamp. It doesn’t take much and then they’re worthless.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #5
Really easy to ruin "C" clamps..
Slightly more permanent but remove's with horizontal draw bar....ITs just a piece of 2x2x1/4 angle iron...
dsc02317-jpg.704591
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #7
Not sure what is meant by your second sentence.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #10
The chain keeps the 3 point trailer hitch from raising up too high and causing an accident as reported in many threads here in the past.
Should not be a problem with a empty lightweight trailer.
The chain and bracket attach to the tractor drawbar.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #11
Like Xfaxman said... Though I do like some of those simple brackets people made. Those are pretty slick.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #12
Yep, you might have a bar, but it isn't a draw bar when on a 3 point hitch.
Use the real one when towing...zero reason not to
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #13
But then you’d have to manually operate the trailer jack. If done properly using the 3 ph is fine.
like you should..... Using only 2 points and any makeshift braces only encourages damage to your trailer hitch and possibly the tractor when it gets away.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #14
They make a lock for these drawbars. However they only work if your lift arms are normal thin ones, not extendable.
The drawbar goes through the square cut out, and the C channel section goes around the lift arm and its secured by the bolt.
2 new 8'' Pallet fork extensions (A61567)
2 new 8'' Pallet...
KOMATSU WA270 (A58214)
PT 6'x16' 4 Wheel Farm Wagon (A60463)
PT 6'x16' 4 Wheel...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
More info coming soon! (A56858)
More info coming...
