Makeshift Temporary Anti-rotate For 3PH Drawbar
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Perhaps not worth posting, but just a simple way to keep the drawbar from rotating while moving a small trailer.
Would like to see your method or perhaps aftermarket devices for doing the same.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #3
Your "real" drawbar is right behind that bar. Just chain to it with enough slack to allow you to lift, perhaps
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #4
You’ll bend the screw in the clamp. It doesn’t take much and then they’re worthless.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #5
Really easy to ruin "C" clamps..
Slightly more permanent but remove's with horizontal draw bar....ITs just a piece of 2x2x1/4 angle iron...
dsc02317-jpg.704591
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #7
Not sure what is meant by your second sentence.
/ Makeshift Temporary Anti-rotate For 3PH Drawbar #10
The chain keeps the 3 point trailer hitch from raising up too high and causing an accident as reported in many threads here in the past.
Should not be a problem with a empty lightweight trailer.
The chain and bracket attach to the tractor drawbar.
2014 HYUNDAI 53X102 T/A DRY VAN TRAILER (A59906)
2014 HYUNDAI...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
KJ K3325 33'x25' Barn Shed (A60463)
KJ K3325 33'x25'...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
