Mitsubishi D4000 trans problem
/ Mitsubishi D4000 trans problem #1
PapaDave
Mitsubishi D4000
Tractor worked fine, shifted into reverse, then when shifting back into forward, nothing! PTO still works but tranny shifts through all gears without depressing the clutch. No forward or reverse now. Any ideas?
/ Mitsubishi D4000 trans problem #2
Is it a multi range tractor? Could the transmission have jumped out of range or range neutral if you will?
Us it a multi range tractor? Could the transmission have jumped out of range or range neutral if you will?
You can actually run the shifters through all the gears without pushing in the clutch. I took the top off of the tranny and could see the main output shaft spinning, the PTO in back works fine, I'm thinking perhaps an intermediate shift my have sheared or something. I can't make any sense of it, that's why I wanted to get the forums help.....
And, that being said, there's a good chance there's an obscure lever somewhere that I'm unaware of that actually does shift the entire tranny into neutral......
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2022 BOBCAT E26 EXCAVATOR (A62129)
2022 BOBCAT E26...
