Mitsubishi D4000 trans problem
/ Mitsubishi D4000 trans problem #1
PapaDave
Mitsubishi D4000
Tractor worked fine, shifted into reverse, then when shifting back into forward, nothing! PTO still works but tranny shifts through all gears without depressing the clutch. No forward or reverse now. Any ideas?
/ Mitsubishi D4000 trans problem #2
Is it a multi range tractor? Could the transmission have jumped out of range or range neutral if you will?
Us it a multi range tractor? Could the transmission have jumped out of range or range neutral if you will?
You can actually run the shifters through all the gears without pushing in the clutch. I took the top off of the tranny and could see the main output shaft spinning, the PTO in back works fine, I'm thinking perhaps an intermediate shift my have sheared or something. I can't make any sense of it, that's why I wanted to get the forums help.....
And, that being said, there's a good chance there's an obscure lever somewhere that I'm unaware of that actually does shift the entire tranny into neutral......
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
2017 Dodge Ram Promaster 2500 Van (A63116)
2017 Dodge Ram...
(4) ROW FIELD CULTIVATOR W/ROLLING FENDERS (A62130)
(4) ROW FIELD...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
