Mitsubishi D4000 trans problem
/ Mitsubishi D4000 trans problem #1
PapaDave
Mitsubishi D4000
Tractor worked fine, shifted into reverse, then when shifting back into forward, nothing! PTO still works but tranny shifts through all gears without depressing the clutch. No forward or reverse now. Any ideas?
/ Mitsubishi D4000 trans problem #2
Is it a multi range tractor? Could the transmission have jumped out of range or range neutral if you will?
Us it a multi range tractor? Could the transmission have jumped out of range or range neutral if you will?
You can actually run the shifters through all the gears without pushing in the clutch. I took the top off of the tranny and could see the main output shaft spinning, the PTO in back works fine, I'm thinking perhaps an intermediate shift my have sheared or something. I can't make any sense of it, that's why I wanted to get the forums help.....
And, that being said, there's a good chance there's an obscure lever somewhere that I'm unaware of that actually does shift the entire tranny into neutral......
Informational Lot - Shipping (A63118)
Informational Lot...
John Deere 5045E for sale
John Deere 5045E...
HAMM 2420D SMOOTH DRUM COMPACTOR (A62129)
HAMM 2420D SMOOTH...
UNUSED WOLVERINE SB84-84" ROCK BKT (A62131)
UNUSED WOLVERINE...
CATERPILLAR 815 PADFOOT SOIL COMPACTOR (A62129)
CATERPILLAR 815...
2020 Nissan Pathfinder SUV (A61569)
2020 Nissan...
