Anyone else make the same mistake I did?
/ Anyone else make the same mistake I did? #1
OWTM
Kubota MX 5400, Kubota BX23 S
Tractors MX-5400, Brush Hog (aka Rotary Cutter) Is a Land Pride 6 Footer. I broke my first shear pin after having the brush hog a year and a half (but with only about 35 hours on the brush hog) Pretty good run and it's kind of expected to break one every now and then. I looked in my garage and couldn't find any 1/2" x 3" Grade 2 bolts so went to the hardware store, no luck there, only grade 5 and grade 8, so then went to dealer and they were out. So then went to Tractor supply and bought a 5 pack of country line shear bolts and broke 3 while mowing a half hour lol.
/ Anyone else make the same mistake I did? #2
What are you hitting that you are breaking shear pins/bolts? What rpm are you running at?
/ Anyone else make the same mistake I did? #3
Tractor supply around here has grade 2 bolts in bulk bins. Buy them by the pound. I suspect the shear bolts you're getting are softer than grade 2
The big box home supply stores (HD, Lowes) generally stock grade 2 bolts in bins too. The higher grade bolts are the bagged variety.
/ Anyone else make the same mistake I did? #4
Now If they didn't break what would Tractor Supply be able to Supply you with! Grade 1.5 most likely lol
/ Anyone else make the same mistake I did? #6
Never broke one, both my Land Pride shredders have slip clutches.
My JD CX 15 slip clutches work very well. They also seem to last longer than the slip clutches on my Pottinger Discbine
/ Anyone else make the same mistake I did? #8
Why do I think the OP has a frozen slip clutch or has never slipped it or don't even know there is one? All LP shredders have slip clutches from the factory far as I know.
I don't know why you think that either? Right from Land Prides Website "The RCF2060 & RCF2072 features a smooth top for easier cleaning and a floating top link for following ground undulations in grass, weeds, and light brush up to 2" in diameter. The RCF20 is ideal for rural acreage or farm grass maintenance. These cutters have a Category 1 3-Point hitch that are Quick Hitch adaptable. The standard ASAE Category 3 driveline is offered with either shear bolt or slip-clutch protection and the tailwheel is offered laminated or solid rubber."
/ Anyone else make the same mistake I did? #13
I wonder if the OP is over tightening the shear bolt?
Maybe even leave it a bit loose with a locking nut.
/ Anyone else make the same mistake I did? #14
Not really a big deal for a hydraulically driven pto, just the rest of us with gear driven pto.
Who offers hydraulically driven PTO? Other than Power Trac, skidsteers and a couple others, but those are different types of machines in the first place.
Shear bolt works just fine and I do believe it's a better option for inexperienced users that don't know or neglect to maintain slip clutches.
We have this style that's very easy to change the shear bolt. Just a simple M8 grade 5.8 bolt. When it shears, it's as simple as pulling both halfs out, take the nut of the broke piece and slap a new one in.
/ Anyone else make the same mistake I did? #15
Mike, the package of shear bolts are not a true grade 2 I went through this with my tiller. They are scored to break you’ll probably see a slight line in it
/ Anyone else make the same mistake I did? #17
I'm running a 5' RC behind my B7800. I have hundreds of hours with this combo in use: two different RCs. Have broken maybe three(?) shear bolts, and I've been fairly abusive. My NX5510 [HST] runs a 6' RC with a slip clutch. This combo would readily eat up shear pins- A LOT of mass and impact force.
OP, what are you cutting? Go with what's in the manual (grade) and you should be fine: LandPride, in particular, should be very reliable as to all this. IF you find that you're breaking too many shear pins THEN consider a slip clutch: either the LandPride documentation's mention of "either" is to cover the different models (usually manuals cover a range of equipment) or it actually is an option- if it's an option then you might fall into the reason for that option (and go that route!).
NX stalled out when my 7' flail choked on a chunk of 8" (unintentionally hit). Quite relieved to find that nothing was broken (except my nerves). The flail (case for many) doesn't use a slip clutch or a shear pin- in general, flails tend to rely on belt slippage. My flail has four belts, which I figure might make it tough to slip. Gonna have to ponder all of this with this setup...
/ Anyone else make the same mistake I did? #18
Shear bolts work fine in smaller cutters. If you are just cutting grass and don't have to deal with rocks or stumps, you may never break a pin. I think you need a 1/2 inch that is about 4 inches long. I would shop Tractor Supply. I usually put the nut on finger tight and secure it with a bit of duct tape or some safety wire to keep the nut in place. A lock nut or jamming two nuts together is another way to do it.
/ Anyone else make the same mistake I did? #19
So am I. Should have gotten the slip clutch option instead of a shear bolt then...
You can actually add one. TSC has them in stock usually (or any place that sells farm equipment like Agri-Supply for instance.
/ Anyone else make the same mistake I did? #20
I am surprised that anyone still makes a rotary cutter that does not have a slip clutch.
All about the money, slip clutch is expensive and takes extra man hours to assemble. Worth it, but the average buyer looking at two side by side wont understand why one's $100 cheaper.
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
2006 Genie Z45/25J Articulated Boom Lift (A64047)
2006 Genie Z45/25J...
2011 CATERPILLAR 299C SKID STEER (A62129)
2011 CATERPILLAR...
2021 23ft. Aquasport Boat with 25ft. T/A Float-On Corp Boat Trailer (A61569)
2021 23ft...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
