trail clearing technique and tools
/ trail clearing technique and tools
As seen on the trails near here today. These are all .155 string heads.
/ trail clearing technique and tools #64
My wife does the weed trimmer work here, and uses the Echo 0.155 3-line head. Used to use the bump and it never held up; she does have to stop a bit here and there to put in new lines but it works the best we've found (she tried a head that has some plastic serrated knife things but while it works fantastically for a bit your throughput sucks because they do break).
Agree with the fiskars gear lopper - it's amazing; if you can fit the jaws around a branch, it'll cut it easily (unless it's dry oak, don't be ridiculous). The blade on mine may need replacement, it's got a wave in a spot idk what from. Still lops really well.
Fiskars is definitely a stand-up manufacturer - we have I think it's called "ez reach pruning stik" which through my own abuse ended up with a broken pull string. I disassembled it to see what was wrong with it, then called them and asked them to send me a new string. They sent me an entirely new pruning stik instead! so I went to the hardware store and found a similar paracord and gave the old one to my daughter :D
I'm looking at setting up a trail between a fence and an irrigation canal; there's 3-5 feet of width and it overgrows rapidly with blackberries. I suspect I just need to blast it with the trimmer more often as I don't care to poison my land...
/ trail clearing technique and tools #65
/ trail clearing technique and tools #68
We dont really have much scrub here in the mountains of CO. The most we get is Juniper which will see your weed wacker and send it packing. Thumb on the backhoe works great though! Thanks for posting these ArlyA!
Might take us a while before we got out again since we are heading to northern MN for a few days. If anyone has machines for, or been out doing trail work, please post photos. Or if anyone has any questions, just post them..
Let me add, we have been so, so happy with the utility of this 6x6 it having a box, small size on narrow trails, push snow with it and all. We are looking at replacing it with a more powerful and newer version. Its one of the best trail tools we've owned.
We are contemplating getting rid of the trusty ol boss and getting a Outlander 6x6 with its 1000 v-twin engine. The 80+ something engine is only needed for operations in the snow.
Over the weekend were to Ely MN and found new bike trails being installed at Hidden Valley XC area by Pathfinder trail building company. We were trained by IMBA so we can appreciate what this crew was doing there. More photos to flollow.
More photos at Hidden Valley ski area Ely, MN. Two of the building crew live on site. We knew the same trail people they did. Not pictured is the Whacker ground packer they use. As far as we seen, they just had the two mini excavators there. The bottom pic is the end of new trail construction. Nice fellows.
I should add, they haul fuel, tools and supplies in via nothing we could see. I'd have a 6x6 for that job. (y)
/ trail clearing technique and tools #75
I always thought these were cool.
/ trail clearing technique and tools #77
I use one of these. Grillo 107d tractor with Del Morino 21” Brush Mower. If it can push it over, it can cut it.
I maintain an 18 hole disc golf course, which is just a really really wide trail.
/ trail clearing technique and tools #78
I priced one a couple years ago and it was outrageous. You could get 3 mini excavators for the price of it or one with a complete tilt-rotator/ multiple buckets and have some good change left over. It might be amazing but dang.
I test operated Orec some machines and LOVED them. They are built for real/serious work. Seen immediately below is a flail mower but they make all types.
Got home late today and we worked on NFS trails over the weekend. Took lots of photos and will post them ASAP. Here is one.
