WALLENSTEIN WX310 wood splitter flow question
   / WALLENSTEIN WX310 wood splitter flow question #11
Most splitters unless very large industrial have a 24 inch throat meaning it will accept a 24 inch log... Not sure of you concerns of length of logs, when most consider fireplace size around 16 to 18 inches....
Higher GPM rate usually means faster cycle time...... Fast is not always better as you physically may not be able to keep up ....
20 ton is minimal, I have 22 ton standalone and I get some really knurly hard oak and that almost tells splitter it isn't going to happen, but usually does, EXPLOSIVELY!!!
Only negative is it can not go vertical for logs that are too big for you to lift into bed of splitter... Cant use tractor FEL to lift log into splitter because it's on other end of tractor....
   / WALLENSTEIN WX310 wood splitter flow question #12
Somewhere a while I posted this one. It can be stand alone or left on. Tractor is best when splitting Large wood. Go to youtube. Plumbstriaight wood splitter. Watch that spelling for the extra I. It was a typo
   / WALLENSTEIN WX310 wood splitter flow question #13
I'm liking the crane concept, though it's kinda fighting him back
   / WALLENSTEIN WX310 wood splitter flow question #14
I might add that it has been just a t for a knife as it just takes two off the bottom
Yes was a quick set and didn't put a block under the knife end to center the block in the throught
   / WALLENSTEIN WX310 wood splitter flow question #15
Throat
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2001 STERLING ACTERRA S/A WATER TRUCK (A57192)
2001 STERLING...
2014 8ft. S/A Utility Trailer (A55853)
2014 8ft. S/A...
2022 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52707)
2022 HYDREMA 912HM...
UNUSED X-STAR TREE SAPDE DIGGER (A57192)
UNUSED X-STAR TREE...
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
