any toro groundsmaster fans on here?
/ any toro groundsmaster fans on here? #941
/ any toro groundsmaster fans on here? #942
Added some zerk fitting extensions to my groundsmasters today. Used a grease gun hose, 1/8” npt union, and zerk to make them.
I put the extension on the forward pto zerk because they are so hard to get to.
The buffalo turbine had three zerks under the safety grill, so I put some extensions there too so I wouldn’t have to pull the grill to grease. The extensions cost about $6 each to make.
/ any toro groundsmaster fans on here? #943
Anyone use r&r products vs standard Toro brand? Looking for some spindles for a 72" mower deck and seems to be the only ones I can find. I bought a hood latch and a few small things from them and they were fine, but wondering about spindles and bearing quality from them.
Let me know if anyone has any experience
Thanks
/ any toro groundsmaster fans on here? #944
Hey fellas. I have three running and driving units for sale in southwest Virginia. Side discharge, rear discharge, two flail decks, and what's left of an old 72 parts unit.
328-2wd-rear discharge
328-4wd-side discharge
325-4wd-flail deck
276-722-0599
/ any toro groundsmaster fans on here? #945
325-4wd-flail deck
276-722-0599View attachment 697612
What is the purpose of the flail deck? cutting rougher taller grass?
/ any toro groundsmaster fans on here? #946
View attachment 674167 on the latest addition to the stable.
Don't have any pictures that show the shield over the fuel tank, I will check tomorrow to see if my 328D has it.
The air cleaner is from a 328D:
View attachment 674168 View attachment 674169
View attachment 674170 View attachment 674171
Seeing your aggressive tires on the back reminded me to ask, do you know if you can fit wider tires on the front with the mulching deck? Not that I need them, I just like the way they look lol
/ any toro groundsmaster fans on here? #947
Yes, a little wider than what I have with Ditch Witch wheels.
Depending on wheel offset, you might need a wheel spacer.
/ any toro groundsmaster fans on here? #948
Thank you sir! :)
/ any toro groundsmaster fans on here? #949
These are the tires that were on the 325D when the recycler deck was on it:
/ any toro groundsmaster fans on here? #950
I put a set of 24x12.00-12's on my one with the side discharge deck. I would love to put them on my mulcher, but there is no way they will clear the rollers. :(
/ any toro groundsmaster fans on here? #952
BTW the deck is not connected in that picture, I leave it off and use this one for running around :)
/ any toro groundsmaster fans on here? #953
Thanks
I've never tried their spindles, but I do get some parts from them. They ship quick. Never had a problem with them.
/ any toro groundsmaster fans on here? #954
Several advantages.
#1- gets more done in a single pass, and can handle much larger growth without needing a to recut.
#2- safer down discharge doesn't kick out stones/twigs hidden in the grass.
#3- the clippings fall back much faster.
#4- nothing stripes like a finish flail deck... the deck is heavy and rides on a load-bearing full-width finish roller.
#5- the knives don't need serviced nearly as often, and are double sided... so when one side gets dull, you can just turn the rotor and use the reverse side.
#6- Belts are MUCH cheaper.
/ any toro groundsmaster fans on here? #955
I run these 24x12-12 Carlisle ATs on my 325. Had to remove the brake linkage... but it's not like they were doing anything anyway
Caught them on sale at Rural King a couple years back. I think they were under $100 mounted on new steel.
/ any toro groundsmaster fans on here? #956
/ any toro groundsmaster fans on here? #957
Caught them on sale at Rural King a couple years back. I think they were under $100 mounted on new steel.View attachment 698391
Great look, I love it!
/ any toro groundsmaster fans on here? #958
Here's my collection, or part of it anyway lol
/ any toro groundsmaster fans on here? #959
Several advantages.
Thanks for the info, now I want one!!! lol
/ any toro groundsmaster fans on here? #960
If the AT101s did anything for you like they did for my Deines it made a whole new machine out of it for slopes and hillsides. I would never think of going back - I rip out much less grass with these chevrons than i did with the turfs and turf IIs which seemed like they were always spinning where these rarely spin and when thye do are not as rough on the grass as turfs.
LOAD OUT AND SHIPPING (A61166)
LOAD OUT AND...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
500BBL WHEELED...
2003 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2003 V.E...
2017 FORD F-150 (A60736)
2017 FORD F-150...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
