Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 13,296
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
What is the purpose of the flail deck? cutting rougher taller grass?Hey fellas. I have three running and driving units for sale in southwest Virginia. Side discharge, rear discharge, two flail decks, and what's left of an old 72 parts unit.
328-2wd-rear discharge
328-4wd-side discharge
325-4wd-flail deck
276-722-0599View attachment 697612
Seeing your aggressive tires on the back reminded me to ask, do you know if you can fit wider tires on the front with the mulching deck? Not that I need them, I just like the way they look lolView attachment 674167 on the latest addition to the stable.
Don't have any pictures that show the shield over the fuel tank, I will check tomorrow to see if my 328D has it.
The air cleaner is from a 328D:
View attachment 674168 View attachment 674169
View attachment 674170 View attachment 674171
Yes, a little wider than what I have with Ditch Witch wheels.Seeing your aggressive tires on the back reminded me to ask, do you know if you can fit wider tires on the front with the mulching deck? Not that I need them, I just like the way they look lol
These are the tires that were on the 325D when the recycler deck was on it:
View attachment 698026View attachment 698027View attachment 698032
I've never tried their spindles, but I do get some parts from them. They ship quick. Never had a problem with them.Anyone use r&r products vs standard Toro brand? Looking for some spindles for a 72" mower deck and seems to be the only ones I can find. I bought a hood latch and a few small things from them and they were fine, but wondering about spindles and bearing quality from them.
Let me know if anyone has any experience
Thanks
Several advantages.What is the purpose of the flail deck? cutting rougher taller grass?
I run these 24x12-12 Carlisle ATs on my 325. Had to remove the brake linkage... but it's not like they were doing anything anywaySeeing your aggressive tires on the back reminded me to ask, do you know if you can fit wider tires on the front with the mulching deck? Not that I need them, I just like the way they look lol
Great look, I love it!I run these 24x12-12 Carlisle ATs on my 325. Had to remove the brake linkage... but it's not like they were doing anything anyway
Caught them on sale at Rural King a couple years back. I think they were under $100 mounted on new steel.View attachment 698391
Thanks for the info, now I want one!!! lolSeveral advantages.
#1- gets more done in a single pass, and can handle much larger growth without needing a to recut.
#2- safer down discharge doesn't kick out stones/twigs hidden in the grass.
#3- the clippings fall back much faster.
#4- nothing stripes like a finish flail deck... the deck is heavy and rides on a load-bearing full-width finish roller.
#5- the knives don't need serviced nearly as often, and are double sided... so when one side gets dull, you can just turn the rotor and use the reverse side.
#6- Belts are MUCH cheaper.
If the AT101s did anything for you like they did for my Deines it made a whole new machine out of it for slopes and hillsides. I would never think of going back - I rip out much less grass with these chevrons than i did with the turfs and turf IIs which seemed like they were always spinning where these rarely spin and when thye do are not as rough on the grass as turfs.I run these 24x12-12 Carlisle ATs on my 325. Had to remove the brake linkage... but it's not like they were doing anything anyway
