any toro groundsmaster fans on here?
/ any toro groundsmaster fans on here? #941
/ any toro groundsmaster fans on here? #942
Added some zerk fitting extensions to my groundsmasters today. Used a grease gun hose, 1/8” npt union, and zerk to make them.
I put the extension on the forward pto zerk because they are so hard to get to.
The buffalo turbine had three zerks under the safety grill, so I put some extensions there too so I wouldn’t have to pull the grill to grease. The extensions cost about $6 each to make.
/ any toro groundsmaster fans on here? #943
Anyone use r&r products vs standard Toro brand? Looking for some spindles for a 72" mower deck and seems to be the only ones I can find. I bought a hood latch and a few small things from them and they were fine, but wondering about spindles and bearing quality from them.
Let me know if anyone has any experience
Thanks
/ any toro groundsmaster fans on here? #944
Hey fellas. I have three running and driving units for sale in southwest Virginia. Side discharge, rear discharge, two flail decks, and what's left of an old 72 parts unit.
328-2wd-rear discharge
328-4wd-side discharge
325-4wd-flail deck
276-722-0599
/ any toro groundsmaster fans on here? #945
325-4wd-flail deck
276-722-0599View attachment 697612
What is the purpose of the flail deck? cutting rougher taller grass?
/ any toro groundsmaster fans on here? #946
View attachment 674167 on the latest addition to the stable.
Don't have any pictures that show the shield over the fuel tank, I will check tomorrow to see if my 328D has it.
The air cleaner is from a 328D:
View attachment 674168 View attachment 674169
View attachment 674170 View attachment 674171
Seeing your aggressive tires on the back reminded me to ask, do you know if you can fit wider tires on the front with the mulching deck? Not that I need them, I just like the way they look lol
/ any toro groundsmaster fans on here? #947
Yes, a little wider than what I have with Ditch Witch wheels.
Depending on wheel offset, you might need a wheel spacer.
/ any toro groundsmaster fans on here? #948
Thank you sir! :)
/ any toro groundsmaster fans on here? #949
These are the tires that were on the 325D when the recycler deck was on it:
/ any toro groundsmaster fans on here? #950
I put a set of 24x12.00-12's on my one with the side discharge deck. I would love to put them on my mulcher, but there is no way they will clear the rollers. :(
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
2018 FORD F-350 FLATBED (A60736)
2018 FORD F-350...
KAESER COMPRESSOR (A60736)
KAESER COMPRESSOR...
John Deere 5045E for sale
John Deere 5045E...
Deere 35G (A53317)
Deere 35G (A53317)
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
