Woods TSG50 stump grinder.
/ Woods TSG50 stump grinder. #1
NH3930Turbo
Richmond, Virginia
New Holland 3930 Turbo, John Deere 5500/520 loader
Anyone have any experience with these units? Recently purchased one from auction and so far it seems to perform as intended. Went after a couple hickory stumps to really test it. Did pretty well with that and is like butter through pine. Does seem to want to bounce a bit if you try taking too much off in a pass. Teeth are slightly worn but all still intact. Other than the $800.00 teeth from Woods, any place else to get quality cutter teeth? Found one site xtremewearparts.com, they are quite a bit cheaper than OEM. I've researched it some, almost think Woods has some proprietary cutter style as I haven't been able to locate anything else.
/ Woods TSG50 stump grinder. #2
One came with my purchase of a used tractor. Seems to work well, I'm sure my teeth need replacing or sharpened too. Take it slow when working it and it won't jump so bad. My clutch will slip if I try and go too deep. Do you have multiple remotes or a diverter valve?
I'm using a hydraulic tapping manifold on my NH3930. This grinder came with a joystick mounted on the unit itself, looking at the hoses and the way its mounted, I'd guess this was a dealer installed piece. Thought about removing it and using the SVC ports on the tractor as to not have to get on and off the tractor, though it is a lot easier to see what's going on standing at the unit(I'm sure any safety guys head would explode seeing it in operation.)
/ Woods TSG50 stump grinder. #4
Mine works of the rear remote with a diverter to switch between cylinders. I work it from the seat. I've worked it from the ground a couple of times but it was awkward. A joystick sounds like a good idea.
/ Woods TSG50 stump grinder. #5
There's a couple of videos on YouTube showing people using it. Sappy trees seemed more difficult than dryer wood also I launched a dead stump once so I check them carefully now.
I like the joystick control, would definitely be easier as a two person operation.
/ Woods TSG50 stump grinder. #7
Do the teeth use a 2bolt pocket mount? If so then I'd look at Greenteeth.
This is the tooth for a Woods unit.
/ Woods TSG50 stump grinder. #9
Ah, nevermind. Doesn't look like Greenteeth won't work.
Generator Cord (A65640)
Generator Cord...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
AGroTK YC-32G (A64127)
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
