Light Fixture Question (adding one)
/ Light Fixture Question (adding one) #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
We added on to the house a number of years ago. During that time, they added a (hard wired) light over the garage.....however, it was wired to a dedicated switch up in the kitchen on the other side of the house. So, we left the switch on all the time and put a motion sensor light there.
Have since added to the house again and now, the wife wants a garage light (outdoor) to be switched right by the garage door. The OLD light is currently gone and the wires are sitting inside the house in a box.
So....thinking.... I said what if we got an outdoor fixture (and I think this is the start of the problem).... get an outdoor fixture with THREE bulbs on it (outdoor flood type). Take TWO of the sets of wires, hook them to the switch by the garage door. Take the THIRD bulb and wire it to the switch upstairs. Now, all the wires are accounted for and in use rather than just being buried & dead.
She does NOT want two different fixtures outside yet we now have two different power sources. (or will have once the switch by door is wired)
Personally, I like the idea of one fixture with three wires (hooked into two different circuits) BUT, the common sense part of me says that is probably in violation of some code since you'd have two sources of power coming into one fixture.
Thoughts?
Side comment.... it's sometimes very difficult working with her as she's VERY VERY aesthetics orientated...and having two different fixtures is "red neck and ugly".... can be frustrating at times so I'm trying to find a solution that will work with her visual needs and stay safe. Wiring a 3-bulb fixture onto two different switches (two bulbs to one switch, single bulb to the other switch) would be a perfect fix. Anyone know of such a fixture that would keep it legal?
/ Light Fixture Question (adding one) #2
The easiest answer would be to get a wireless remote switch. you can add as many locations as you want. Amazon sells them, so do electrical supply houses. You leave the light source hot 100% of the time. The remote switches use batteries. Batteries last about 5 years.
your not supposed to have 2 power sources to one fixture. Someone may turn off the circuit thinking fixture is dead, but the other half is still supplied with power. I suppose a linked breaker would nullify the problem, but good luck isolating circuits.
I use wireless switches and dimmers all the time. Especially useful in adding 3 way and 4 way switching to old houses.
/ Light Fixture Question (adding one) #3
Whatever you decide, go with LED. One, you will never replace a bulb, two, they run extremely cheap and 3, light output is fantastic.
/ Light Fixture Question (adding one) #4
... BUT, the common sense part of me says that is probably in violation of some code since you'd have two sources of power coming into one fixture...
Not necessarily. For example, in a new house here a kitchen is required to have 2 circuits for outlets, each on it's one GFI breaker. If you have an extremely small kitchen that only has one wall outlet (2 places for plugs) then the outlet is split and each side has a separate circuit.
It's been a while since I did electrical work, but the electric codes on this type of thing has more to do with the number of conductors in the box than the number of power sources.
/ Light Fixture Question (adding one) #5
But you HAVE to use a 2 pole linked breaker to protect the outlet. You cannot use separate breakers if you split off the tab and bring 2 circuits to an outlet. I mainly do this for dishwasher/disposal circuits where there is 1 outlet under cabinet.
/ Light Fixture Question (adding one) #6
Second that idea. I have one ( SkylinkHome WE-318 On/Off Wall Switch Lighting Receiver with Snap-On Remote (1000 Watts), Dimmer Switches - Amazon Canada ) to control the sodium light over my detached garage, works great and I have a second remote in my truck so I can turn it on from there. Only caveat is the light being controlled has the be of an incandescent type as the receiver is powered thru the lamp filament.
The link is to Amazon Canadistan where we get ripped of on price, your price will be considerably lower.........Mike
/ Light Fixture Question (adding one) #7
Actually, you use a double pole GFI breaker and each leg of the circuit powers half the outlet with a common return and ground.
But talking about wireless, I;m actually planning on putting in solar powered flood lights with remote control around the house. Solar because they will be put on poles and outbuildings some distance from the house.
20 years ago I wired switches into my basement stairway to control my flood light that is on it and outlets so I could turn on my tractor heaters from inside. If I had to do this again today I would go with wireless remote controlled stuff like others suggest.
I've replaced all exterior bulbs with LED and many interior...
I don't agree that they'll never be replaced. I've replaced some of them several times.
For the cost of them that kind of irritated me.... still, I do agree that they should lower electric use bills and the light output though harsh, is fantastic.
(I made the mistake of getting "sun" or 'bright' bulbs for use in the kitchen....had to dump them and replace them with soft white, NOW I look at the box before I buy them!!)
They really do light up the place. I was tickled when I was once cutting a field.... I had replaced the two (working) lights on the front of my tractor with LED's.....and I replaced the FOUR (non-working) bulbs on the fenders with LED's.... it's amazing what it lights up for you with all six of them on.
/ Light Fixture Question (adding one) #9
Yes - agreed. I’ve replaced the outside wing wall bulbs a couple times. Of course, they are on all night (work by light sensor).
They last a long time - but not forever.
MoKelly
/ Light Fixture Question (adding one) #10
Not all wireless light switches power thru lamp. Lutron switches are used on leds all the time. But there not the cheap chinese amazon brands.
the switch to GFCI requirements for disposal and dishwashers came after I retired from electrical trades. I’m actually glad I retired. Regulations have killed the trade.
i wonder when they will require children to be bubble wrapped before going outdoors.
/ Light Fixture Question (adding one) #11
My BIL was telling me that his BIL building an addition for someone and now the requirement here is that everything in the house needs to be on a GFI breaker, at least for new construction and getting it inspected. I'm also glad I don't do this kind of work for others any more. However, you don't need to get new stuff inspected around here if you add something. The reason he had an issue was that he needed to replace the main panel in the house so when doing that inspection is required before the power company will turn you back on.
/ Light Fixture Question (adding one) #12
Well, every residential circuit that is not required to be gfci needs to be ark fault protected. Idaho , where I live, has not adopted that absolutely stupid requirement. Washington State did. There is nothing stating every circuit needs to be gfci.
when replacing a main panel, the house wiring does not have to be brought up to code, only new additions to house need to be.
but, your state may be different.
/ Light Fixture Question (adding one) #13
Forget it, I forgot about the 3rd wire for return in a 3-way.
I'd go the remote route over putting two feeds into 1 fixture.
/ Light Fixture Question (adding one) #14
One no no I saw posted was to share a common return with 2 circuits, don't do that.
/ Light Fixture Question (adding one) #15
I got bit at one of my employer's facilities changing ballasts. I'd killed power to the circuit in a 2 bulb fixture. Unbeknownst to me, there were two ballasts in the fixture. 1 was on the breaker that I killed, the other was on a different circuit that is tied into emergency lighting, so if power dies the generator powers 1 bulb in that fixture. Plus a photo cell and relay was involved.
Anyhow, I put my voltage sensor into the socket after I killed the breaker and it was dead. Yay! Then I unwired the wire nuts that I thought were coming to the ballast. On the other side of the plate that the ballast was mounted to was another ballast with a relay and I couldn't see them working with my hands through the fixture. ZAP!
/ Light Fixture Question (adding one) #16
Probably should have said outlast conventional bulbs instead. Lifespan does depend on the SMD device. I try to only buy CREE SMD's
/ Light Fixture Question (adding one) #17
It's not a common return with 2 circuits, it is a common return with a split circuit. This uses a double pole breaker with 3 wires (black/red/white) where black and red are used to supply power to separate things, like the two sides of an outlet. This could also be done with 2 lights or one light and one outlet. For residential installations you do not run 2 separate breakers for one box. With a double pole breaker you ensure that all power to the box is off by switching off the dual pole breaker.
Here is an explanation of how to split an outlet in this manner How to Wire a Split Outlet
/ Light Fixture Question (adding one) #18
i have always used cree fixtures. i now have 2 burnt out lamps that were installed 2 years ago. lights are not used alot either. im not a big believer in leds.
/ Light Fixture Question (adding one) #19
As others have mentioned wireless switch solutions work well... & as grsthegreat mentioned the Lutron products work pretty flawlessly with just about any LED. Wireless will probably solve all your problems & be the cheapest... The only thing to keep in mind with the wireless is distance, you mentioned the switch in the kitchen is on the other side of the house. Lutron, I believe, still specs a 30ft radius (I have ones working twice that distance) but it does depend on location, interference, etc, so you may need a repeater. Just something to keep in mind, the better half may not like it, if it only works sometimes... lol
Another product you could look at is PulseWorx's (again priced higher like a Lutron) but their switches can be hardwired (no batteries) & no wireless. After they are installed the switches can then be programmed to control just about any of their other installed switches, programmed scenes or controlled loads. We use them a lot on retro-fit projects & for landscape / outdoor lighting control that go on an off based on sunrise & sunset (using an astronomic clock). They build a real quality switch (USA company - USA Assembled - 5yr warranty) and you install them as need for a project right next to any other decora switch... thinking "Aesthetics"
You could basically install two of their switches 1 in the existing kitchen location & 1 in a new electrical box in the garage & then program them to operate like a traditional 3-way switch but without the 3-way wiring...
Just an option to look at... this pic is one of their switches & a controller installed, you wouldn't need a controller just switches (oh, the LED on the switch can be defeated or change based on status)
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T800...
PATRIOT 5100 ELECTRIC CAKE FEEDER (A64277)
PATRIOT 5100...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
