Not Charging
/ Not Charging #61
That larger output alternator (for A/C models) is a near-twin but its fatter. So you need a longer adjustment strap over to the block, and likely the next size belt. For me, I would get the non-A/C alternator and keep the project simple.
But your low charging issue may not be the alternator at all.
/ Not Charging
Glad you said that. That's all that's needed anyway. LED lights up front are a mod I want to make at some point. I do now into the night sometimes in summer. I put an LED rear work light on that's on when I think my low beams are on up front...I can't remember how I wired it now?
/ Not Charging
I see a 35 amp alternator for some of the 79 nissan vehicles. And then certain models I select there is a "non AC " 50 amp alternator and then an "AC" 60 amp model. Do know which of these share the same physical housing as our original. I want to order one and get the largest output in the same size housing.
/ Not Charging #64
I don't know the answer. In 2004 when I needed an alternator I read here that early 70's Datsun alternator was more output in the same enclosure, I think 25 amp replacing Yanmar's 10 (?) amp original spec. I found online that the Datsun alternator I needed was used only through 1973, but the alternator that replaced it used the same regulator for a few more years.
And the advice here that only the non AC alternator was the same dimensions, with the AC version fatter, was confirmed in my research.
Wish I could tell you more but that's all I know. At any rate the alternator and potted regulator I installed in 2004 still work fine.
One more comment: when I bought the tractor late 2003 I noticed there was a new lower radiator hose that was already chafed by the fan belt. I put a radiator-hose clamp, smooth side up, on that lower hose where it was wearing, as a shield to protect the hose. No problems since. But a replacement fatter alternator mounted farther out might have this chafing problem and need a hose clamp shield too.
/ Not Charging
Ok I will check a 73 nissan and see what part numbers come up for that one. 35amp is more than enough for this tractor bit 8f I could get a 50 may as well right. That's will just be barely going to keep up.
/ Not Charging
I looked up a Nissan pickup from 73. It has a 1.6L further looking shows it's a 35amp alternator, main mount ear at 6 o'clock and rear plug is clocked at 9oclock looking from the rear. This one has a 2.7" diameter pulley.. The 79 has a 2.0L engine also a 35 amp and the rear plug is clocked at 12 o'clock, and mainount ear also at 6 o'clock. The pulley on this one is 3.1" in diameter. My tractor is at the 9 position so your correct about the 73 being the right one. The pulley I don't really care about either way, that's suck a small difference you can adjust that out and also if it was that big a deal I could just swap my original pulley onto it if I needed.
Thanks again California for your knowledge.
/ Not Charging #67
With the Yanmar turning at lesser rpm's than the 1.6 L light pickup, I think you want the smallest pulley. Likely the pulley off your old alternator.
/ Not Charging
Ok we can bring this to a conclusion. New AC Delco reman arrived yesterday. Swapped it just now. Swapped pulleys from my original because it has a smaller diameter. The alternator was bad. From high idle all the way through working RPMs I now am showing 14.01 or so at the battery right after startup. Must have been like someone said a busted diode or something in the alternator. One oinnon the old one would show up to 20v or so but it must not have been turning it into voltage to send out of that alternator cause at the battery connection at the alt all I got was battery voltage and at the battery while running I never got more than battery voltage. I can bring this long drawn post to an end.
Anyone searching for parts see a few posts above where I listed the application. I got it shipped to my house for I think just over $40. I can't remember all the numbers right now. I think the alternator was $32 it so. There was a $6 core or something on it and an instant $7 rebate from AC Delco. And I paid10 to ship it and a set of spark plugs for my old truck to the house. I am pretty sure I have to cover return shipping for the core so it really doesn't make sense for the amount of this one to return it. But I will check for sure.
Thank you again to California for his excellent knowledge and documentation of the parts that swap.
/ Not Charging #69
most of the time the only thing wrong with the alternator is
the diodes/rectifiers and you can get them at an auto parts
store/shop easy to replace.
willy
/ Not Charging #70
Thank rScotty! As I recall it was his advice that started me researching the Datsun (Nissan) application.
___________
Added: I see I used the term AC alternator, above. I should have made clear that it is the Air Conditioning special alternator that is higher output, and fatter so it would need a longer mount strap.
/ Not Charging
willy
Rectifier on this tractor is external, it was replaced already.
/ Not Charging #72
When I trouble-shoot a charging system that starts the tractor but doesn't seem to be maintaining the battery at full charge, I start with checking the battery & connections. We've been through that now in this thread.
Next thing I do is unplug the alternator from the circuit and hook my VOM directly to the alternator output leads to see if I'm getting AC or DC .... and to check if the output tracks RPM.
NOTE: Put the range selector on the VOM where it can safely handle at least 25 to 30 volts. Use a 50 volt scale if it has one.
Who wants to chime in with where to go from here?
rScotty
/ Not Charging
Grounds and connections were clean. That was done. Promise. I am not sure if I was getting AC or DC on the progs of the alternator. I was checking one of them on the connection. I was getting upwards of 20+v on the DC scale. And it did track with RPM. The other connection on the 2nd prong at the alternator didn't have anything or if I remember at this point it was 10-12v I'm thinking it was battery voltage.
Please post the whole diagnostic chart if you would like I'm sure it would help someone who is not an expert in what connection at what spot on the back of the alternator should be showing what voltage. I just know it wasn't charging as I was showing battery voltage running at the batter wire on the alternator and obviously the same at the battery itself. I was not charging. One connector on the back of the alternator was showing close to 20 so I assumed alternator was good. I am pretty good with this but not an expert. As you see. I'm happy at this point it's fixed. No headache parts are new alternator and regulator and I have about $50 in it all. And probably a good regulator I took off for the shelf. I'm sure im good for another few decades. Long enough I will forget all this I'm sure.
/ Not Charging #74
I'm glad yours is fixed and working. But there will be another owner with a challenge, so I hope this thread helps them too.
Just how one learns - and then teaches - the troubleshooting of electrical systems is still a mystery to me. I'm hoping to learn that art myself someday.
As for diagnostic charts - the ones that I have seen are either too simple to be useful, or are so complex they only work with the particular circuit they were designed for. There is really no chart that can substitute for a basic understanding of how charging circuits work.
By the way.....VOMs do vary in quality. Might as well get a good one. A good one - like a Fluke - will always have a way to tell AC from DC before the wrong assumption damages the meter.
When learning, I found it helpful to build up that basic understanding by realizing that all of the various motor/generator/battery systems are doing the same thing, and they do it in pretty much the same way.
Luckily, they all have only a small handful of similar parts connected up to accomplish the same simple goal - which is simply keeping a battery charged.
The only real difference being in a few details. With a little practice and study you will figure them out.
Don't be shy to ask dumb questions when you come to a mental roadblock.... Doing that sure helped me to learn this stuff.
/ Not Charging #75
Oh, we can't just call this thread coming to a close. There is still so much of this electrical stuff to be uncovered for charging. :)
/ Not Charging
Y
YeS full diagnostic flow chart for diagnostics would be great. I usually an tinkering with newer stuff than this. They have internal regulators. So you diagnose the alternator as not working, at that point it doesn't really matter if it's the internar regulator or something else that part is bad.
/ Not Charging #77
Yes full diagnostic flow chart for diagnostics would be great.
As rScotty and bmaverick noted, it will be helpful to owners in the future if we accumulate what we know into a diagnostics thread.
For YM186, and other 80's Yanmars with the pancake alternator and diodes external, I posted a test diagram in Post #7 of this thread. The thread also discusses the earlier pancake alternator with internal diodes.
And here is the YM186 wiring diagram, that uses that alternator. The diagram is likely applicable to similar Yanmars.
/ Not Charging #78
Pretty straight forward still on a YM 2000. My dash light would flicker!! Chased that for months and finally stumbled into it. Loose bad connection on my fuse panel. More corroded than I would have thought. That was more of the problem. Still ? how I found it!!...... Drove me nuts... Here is the 2000 dia. I just had out for anyone who may need it!!!!
/ Not Charging
Something I suspect to be the case but I am not sure is that your charge light does not come on till voltage is below a certain level, even if your not charging. My light flickered and then was on if I remember right. But once I charged the battery even though I was not charging my light would not be on. When I caught it the battery was pretty low 50% or less if I remember. So untill your total system voltage drops below some level I don't think that light even comes on....it's nothing to do with you charging I believe just a set voltage level. At least that's my suspicion from the poking around I have done. Both regulators kept it off too. But the battery was right around 12.6 resting so it was almost full
/ Not Charging #80
I just changed my battery of 13Yrs. which is still good since I didn't kill it. Which one thing I did notice going to a 700 cca. is that if my Rpm's. get below 800 my Alt. light will flicker. Barely bump the Throttle and it stops. How I found this out is if I'm shifting a lot with the mower on I'll run 2nd. PTO. so shifting is easy and I set my Eng. Rpm's as low as I can without the Mower in gear. It has always seemed to Gradually increase Rpm's a few hundred but not much
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61569)
2018 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 CATERPILLAR D3 LGP CRAWLER DOZER (A62129)
2020 CATERPILLAR...
Case 580 Super K Backhoe (A61166)
Case 580 Super K...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
2006 Ford E-350 Enclosed Service Van (A61568)
2006 Ford E-350...
