Kubota F series
/ Kubota F series #381
Do the other implements, blower, flail mower, etc. hook up fairly easily ?
As far as the hookups on the quick hitch, it seems pretty easy. You basically just drive the tractor forward to insert the male part on the tractor into the female fitting on the attachment and throw the lever over to lock it on. To go between the blade and brush I’ll have to connect the PTO of course, but hoping I’ll get the hang of it.
/ Kubota F series #382
Here’s a question and I apologize if already asked:
The F deck appears as if it rolls across the ground on at least (4) casters. The ZD deck is suspended and floats, with anti scalp wheels only touching to prevent bottoming out.
IF this is true, is one system superior to the other?
/ Kubota F series #383
I currently have both now and believe the hanging deck may have some advantages. The front wheels of the F sometimes act like they are digging into the yard in front of them when you come up to a steep accent and a slight bump up on the lift corrects it and let drop back down when going up the hill. They also drop into holes in the yard and can plow the yard up when going into some turns on sloped yards. By the way the F deck is hanging in the back and the 2 front wheels are rolling on the ground.
I do prefer the F over the ZD and if I only had one it would be the F in a heart beat. Have had only a ZD once for a short period of time and would hate to rely on just a ZD with my hill side property, may be different story with small flat "Lawn" but I have a large hillside yard..
/ Kubota F series #384
I’d think the F deck running on really rough ground at speed wouldn’t take heavy abuse as well as a deck hanging from a mower frame.
Not knocking either one but the small wheels on F deck would get beat up pretty bad here on my farm ground
/ Kubota F series #385
I found a nice F-3680 "chassis". No mower.
Wondered how a Peruzzi Flail Mower would work compared to the typical 72" commercial deck for lawn cutting?
I would go with the "Y" finish blades
/ Kubota F series #386
I needed a replacement 72" RD deck shell for my F3060 and still am convinced the Peruzzi flail would be a good choice, except at the time they only had 60" version and also the price difference between just shell vs. whole new (60") flail mower was something like $2000 vs. $4500 or so.
Looks like they now have 72" flail version so I think it comes down to price difference between a complete 72" Kubota deck vs. 72" Peruzzi for $5500 ?
In my case the old deck shell was warped (who knows why?) and worn lower edges due to municipal hired help having ran it it too close to the ground.
I still have the old shell but so far decided not rebuild it due to other priorities.
Here is my 72" RD deck with a new shell:
/ Kubota F series #387
Lost front deck wheel and lower bracket leaving shaft in place. Solid tire chewed up, rim dinged.
Was on a ruff slope.
/ Kubota F series #388
My 3680 72” side discharge deck has been shipped from GA and should arrive in PA in a week.
I hope to be mowing with it next week.
/ Kubota F series #389
I coulda tried it out for You if I’d known :LOL:
/ Kubota F series #390
I’m sure it’ll be fine! Little nervous about the “ heel/toe” pedal and the steering wheel instead of levers, though
/ Kubota F series #391
Steering wheels have been (a)round for quite some time so you should be OK
:ROFLMAO:
/ Kubota F series #393
The steering wheel requires much less input/movement/adjusting than the sticks on open somewhat rough ground. The steering wheel seems to stay true to the course but sticks require almost constant corrections and that comes from experience with both from me and others that I had helping mow some rental property.
/ Kubota F series #394
The steering wheel adjustment for me will be tail swing. I have to be careful the steering wheel and tail swing doesn’t have me swinging the tail end and slamming into a building, mailbox, bush, etc.
/ Kubota F series #395
Just did our first mowing of the season. As best as I can figure it's somewhere around the 38th season for our old F-2000 and about the 35th for us. Battery tender all winter and the old gal fired right up. Just needed a little air in the tires. 👍
/ Kubota F series #396
I think I will keep an eye out for a used one in the future. Also want a debris blower for leaves and roads so I can do more large property maintenance tasks
/ Kubota F series #397
It does happen. I still some times bump a tree but I figure it should get out of my way. :)
/ Kubota F series #398
It takes little bit to get used to it, but Z mowers where operator sits above the deck have somewhat similar situation with few feet less overall lenght.
We have been mowing 18 years Grasshopper (stick steering & front deck) and it's no big deal at all in my opinion.
/ Kubota F series
The F-series is the best mower I have ever had. It can be improved upon though with one thing. Four-wheel steer with the addition of a switch so that the wheels can turn in tandem or opposite of each other. That way going around trees would be closer and if you want to pull away from a building or a pond and not have the rear end swing around, they turn in tandem. It would be a killer machine if it had that feature.
/ Kubota F series #400
I was cutting our biggest customer yesterday-about an 8 hour cut-noting that soon I will be cutting it with the F and not the Z.
Gotta remember that tail swing!!!!
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2005 Nissan Frontier Crew Cab Pickup Truck (A61568)
2005 Nissan...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A60352)
2015 Peterbilt 348...
New/Unused Pallet of 8 Binders and 16 Chains (A61166)
New/Unused Pallet...
2015 Nissan Quest Van (A61569)
2015 Nissan Quest...
