Kioti LB2204 hydraulic issues
/ Kioti LB2204 hydraulic issues
Those three going to the loader valve are these three on the manifold. Bottom left goes to middle on loader valve pic. Top left going to far right on valve pic. Right on manifold goes to far left on valve.
Also have a picture of the pump off the tractor
/ Kioti LB2204 hydraulic issues #23
I did not realize how different the LB series was from the LK. I was hoping to see a pump similar to the ones on the LK models. That one mounts upside down from the LK.
I can not tell from the loader valve picture which is which. Usually they are stamped somewhere by each port. P=power in, T=tank and C=power beyond. Most likely on the bottom of your valve.
You are correct to locate the power beyond and check flow rate there. That will be after the diverter valve. The diverter also is splitting what flow you have for the power steering leaving very little for the loader and 3pt. This will probably be less than 1GPM at this point.
I would check on what pumps are available. Unfortunately the parts lookup does not show your model so I can not help with that. You may just need to call Michigan Iron and talk to them about pump options.
I was able to get fluid out of the hose I disconnected, it was going much slower than my previous flow test so I didn’t bother measuring and also I wasn’t able to pin point which position my diverter should be in. So my first course of action should be to source a new hydraulic pump to put on the tractor? Also is the function of the power beyond just to get rid of fluid while the loader valve is idle?
/ Kioti LB2204 hydraulic issues #25
I think I can answer your last question. Power Beyond is to provide hydraulic power to other attachments like a backhoe, auger, etc...
/ Kioti LB2204 hydraulic issues #26
Power beyond allows adding additional valves to the system. The loader valve feeds your 3pt hitch valve through the power beyond port.
I hate to say it but yes I am thinking a new or rebuilt pump is needed. You should see if a local hydraulic shop can rebuild yours. You still will have to sort out the priority/diverter valve as well.
I would look to see if they every offered a higher flow pump for your model. I was able to go from 7GPM pump to a 10GPM pump on my Kioti. But I knew the condition of the rest of the tractor and was comfortable it was worth the price of the new pump.
The hydraulic pump shop says my pump has minimal wear on the inside of the case but nothing that looks severely bad. They advised that the problem is somewhere else in the system.
/ Kioti LB2204 hydraulic issues #28
So on your flow rate test you used the hose that feeds the priority valve correct? That would be straight from the pump?
If so that eliminates most of the system. The only other thing it could be is a supply restriction to the pump. The test shows a 50% reduction in flow rate.
Now I agree there is probably another issue. Most likely with the priority valve as we know the diverter knob is missing it's stop. Could also be trash inside the priority valve adding to the issues.
But the flow rate is off the mark to me and surprised they did not find a issue in the pump.
When you did your flow test did you see a lot of bubbles? Is it possible the system is pulling air?
For flow test I just disconnected the metal pipe going from pump out to the diverter.
I will try to pull out the pipe that feeds the hydraulic pump with oil and run air through it to clean it out and then also look at where it bolts on the side to see if there’s a mesh filter.
The mechanic that looked at the pump said there were small signs on wear on the inside but nothing that would cause it to fail.
There was some air when I did my flow test. I can reinstall everything tomorrow and do another flow test to confirm. If there’s air how do I fix that
Also could I replace my diverter with another kind of hydraulic manifold that doesn’t have a diverter switch on it?
/ Kioti LB2204 hydraulic issues #30
If you are getting air the small Rubber hose feeding the pump is a common issue. The O-rings at the fittings can also allow air into the system.
Sometimes you can find the leaks by coating the connection points with grease. This is done one at a time then test to see if air is eliminated. If not coat the next one.
I do not know of any other replacements for the priority/diverter valve.
Another question I have is about the 3pt control. Some of these did not have position control valve. With position control the 3pt moves with the movement of the lever and you can leave the lever at any position you want.
The other type you raise the lever all the way up till you reach the desired height then return the lever to center. To lower you move the lever all the way down to desired height then return to center. Do you know which type you have?
I have good news to report: So as well as removing the pump and having someone look at it I also removed all my hoses and blew compressed air through them. Upon re installing everything the rear will still lift slow at higher rpm but it’s holding position not falling anymore
Power steering also seems to be working a little bit at the higher rpms
/ Kioti LB2204 hydraulic issues #33
That is progress. Good Job! Now you just have to figure out the flow problem and priority valve. Once that is done I am thinking you pressure will increase and things will work much better.
By any chance do you have any idea where I can get a new diverter or know of an aftermarket one I could replace this with?
/ Kioti LB2204 hydraulic issues #35
You could call the guys at Michigan Iron. They are really good people to deal with and will have a better idea.
I would take it off and clean it real good looking for any blockage.
Thank you, I got this valve to replace my existing loader valve, could you just help me understand what P T N stand for? My old valve says in out P. Just need to know on this one which is in and out.
If I had to guess P is power aka in and t is tank aka out and n that’s plugged would be for the power beyond?
/ Kioti LB2204 hydraulic issues #38
P is Pressure in
T is Tank port
N is Power Beyond. You do need the PB sleeve for this valve in order to use the power beyond.
Very popular valve on this side of the pond. It's actually made by Badestnost in Bulgaria. Then just rebranded to whoever sells it on other countries.
P is Pressure in
T is Tank port
What is a PB sleeve?
/ Kioti LB2204 hydraulic issues #40
Power beyond sleeve is a fitting that's needed to provide flow to any valves after that one.
It's also valve specific, so you need to get one for your valve, unless you're not feeding any valves after that one. (I haven't read the entire thread though).
It looks like this:
Pressure sleeve 1/2 BSPP for P40/Z50 power beyond - Hydraulic Master  Online shop
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
Case 580 Super E Backhoe Loader (A66285)
Case 580 Super E...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
Winco 12T Fertilizer Tender Box (A66408)
Winco 12T...
