Gas power washer question
/ Gas power washer question #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
I want a gas power washer but many use more water than my hose can deliver to it. For a unit rated at 3gpm can I lower the rpm of the engine to use less water? The unit is rated at 2600psi and I do not need that much either. If I lower the rpm of the engine can I lower the psi to a still usable 16-1800psi? Thanks.
/ Gas power washer question #2
Interesting questions I had never considered. Are you SURE your hose can't deliver the necessary flow? I've never measured my flow but suspect most water systems can provide more than that even at very low pressures. My power washer normally runs at a fast idle but when I'm using it the revolutions increase dramatically to build pressure. Be sure to turn on water before starting the engine to ensure pump is cooled and lubricated.
/ Gas power washer question #3
Can you use electric? Some are fairly powerful.
I've had a few gas pressure washers and they just sat. Go to start them and it's like an all-day struggle. Then it doesn't even want to run right because chinese carburetors suck.
If I can't use an electric, it don't get pressure-washed. But that's me......
/ Gas power washer question #7
Yes you can!
I bought a used belt driven Landa 2500 psi / 2.5 gpm with 11 hp Honda GX 340 back around 1995 or so and run it at reduced rpm frequently, not because of lack of water but there are many times when less works better!
The washer has a nice factory "idle down" option where the engine drops to idle speed when you release the trigger, for example need to move around or take a short brake etc.
I have made a couple of changes over the years:
  • Installed a high pressure hose reel elevated above the pump.
  • Switched to larger (log splitter) wheels, to make it easier to move in a grassy yard area.
It has been an excellent washer and I am sure there are other brands with similar features.
/ Gas power washer question #8
My Mi-T-M gas washer is 4.6 gpm with an 11 hp Briggs, belt drive pump. It has a pressure adjustment on the bypass valve but I've never tried running the engine at a lower rpm to see what happens, would have to fool with the governor adjustment to do so. My well can keep up with the washer but it really goes thru the water quickly. I don't use the washer anymore mainly because I don't need that much volume for anything I have.
/ Gas power washer question #10
I have a 3500 PSI with 3 GPM washer with 10 HP gas motor, or there about. I hook it to whatever 5/8" hose I have laying around hooked to a country 50-60 PSI tap well and a 100' garden hose. Never was starved for water. Let it rip
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
JCB TELESCOPIC FORKLIFT (A65053)
JCB TELESCOPIC...
2018 John Deere 3033R (A64126)
2018 John Deere...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
2019 Nissan Sentra (A61574)
2019 Nissan Sentra...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
