Fire extinguishers
/ Fire extinguishers #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Decided to up the ante a bit with my on board fire protection. Hay fires and baler fires are a REAL serious issue. Have water extinguishers on the balers. Now the tractors...
I prefer the 2.5G Badger-type stainless water extinguishers, but they are pretty expensive. Was looking around on Ebay last weekend and found a guy out of MA that reconditions, tests them and sells them at a more affordable cost. He also sells the mounts cheap. They arrived in 2 days. Mounted 2 on tractors already, have a few more to go. I keep the ABC type in the cabs, too for electrical/oil fires.
Anyone else have other mounting locations, or ideas? Heres the outside mount I did on 1 of the 3 today. I don’t know if I will keep the decal. A little large, but makes it easier for my guys to find in an emergency.
/ Fire extinguishers #2
Good stuff having the extinguisher... if it's possible I'd try and have some training in the use of them, perhaps via your local Fire Brigade/Dept. Instructions are all well and good but actual experience goes much further.
Is there some way that you can cover the top 3/4 of the extinguisher, perhaps a clear plastic bag, IOT keep debris/mud from the front tyre clogging the 'workings' of the unit?
/ Fire extinguishers #3
Very nice looking installation!
Tag shows 2017 service date.
Is that acceptable?
I have emptied more than a few. Had a brush fire I drove up on and helped him put it out. Also had a mouse nest fire in an engine compartment a few years back.
I also keep them on my hay balers.
Most all the tire mud flings outside the FE.
Is that acceptable?
Thanks. I think that’s an old sticker. They are fully reconditioned. Havent charged that one yet, its empty.
/ Fire extinguishers #6
What do you do to prevent freezing?
/ Fire extinguishers #7
Add some dish soap to the water to reduce the surface tension of the water and it will be more effective on hay fires.
I take them off during coldest parts of winter.
I left one on a piece of equipment years ago all winter. Forgot about it. Nothing happened to it!
Yes I do that with each discharge. Foam works great on fires.
/ Fire extinguishers #10
I had one I recharged with air compressor, rubber tipped nozzle put in end then pressed lever to fill watching gauge.
These have schrader valves.
Putting one on the big Massey next.
/ Fire extinguishers #13
Ditto on adding liquid dish soap or a product called "Fire Out". One doesn't appreciate the importance of a fire extinguisher especially when rd baling until you see a FIRE behind you. BTDT yrs back.
/ Fire extinguishers #14
OOPS I forgot about my water charged fire extinguisher during the 0°F temperature we experienced last week & I didn't empty it. OH WELL all my pipes survived so it could have been worse! :cool2:
/ Fire extinguishers #16
/ Fire extinguishers #18
I just have a small ABC strapped to the ROPs on my little tractor. I wanted it when brush hogging last fall as I have seen sparks from rocks or hidden steel fly out from them decades ago on the farm, grass wasn't dry so no issue then.
I guess we were very lucky, never had a fire on a tractor or implement brush hogging, raking or baling all those years. I don't even recall a fire extinguisher on any tractor or implement back then.
Now days I have them every where! I have a FE in my pickup, in the TJ, on the tractor, 1 in the boat plus a suppression system in the engine bay, a couple in the toy hauler and 2 or more in the house/garage and shop and so far only used one years ago on someone else's pickup that caught fire but I arrived too late and it burned until the Rural FD arrived.
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
2014 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2014 Caterpillar...
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
