Fire extinguishers
/ Fire extinguishers #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challengers: MT655E, MT555D, MT535B, Massey 7495, Krone 4x4 XC baler, 2-Kubota ZD1211’s, ‘20 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 38K trailer, Deere CX-15, 2 Pottinger Hay mowers, NH wheel rake, Claas 30’ tedder
Decided to up the ante a bit with my on board fire protection. Hay fires and baler fires are a REAL serious issue. Have water extinguishers on the balers. Now the tractors...
I prefer the 2.5G Badger-type stainless water extinguishers, but they are pretty expensive. Was looking around on Ebay last weekend and found a guy out of MA that reconditions, tests them and sells them at a more affordable cost. He also sells the mounts cheap. They arrived in 2 days. Mounted 2 on tractors already, have a few more to go. I keep the ABC type in the cabs, too for electrical/oil fires.
Anyone else have other mounting locations, or ideas? Heres the outside mount I did on 1 of the 3 today. I don’t know if I will keep the decal. A little large, but makes it easier for my guys to find in an emergency.
/ Fire extinguishers #2
Good stuff having the extinguisher... if it's possible I'd try and have some training in the use of them, perhaps via your local Fire Brigade/Dept. Instructions are all well and good but actual experience goes much further.
Is there some way that you can cover the top 3/4 of the extinguisher, perhaps a clear plastic bag, IOT keep debris/mud from the front tyre clogging the 'workings' of the unit?
/ Fire extinguishers #3
Very nice looking installation!
Tag shows 2017 service date.
Is that acceptable?
I have emptied more than a few. Had a brush fire I drove up on and helped him put it out. Also had a mouse nest fire in an engine compartment a few years back.
I also keep them on my hay balers.
Most all the tire mud flings outside the FE.
Is that acceptable?
Thanks. I think that’s an old sticker. They are fully reconditioned. Havent charged that one yet, its empty.
/ Fire extinguishers #6
What do you do to prevent freezing?
/ Fire extinguishers #7
Add some dish soap to the water to reduce the surface tension of the water and it will be more effective on hay fires.
I take them off during coldest parts of winter.
I left one on a piece of equipment years ago all winter. Forgot about it. Nothing happened to it!
Yes I do that with each discharge. Foam works great on fires.
/ Fire extinguishers #10
I had one I recharged with air compressor, rubber tipped nozzle put in end then pressed lever to fill watching gauge.
These have schrader valves.
Putting one on the big Massey next.
/ Fire extinguishers #13
Ditto on adding liquid dish soap or a product called "Fire Out". One doesn't appreciate the importance of a fire extinguisher especially when rd baling until you see a FIRE behind you. BTDT yrs back.
/ Fire extinguishers #14
OOPS I forgot about my water charged fire extinguisher during the 0°F temperature we experienced last week & I didn't empty it. OH WELL all my pipes survived so it could have been worse! :cool2:
/ Fire extinguishers #16
/ Fire extinguishers #18
I just have a small ABC strapped to the ROPs on my little tractor. I wanted it when brush hogging last fall as I have seen sparks from rocks or hidden steel fly out from them decades ago on the farm, grass wasn't dry so no issue then.
I guess we were very lucky, never had a fire on a tractor or implement brush hogging, raking or baling all those years. I don't even recall a fire extinguisher on any tractor or implement back then.
Now days I have them every where! I have a FE in my pickup, in the TJ, on the tractor, 1 in the boat plus a suppression system in the engine bay, a couple in the toy hauler and 2 or more in the house/garage and shop and so far only used one years ago on someone else's pickup that caught fire but I arrived too late and it burned until the Rural FD arrived.
