Engine design affects starting
/ Engine design affects starting #1
tree grower
Cuttingsville, VT
Ford 1210, Bobcat 742B, John Deere 1050
This is a very theoretical question, probably aimed at an automotive / engine engineer. Why do JD engines start so well without need of glow plugs, compared to other diesel engines? I have had my 1050 for 8 yrs (Yanmar engine), and even though it sits from December to March without starting, it will start instantly w/o glow plugs. I used a friend's 350 crawler that had not been started for many months, but it only turned over a couple times before starting--no glow plugs. Another friend has a Samsung excavator which had not been started in 8 yrs, but with new batteries he said the starter had barely engaged before it was up and running beautifully. My little Ford 1210 (Shibauru engine) needs glow plugs unless it is hot. My F 350 7.3 idi is the same. I assume the answer pertains to engine combustion chamber design, ie compression ratio, injection pattern, or some related factor. I'm curious as ****.
/ Engine design affects starting #2
Certainly does. Our VW TDI started and sounded virtually like a gasoline engine. Glow periods, even in winter, were only a couple seconds.
The Isuzu diesel engine on the generator starts and sounds like a gasoliine engine except for the built-in glow plug delay. Absolutely no shudder, no clatter ever.
Our 2 Benzes we had had virtually the same type of engine as has been on the 2 JD tractors I've owned, e.g. with chambers off to the side. All started with some initial shudders on cold running and were greatly helped with about 1/2 throttle opening vs. NONE on the VW TDI nor the Isuzu.
Ralph
/ Engine design affects starting #3
Direct/indirect combustion chambers and compression ratios. Air intake heaters. Battery and starter size. Do not forget oil type and grade along with engine wear.
/ Engine design affects starting #5
Our larger 4 cyl JD engine starts down to about -10 with little problem. It does like it better to be plugged in but Glow Plus Hardly matter.
My Diesel Mule engine has no block heater, but has never failed to start immediately with just one glow plug application.
The Kubota D722 Diesel Engine in my Steiner is the worst starting engine I have ever owned. Below freezing it needs to be plugged in and MUST have glow plugs. At minus 15c it will not start without a block heater. Without access to power, you would be screwed. Unfortunatley, Cummins/Onan chose this same engine in my 7.5KW Inverter Quiet Diesel Generator. I think Kubota makes some of the worlds greatest engines but they aren't much good if you can't get it started. I just put in JD Plus 50II 0/40 synthetic oil and it seems to help the D722 spin over a little faster in the cold. First time I ever used synthetic in anything.
/ Engine design affects starting #6
Question. The John Deere (non emmissions/no computer) had sat in minus 25c for days and I didn't leave it plugged in long enough.
Trying to start it, it was cranking quickly, half running. Let off on the starter and it would run for ten seconds and die. But not really running. Did that again and all of a sudden she just took off.
Is that bad for anything? The dealer told us when we bought it, that when starting it, you can damage the engine when it's surging at a low idle, rather than increase idle and let it run more smoothly. Maybe something about the rings.
/ Engine design affects starting #7
Careful, you guys that have good starting diesels are just "bragging", according to some on this site! lol
My loader tractor always starts, without plugging it in or using the glow plug, even below zero F.
It can be for many reasons, but the biggest reason, compared to the smaller tractors of today is, the smaller tractors of today have pre-chambers, they are not direct injected. The fuel is shot onto the pre-chamber and has to be warmed up for a cold start, I have those too, and I HATE them!
Years ago, I had a Kubota 2850, it was direct injected and started very easy, no glow plugs needed, even in the cold. I can't say the same for any indirect injected Kubota I've owned since!! Emissions, is why they went to pre-chamber diesels...
Other things that affect starting is, how fast it turns over when starting, what the fuel pressure is, (injection pump) and how much compression the diesel has, BUT every non-pre-chamber diesel I own, or have ever owned, has started better than the pre-chamber diesels of today. I'm talking about modern diesels here as many of the OLD diesels were hard starters, mostly because they had such low fuel pressures and lower compression...
SR
/ Engine design affects starting #9
Glad my '98 Yanmar diesel in the JD 4300 is a great starting engine. Seldom use the pre-heat, but do on occasion. Sits in an unheated shed. -10° F in there the other morning, and did smoke a fair amount. No plug for heat, and do not use a battery aid. Appreciate how quick it fires and runs.
/ Engine design affects starting #10
SR
Don't know what sort of chambers my little 32 Hp Shibaura (Ford 1920) has, but it starts easily without glow plugs, down to 32F, and I never have tried below that.
/ Engine design affects starting #11
If there are glow plugs the engine has a pre combustion chamber.
/ Engine design affects starting #12
Ford 1920 parts catalog shows key 36 as """glow plugs""".
/ Engine design affects starting #13
Why does Japanese small engines use out dated designs with prechambers and not direct injection? Is it the obsession to make it so light and cheap as possible?
/ Engine design affects starting #14
Oh.....I know my Ford 1920 has glow plugs,....the point is, that it starts just fine without them.
/ Engine design affects starting #15
Sorry my reading comprehension failed me again. Danged Oldtimers acting up again.:laughing:
/ Engine design affects starting #16
Agvg
Which small engines do you refer to here?
/ Engine design affects starting #17
You mean, "if there are glow plugs in the engine"...
Some direct injection diesels have a glow plug in the intake tract...
SR
/ Engine design affects starting #18
No, many "use to be" direct injection, the pre chambers came along with emission BS.
SR
/ Engine design affects starting #19
My 1962 Toselli 226 crawler tractor with a 2 cylinder Air cooled VM engine always started so nice and easy. Granted the lowest temp we usually get here is somewhere around 28F, but without any glow plugs or grid heaters (it didn't have any of that), it only took like 1/2 of a turn to start up.
These air cooled engines as long as it has good compression and good battery, it'll always start regardless of the temps outside.
My new tractor with the Kukje A series engine, Cummins licensed, start just as nicely and easy with the use of glow plugs.
The Kubota engine on my homemade backhoe, takes a loooot of glow plug help to start. Usually more than 40 seconds.
/ Engine design affects starting #20
Yes, large air-cooled diesels are popular I very cold climat, Tatra trucks uses V12 air-cooled for use in extreme cold. Some Russian equipment has all kinds of tricks to get it to start in the cold.
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
2003 Freightliner MC 331 2,800 Gallon Fuel Truck (A64194)
2003 Freightliner...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
Frac Manifold S/A Trailer (A64194)
Frac Manifold S/A...
2020 BOBCAT E35i EXCAVATOR (A65053)
2020 BOBCAT E35i...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
