Protecting new tractor from the elements
/ Protecting new tractor from the elements #1
swreeder
Wimberley, TX
LS MT3 52HC
Greetings everyone,
I just signed yesterday on a new tractor for my property. I have been using a old Yanmar 2420D for the past several years to maintain 50 acres in Texas hill country. It was undersized, but served me well until I could afford something better.
So coming home this week will be a new LS MT353 Hydro with a cab. Living in Texas, the sun and heat are brutal on equipment. I plan on building a really large barn in a year or two, but until that happens I want to keep this tractor shielded from the elements as much as possible. So I am looking for some ideas here.
It will have to handle extreme heat, high winds (not uncommon for 20MPH sustained gusting to 50MPH) and not be a eyesore on the property.
I thought about something like this (pic below) in a 16x24 config, but haven't been able to find plans and not sure what it might cost me to build it myself.
Advice, thoughts and suggestions welcome.
/ Protecting new tractor from the elements #2
Greetings everyone,
Open sheds are good enough. I keep mine in one and my last tractor at trade in time looked great after 28 years in there.
Only difference is I would build a "shed" type roof with the shed side of the roof facing the prevailing winds.
This way you can run the rafters parallel to the opening and not crossed as in your pic.
Much easier to build.
Just make the "low" side of the building high enough to swallow your tractor should you wish to back it in.
I'm pretty handy and have made and fixed lots of things in my life, but never a pole building. Going to be a learning process as there is a lot that I do not know.
/ Protecting new tractor from the elements #4
You should also call a few metal building companies and get quotes. Sometimes they offer a built building at discounts that are not much more than your materials then it's done quick and ready to go.
/ Protecting new tractor from the elements #5
On our remote property I have two shipping containers for tractor,atvs, golf cart, etc. They are not pretty but I placed them where I do not care how they look. They are cheap and most importantly they keep the rodents out. I have a barn with a lean to but I gave up on storing anything that rodents like in it.
/ Protecting new tractor from the elements #6
So I just got my MX in December. I began getting bids for a shed with 3 enclosed sides just like your picture. 26ga Galvalume. One bid for a 30x36 pole shed. Another for a 30x40 steel framed shed. Pole shed quote was $12,000. Steel frame shed quote $13,700. Well that was a no brainer to go with steel. But get this. . . If the price of lumber was not already bad enough, I was looking at 2x12x12 boards for raised beds. I looked 2 weeks ago, and one board was $17. 3 days later the same board was $31. I am NOT kiddin. If I get the bid for the pole shed right now, it would be more than the steel shed.
Both lumber and steel prices are way up, but lumber is up exponentially! ! !
Thats what I was afraid of! I hate to dump 10-15K into something that is temporary. My plans are to build a 30X40 fully enclosed, insulated big barn workshop, but thats going to take some time to save up.
/ Protecting new tractor from the elements #8
with the cost of wood these days!!!... A metal carport works just fine, can be custom sizes and are relatively inexpensive. My LS MT240 sits under one and survived a direct hit from Hurricane Sally just fine. (ours is certified)
Non-certified metal carports haven稚 earned an engineer rating for snow and wind load. Certified carports are designed by professional engineers to stand up to specific snow and wind loads in a given area. Certified carport covers may be built with additional structural tubing and include superior secure anchoring systems with extra bracing, in addition to tighter screw pattern spacing.
several years ago it was about $600 and it is 23x25ish with 7' legs. Would probably go taller these days, as my last tractor didn't have a ROPS, but the MT240 fits just fine. (The extension to the left is new, it is what was left of a neighbors carport we cut in half after a Hurricane Sally tree landed on it. We had enough scrap for a large lean to, it was completed about 2 weeks ago. I am fully confident in it's hurricane wind rating...a tree not so much.
Tree on top of the lean-to when it was a full carport:
/ Protecting new tractor from the elements #9
Then what you do is to build this shed with a design that will incorporate your eventual, full building. In the meantime, you still have shelter for your tractor.
Another reason to incorporate a "shed" style roof as they can easily be made to attach and blend into a larger building addition.
/ Protecting new tractor from the elements #10
swreeder - that original picture of a lean to is all I've ever had out here. I've kept two tractors in my enlarged carport for over 39 years and had no damage of any kind. We don't have the heat that you do but UV from the sun is probably the same. You gotta keep the sun off the tires and any other rubber or vinyl parts.
Around here - fully enclosed reduces the dust/ash build up but certainly does not eliminate it. Our SW winds will blow dust/ash everywhere. That's why I've never gone beyond a large carport. My M6040 sitting in its carport stall. View attachment 686388
/ Protecting new tractor from the elements #11
I am waiting on a 28x36 metal garage fully enclosed with 2 10x9 doors. for rightat 11000, You could build a 16x24 temporary shed for a couple grand. The steel container might be the way to go though because you can always sell it later after your garage build.
/ Protecting new tractor from the elements #12
I just saw that osb went up from 23 a sheet to 32bucks , thats crazy. Last yr it was 8 .
/ Protecting new tractor from the elements #13
Yep, I went to Lowe’s yesterday and saw that 2x12x12 that went up $14 over nite to $31 is now $32.75. I wonder where it’s going to end. Our new house was framed in July of 2019. My builder told me last month, he has had to adjust contracts up by $15K, because of the FAST rise in lumber prices.
/ Protecting new tractor from the elements #14
OP, when you say protection from high heat are you referring to temperature or UV (ultra violet) rays. It's the UV rays that really cause colour fading and tyre damage.
If so, I recommend orientating your future open shed facing North.
Tasmania has brutal UV exposure (right now, our Summer, we're getting Level 10 to 11 even with cloud cover). My 5-bay all metal shed, with concrete slab, faces directly South.
/ Protecting new tractor from the elements #15
It's going to end when people can't afford the prices, or find another building material.
/ Protecting new tractor from the elements #16
Yup......the lumber prices will crash, we just don't know quite when yet.
/ Protecting new tractor from the elements #17
It’s not showing any signs of stopping yet. Honestly I wouldn’t make any bets on it slowing anytime soon. My state is seeing record building mostly to out of starters fleeing the more liberal states. Our market was already a lot cheaper than theirs and an additional 20k for lumber isn’t concerning for them.
/ Protecting new tractor from the elements #18
When the stock market takes a flop, the lumber prices will also take a flop!
NOTHING goes up, and stays up....forever!
/ Protecting new tractor from the elements #19
It’ll probably never reach the price it was early last year though. Gas used to be 20 cents a gallon. That doesn’t mean it ever will be again.
/ Protecting new tractor from the elements #20
I hope that you're right. A happy medium would be nice... prices high enough to keep jobs on this side of the border yet low enough so that people can afford to build.
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
16ft T/A Utility Trailer (A64557)
16ft T/A Utility...
2005 Toro Workman Utility Cart (A64194)
2005 Toro Workman...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
2025 VR39 39in Vibratory Roller Skid Steer Attachment (A64553)
2025 VR39 39in...
