bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,978
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I have a fairly cheap wireless camera system I use on one of my tractors. I occasionally need to use a camera on other equipment as well. Rather than buy multiple cameras, I converted the one I have into a portable rig. Although the camera video is wireless, both camera and display require power. I used cordless tool batteries with adapters (in my case DeWalt), a few strong magnets and some 3" aluminum channel to make camera and display mounts that are truly portable and can be attached to any metal surface. These inexpensive battery adapters are available for most cordless tool battery brands. Even small 2 AH batteries will power the camera & display for several hours.
With the cameras hard wired to the tractor cab, general viewing is fine but I often can't see enough detail for some types of work. Lining up pallet forks or FEL SSQA implements can be difficult. Without any wiring, these cameras can be mounted almost anywhere. To increase flexibility, I added a ball / clamp combination from RAM products along with another magnetic base. I store the cameras & display in a case which I carry on the tractor. It can be set up in seconds anywhere it's needed.
Although quite sturdy, these magnetic mounts aren't meant for permanent use. For general purposes, I rely on the cab mounted cameras and use these for temporary work operations.
Yes, there are portable camera systems available but they are expensive and most aren't meant for heavy duty farm equipment use. They also have proprietary batteries which must be kept charged. This rig costs less than $50 (excluding battery) and uses the camera I already have. I always have a supply of cordless tool batteries charged and ready to go.
