Trailer shaking at 60MPH
/ Trailer shaking at 60MPH #41
Maybe I am over thinking? Antifreeze is nasty, doesn't dry or evaporate. It will coat the tire, wheel and valve stem. Anytime you check the air, I would think a spec of antifreeze would get in the gauge. You would also need to wash the tire and dry it, for a patch to stick.
Yea, you're overthinking it. I have antifreeze in all my tires, trucks and trailers, as dynamic balancers. I've had a couple of them patched; it's never been problem; it's a couple ounces for crying out loud, not a toxic waste dump. It's inside a tire, how many times do you have to deal with the inside of a tire? Let's see: a truck, Pathfinder, trailer, ZTR, tractor, RTV tires - in 7 years, maybe two trips to the tire dealer for a tire patch. BFD.
Checking air pressure: AF drops to the bottom due to gravity (which never fails); the amount getting into a pressure gauge is minuscule. I've checked my tractor and ZTR tire pressures all the time - which are 75-80% filled for ballast purposes - still no big deal.
Nasty? Use RV antifreeze, it's potable water compatible.
/ Trailer shaking at 60MPH #42
You are obviously fine with it, that's all that matters.
/ Trailer shaking at 60MPH #43
Good thing!
Hauling a tall stack of old grass clippings around calls for a smooth running trailer!
And my Wal mart push mower (self propelled, of course) :laughing:
2016 VOLVO SD115B SMOOTH DRUM ROLLER (A65053)
2016 VOLVO SD115B...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Rolling Cart Base (A65640)
Rolling Cart Base...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
2023 Big Tex 16GN 102''x40' Gooseneck Trailer (A64127)
2023 Big Tex 16GN...
208735 (A60430)
208735 (A60430)
