Harbor Freight FCAW welder
/ Harbor Freight FCAW welder #32
It may have already been mentioned but the HF welder mentioned is a DC welder. It runs a lot smoother than an AC flux core welder I tried.
To me, anyway. Anyone else got input on AC vs. DC in flux core wire welding?
/ Harbor Freight FCAW welder #33
Yeah we discussed this over at WeldingSite: https://weldingsite.com/threads/welding-a-wrought-iron-railing.283/
I tried both and wound up with the unit Gary bought. I found the AC flux core to be essentially unusable as a newbie. With the DC I was able to get strong welds and not all that much cleanup when welding good clean metal.
/ Harbor Freight FCAW welder #34
Hey, you know pictures over der really suck. Too small! Too many ads too.
Why all you kids call steel "wrought iron"? You ever meet wrought you gonna know what a day of work is for sure.
SanDiego look like one dem califoolish places. Look around fer ceramic shop. You find get a gallon of what called slip clay, I tell you dirty trick for next flux job. Save up some dat drywalmud too, another trick you don't know fer dat.
/ Harbor Freight FCAW welder #35
okay
/ Harbor Freight FCAW welder #36
My reaction too.
I am leaning towards the Titanium 125. Video reviews were good and I think I'd have a better learning curve. It's $180 now and with a 20% off coupon.
Now deciding to get auto darkening or standard helmet. My concern is not cost but safety and workability. I have a friend who is a professional welder and he swears by the HF auto darkening helmets.
/ Harbor Freight FCAW welder #37
Free HINT- Horrible Fright autodark same technology as Hobart, Miller, and de rest. Few guys have torn em down and element & electronics same. Been known fer years.
BangGood.com sells same helmets cheap direct from China, goo look you can even buy replacement package for 10 bucks.
Big important part is battery replacement. Coin cells on some easy to change, others you gotta open de package and glue back shut after solder new battery.
Autodark all began wid General Electric self shading window dat was big flop. Technology of glass ain't changed, electronics got better over time.
/ Harbor Freight FCAW welder #38
My reaction too.
I bought one of the cheap $50 auto darkening HF helmets and while using it outside, decent results. If you have glare you might need a cover behind your head otherwise you won't see anything. Also be sure to remove the protective film from the glass otherwise it's all blurry.
/ Harbor Freight FCAW welder #39
Don't forget to add bib, or at least slather wid de zinc paint protects from Sun.
Wash off outside spatter lense every day too.
/ Harbor Freight FCAW welder #40
And good PPE. First time you burn a hole through the crotch of your pants you'll get on Amazon for a good set.
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
CHANDLER 500 BBL FRAC TANK (A60736)
CHANDLER 500 BBL...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
2012 HEIL (A60736)
2012 HEIL (A60736)
