Thanks, have some follow up questions:
Does a
grapple have any advantages over the Green's Machine Thumb and tooth-bar set up?
Are there different styles/functions of grapples?
What is involved in adding a 3rd function to this
B2650 and approximate cost to have it installed?
How stable is a log on a set of pallet forks when driving...thinking the log would need to be strapped to the forks?
Can the thumb be installed on the pallet fork frame?
Yes a dedicated
grapple setup will hold more material and be easier to grab/gather up loose brush, also will be more HD. There are many different types of grapples available, but for your tractor, probably a light to medium duty
grapple would be best as you don't want to lose lift capacity with a heavy
grapple.
Cost for a third function valve, wiring, hoses and related parts is about $5-600 range, dealer installed are typically around $1000-1200.
I have moved many logs with bolt on pallet forks - no need to strap them on unless you are moving them across rough sloped terrain, as others have said carry low and go slow and you should be fine. Counter weight on 3PT is key- also maybe you want to look into a rear log lift for your 3PT?
As far as a "green" thumb, or bolt on
grapple on your bradco forks, I think this might be your best option cost and function wise, it depends on your fork style where you can mount the bracket for the thumb. You might have $1500 or so in this setup `$1000 for the 3rd function valve, $500-800 for
grapple setup.
If this is a "one time event" cutting and moving 30 trees and brush, then you could get by with what you have now, but if this is something you will do over a few years, then I would invest in the
grapple now.
The other benefit of the bolt on
grapple you could use it on the pallet forks or the bucket if you get duplicate mounting hardware (set for the bucket and the pallet forks)
