Retaining walls and patio
   / Retaining walls and patio
First batch of blocks arrived for the retaining wall. Started getting the lowest point first course down. Using a 10 inch 3/4 clear base. 3 down, 492 to go. received_425082985295514.jpeg20201229_122413.jpeg
   / Retaining walls and patio #23
I see the slight curve. Are you setting the wall vertical or using the step back option? When I rebuilt my wall I changed it from vertical to stepped. Cutting the blocks for the curve was a pain.
Doug in SW IA
Doug in SW IA
Going vertical so the blocks will be flush. They are secured with pins instead of lips.
These blocks are narrower in the back than the front so you can curve them without cutting. Makes it really easy.
Realized I needed seven blocks on the first course so had to dig out a little bit. But today I bought a cheap 20lb bauer demo hammer from HF... seems to work just as good as the makita I usually rent. So far this is about 3 hours of work to get these blocks in.
Tomorrow I'll pick up some drain pipe since it needs to go in behind the second course. 20201230_153757.jpeg
Stanley "Dirt Monkey" Genadek - YouTube
May want to look over some of this guy's videos - pro landscaper
Yup, I've already watched them! Good tips for sure. The only thing I'm unable to do to make this the best possible wall is build up the backfill with grid to spec. The hillside is just too steep to take out another 3 feet and then build it back up. That would dramatically increase the strength but what I will be doing is laying grid as far back as I can, just not the full four feet that the engineers would want.
   / Retaining walls and patio #28
What is maximum height of your wall.depending on existing soil rotational grid is needed for walls over 4 ft in height
We're going to 4 feet including the cap.
I am all for the grid, I'm just making the risk:reward calculation based on the amount of work it would be to excavate out the hillside to be able to insert the grid, compared to the height and building permit requirements (not needed up to 4 ft total height).
   / Retaining walls and patio #30
That works for a while, but depending on the curve and height eventually you have to start cutting blocks. The radius of the curve gets tighter and at some point the pins don't line up anymore.
Doug in SW IA
2013 Ford F-150 Pickup Truck (A55788)
2013 Ford F-150...
Year: 1999 Make: GMC Model: C7500 Vehicle Type: Truck Mileage: 46613 Plate: Body Type: Conventional (A55852)
Year: 1999 Make...
2019 Dodge Durango AWD SUV (A55758)
2019 Dodge Durango...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
Yanmar YM1500 Tractor w/Loader (RUNS) (A50775)
Yanmar YM1500...
Giyi Pile Hammer (A53316)
Giyi Pile Hammer...
